Question about Hotpoint HSS25GFP Side by Side Refrigerator
Water dispenser is extremely S L O W
My water dispensers output is a bit too lite. it takes a considerable amount of time to even fill a regular drinking glass...is there a way to increase the flow?
On the bottom of the freezer door you will find a clear hose. Follow the hose and you wil find a connector. Disconnect it and place on small pan. Activate the water switch on door and see if water comes out. The problem is on the line going from bottom of freezer door up to dispenser. Some models water line is close to extruded door(miss manufacturing) cover and the line freezes over. This is a manufacturing fault from GE and unfortunatelly the whole door must be replaced
Posted on May 29, 2007
    President:
  • 1,462 Answers
Check no ice build up in bottle but the most likely cause is poor water pressure on the inlet. no cure except to improve water pressure. if there is a valve in the input water line, check it is fully open
Posted on Apr 25, 2007
Tip
Bottled water appliance precautions
Hey Culligan Man!
My family has enjoyed the convenience and health benefits of drinking bottled water for several years. We have used a drinking appliance where the bottled is upturned and the water is gravity-fed. The water is then heated and cooled and served from hot and cold spigots. (I've seen other types of dispensers when the bottle goes upright inside the cabinet and is pumped into the water pitcher.)
The heated water quit working recently but the refrigerated part was OK. After noting how some members of my family used the dispenser, I have solved the problem. It is caused by the water level running too low in the mini water heater causing the element to burn out. Low water doesn't harm the mini-frig part. Low water levels are caused by using the bottle past empty and continuing to take water until it almost stops coming out. This "starves" the water heater, consequently burning out the element! Always replace the bottle on top before it gets past empty! If it gurgles considerably, it's filling up a nearly empty water tank probably with a burned-out element.
Maybe manufacturers can address this problem of too low water levels in subsequent models.
Regards,
Bob K.
on Feb 28, 2010 | Kitchen Appliances - Others
Won't dispense all the coffee from the disc. Have to push button at least two times. Descaled Help
The discs tell the machine how much water to dispense through the disc. Some discs dispense a small amount for an Espresso, others give a larger drink. Normal cups will not fill, you need smaller coffee cups for most Tassimo drinks.
Check the packet to see how much it dispenses and check with a measurement jug to see if it is working properly, you may be surprised to find it is working fine.
Oct 03, 2014 | Bosch TASSIMO Coffee Makers & Espresso...
Ihave had Hiccups for two days and need a method of stopping so I can get some sleep
Hey there "Lanier" do you still have the Hiccups ? if so, I will tell you how to get rid of them in 30 seconds.
get a medium size glass (10-12oz) fill it to about 1" full from the top, now while standing up, drop your head down put the glass to your mouth so that your trying to drink off of the opposite side of the glass than you normally would, so that your chin is actually in the glass and so the bottom of the glass is going back towards your chest, now as you slowly bend forward from your waist, start drinking the water out of the glass, (its like your trying to take a drink in the opposite fashion that you normally would) . Now you might spill a little but its ok, you only need to drink a small amount of water, now when your bent over and have had a few swallows of water, keep your head bent down for 10 seconds or so and now stand back up and pour the rest of the water down the sink because your Hiccups are gone.
Here is why this works, (it's actually a biological plumbing thing) the " Hiccups " are nothing more than an air bubble in your digestive system, so by bending over and drinking the water in this fashion, it lets the water run into your system and the air bubble to escape over the top. ( BTW my dad taught me this trick in 1965 and I've cured a million cases of Hiccups, plus I've won a lot of money in the bars showing people how to do this ).
You can thank me later...
Sep 29, 2014 | Lanier UNKNOWN
If water get overflow from the tub what defect it will cause to the machine
it can cause a lot of rust on the metal parts of washer and could cause wires to short out
May 22, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Saeco Odea Giro nozzle blocked.
First, I'm Not a Saeco Representative, though I have worked on some Saeco machines.
** Most cases of one side not dispensing coffee is usually coffee that has dried and built up over time to coat the least used spout. This is caused by the machine not being flushed or cleaned daily.
** Follow the MFR's daily cleaning instructions to keep you unit operating properly.
** fill a glass up of water to the rim and place on drain tray. the water in the cup should be even with the glass lip all around the cup. If it's leaning to one side then your machine (or table it on) needs to be level in order for the spout to dispense evenly. Another way to check is to place 2 shot glasses under each spout and brew a double shot. Both should fill at the same time and be the same amount when finished.
** Check your MFR's kit to see if there is a small brush to allow for nozzle cleaning. Otherwise follow the cleaning instructions and do multiple cleanings to get rid of the coffee residue. Once cleaned you need to maintain a regular cleaning schedule.
** There are no serviceable parts in these small home machines. Suggest contacting your vendor or Saeco for service or replacement.
Aloha! ukeboy57
Dec 21, 2017 | Saeco Odea Giro Plus Coffee Maker
Water dispenser is not working
Does it make ice? If it makes Ice, then you have water to unit. If No Ice and No Water, check water supply. Otherwise, you could have a bad water valve. Remove valve and the line coming off of valve to water reservoir try to dispense water and if valve is good you should have water coming from valve. (have a bucket or bowl handy to catch water).
Mar 28, 2010 | GE Refrigerators
Ice maker quit, water still dispenses
even though you still have water dispensing you may have a frozen line to the ice-maker, take out your ice-maker and check to see if the feeder tube has ice in it, take a drinking straw and insert it into the feeder tube for the ice-maker and see if you can push it all the way to the valve, it's lite enough not to damage the feeder and strong enough to break up whatever Ice might be blocking the tube
Feb 16, 2010 | Kenmore 53642 / 53644 Side by Side...
Low water pressure on door dispenser
i have a similar problem. my water dispenser worked perfectly with the origional filter for about 8 month . then there was a decrease in water output. i then changed the filter.this worked fine for about 2 weeks . changed the filter again 2 days of water output. i have since changed the filter 2 more time with the same results. i do not have a kinked line . i have had the refer for about 1 1/2 years. ice production is down also . any thoughts?
Jul 01, 2009 | LG LFX25960ST Stainless Steel French Door...
No ice or water from in-door dispenser
When you first hook water up to the refrigerator you have to fill a tank in the fridge. Open the water supply behind the ref. turn the control on the front of the ref to water and hold a glass under the spout as if you are filling a glass . You may have to wait 3-4 minutes forthe tank and lines to fill with water before you get any to come out into the glass. The water my be discolored at first so run a few glass full through before drinking . hope this helps
Bobalix
Apr 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
195 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
