Question about Whirlpool Calypso GVW9959K Top Load Washer
Replacing u-joint and leveler in Whirlpool Calypso washer
Need to replace the washplate u-joint and leveler in a Calypso washer. Can't figure out how u-joint comes off shaft. The leveler has been removed along with inner wash plate dome.
How do the seals get installed before the leveler goes over u-joint?
Thanks!
Rodger
    Genius:
  • 1,011 Answers
Sir,
You shoukd also install a gasket set.. If you got the top loose lean itback and remove the top splash ring and set aside.. the you need toremove the grey balance ring from basket...where the dome in centermeets he washplate there are 4 slots... take 2 ftat screw drivers andinsert slightly into to beside each other .. push in and lift willremove the dome... then you have 8 7/16ths bolts to remove.... lift utwashplate... under the dome blow wash plate is the leveler andu-joint.. its a good idea to check it since you are that far.. if thereis alot of corrosion you should put in a u-joint kit which has a new lveler/u-joint/gasket kit...
click this link for more help
Posted on Dec 28, 2008
    Master:
  • 638 Answers
Http://www.applianceaid.com/calypso.html
just click the link and check out.
I have a Whirlpool Calypso and I have removed the washplate, lock nut using spanner wrench and u joint assy. I want to remove the metal inner basket so I can clean all the scum inside the outer wash...
Once you remove the agitator, then the nut with the spanner wrench, the basket should lift right out. It may need a little encouragement but it will lift out. I clean the out side tub with a putty knife to get the bulk of the scum off then use some cleaner like 409, or purple power to get the rest off. BE careful around the tub seal around the shaft, you don't want to damage it and have to replace it.
Jan 22, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer clothes get stuck under the washplate ..the gap looks too wide between tub and washplate...does the washplate need replaced,, or is the plastic seal around the washplate replaceable???
THE PLATE CAN BE REPLACED, GET ONE FROM YOUR LOCAL APPLIANCE PARTS STORE OR SEARCH ON LINE, SEARSPARTSDIRECT.COM, REPAIRCLINIC.COM, ETC. GET MESH BAGS FOR YOUR SMALL ITEMS. THAT WILL PREVENT FUTURE PROBLEMS, IE: PUMP GET STUCK AND BURN(COMMON PROBLEM)
TIMOTHY DO 714-334-1998
Aug 04, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How do I remove a small part of ziper
You go buy a magnetic or three hook flexible retriever from your hardware store and go fishing down the side.
Or if the zipper is floating about loose you take the back off the machine after dumping the outlet hose into a bucket to drain off the water.
Tip the machine forward or backward so that the outlet hose from the drum to the pump is as near to the ground as possible then remove the clip retaining it to the outer drum and your zipper should be within grabbing distance.
Make sure you have an old towel underneath the hose before you crack the joint
Jul 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore calypso has clothing stuck
I believe the problem is the Outer Wash Plate. Replacing it may fix your problem. I am about to do that to mine, so I don't know yet. The outer plastic 'seal' or rim of the washplate should be touching the inner surface of the stainless steel wash basket. So it catches clothes. I just installed a u-joint kit today, so needless to say, I got out the washplate and retrieved my clothes on the way to replacing the u-joint. It involves leaning up the upper lid and cover, removing the tub ring and balance ring and the dome. Then there are 6 bolts to remove the outer wash plate to get to your clothes underneath. Might as well replace the washplate while you are at it. to download the manual, copy this https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
into your internet explorer address line and save the manual. page 36 starts the instructions I used to remove the washplate and other items. I spent a LOT of time cleaning the gunk out.
May 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso once wash cycle is selected. The machine will fill then stop and there will be a humming noise
does it wash or spin anywhere on the dial.  If not, the coupling that connects the motor to the transmission is defective and need replacing.  A $20 part
Mar 25, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What type of wrench do i need to change u joint on Whirlpool Calypso washer
You will need a spanner wrench available from your appliance parts dealer.
P.S. There are several parts that MUST be replaced when the u-joint is replaced.
Mar 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Taking the spinner off
if you are calling the washplate the spinner pry off the dome then take out the six or eight bolts holding it down.
Oct 25, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso
If you have already removed the outer washplate, the inner wash plate should just lift off the leveler and u-joint. The washplate dome refers to the center cone that fits on top of the outer wash plate. This piece comes off by inserting a screwdriver in the slots along the sides and gently prying to release the locking tabs. The mounting bolts that secure the outer wash plate also secure the inner wash plate to the u-joint assembly. There is a seal under the inner wash plate that may be holding it on. I don't know of anything else that would be holding it in place. Searspartsdirect.com has an excellent exploded view diagram of the wash plate and components that you may refer to provide you with a perspective on how everything fits together. I hope you find some of this information helpful. Please post back and let me know if you are still having problems.
PS You may have to resort to using a rubber mallet to lightly tap on the inner wash plate to knock it free.
Sep 28, 2008 | Kenmore Elite 21086
Material getting caught
ARE YOU SELECTING THE RIGHT AMOUNT OF WATER.AND MAKE SURE THE HIGHT OF THE CLOTHING IS NOT TO HIGH.
Sep 12, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
298 people viewed this question
Dan Webster
Dan Webster
Sal De
