Question about Nintendo Wii Fit for Wii
'step off me and press A' message when not on - cant get further
Have tried all the troubleshooting solutions several times - these don't help. Family Ski works without problem.
When entering height and age when logging in we get the above problem.
Thanks for your thoughts! :-]
  • jenkinslaila Jan 03, 2009
    I have the same problem. Balance board works on Wii Ski but can not get past step off of board on Wii fit. Somebody please help.
HI HAVE THE SAME PROBLEM ( STEP OFF ME AND PRESS A MESSAGE )
ANY BODY WITH THE ANSWER TO THIS PROBLEM !!!!
ONLY GOT THE WII FIT FOR CHRISTMAS 1 WEEK OLD !!
Posted on Jan 01, 2009
  • Ivy  Cada
    Ivy Cada Feb 07, 2011
    HI there.
    You need to re seat the sensors.
    I have written a great tip with video. You can find it here.
    Thank you!
    http://www.fixya.com/support/r7297346-ni...
HELP! ACT Emergency!
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect first.
1. Try a new set of AAA batteries.
2. Adjust the contrast by pressing and releasing the 2nd key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
3. Remove one of the AAA batteries. Press and hold the CLEAR key. While holding CLEAR, reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the CLEAR key and then press it one more time to remove the message.
4. Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Jun 08, 2013 | Texas Instruments TI-85 Calculator
I get black "lines" going across the screen when i hit the graph button. It will graph also,but you can barely see the graph. Help pleae.
Jun 04, 2013 | Texas Instruments TI-83 Plus Calculator
The batteries were all just replace including the lithium and it won't work I don't have cables with it does it need a download.
Usually, you should not change all batteries at one go.
It is likely that the calculator is ON, but the screen is too light to enable user to see anything. If that is the reason, you can darken the screen.
Press the [2nd] key and release it. Press and hold the UpArrow till screen darkens enough.
You can reistall the system (if needed) by connecting it to a working TI83Plus calculator. You need the calc-to-calc cable.
If that does not work, here is what the Texas Instruments Knowledge Base says about the calculator not turning on.
Without further delay, here it is from the horse's mouth (TI Knowledge base)
I hope it helps.
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Remove all of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
Oct 25, 2009 | Texas Instruments TI-83 Plus Calculator
I changed the batteries and now it will not come on
Here it is from the horse's mouth (TI Knowledge base)
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create backup using TI Connect™ first.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed bypressing and releasing the up arrow; repeat as necessary. To adjust orlighten the display, use the down arrow.
  3. Remove one of theAAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83 or TI 84 Plus family to reinstall the calculator operating system (see below.)
  5. Removeall of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn thecalculator on. Adjust the contrast if necessary.
Reinstalling the OS for the TI83/TI84 Plus family
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TIConnect installed on the computer.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Oct 11, 2009 | Texas Instruments TI-84 Plus Calculator
Replaced the batteries and downloaded the software
Hope it helps.
Oct 05, 2009 | Texas Instruments TI-84 Plus Calculator
HP 5610 all-in-one fake "paper jam"
I request you to please perform the below steps to reslove false paper jam..
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
Sep 02, 2009 | HP Officejet 5610 All-In-One InkJet...
I accidentally pressed down for too long on my ti-84 plus calculator and i think it locked itself. how can i turn it back on? I NEED it for school!
From TI FAQs:
What troubleshooting can I try if the TI graphing calculator will not turn on?
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
Aug 24, 2009 | Texas Instruments TI-84 Plus Calculator
My TI-83 Plus Calculator will not turn on
This is from TI FAQS:
Solution 11900: Troubleshooting a TI Graphing Calculator That Will Not Turn On.
Aug 06, 2009 | Texas Instruments TI-83 Plus Calculator
NEED TO CLEAR MESSAGES OFF ANSWERING MACHINE
When the answering system is full, [FL] is displayed on the base, and the system announces "No remaining time."
To delete the old messages.
1) Press the [play/stop] key to review your messages.
2) Press the [delete,ont Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 159 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0in; margin-right:0in; margin-bottom:10.0pt; margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} ø] key( located below [ >| ] button or at the right side of [ ^ ] button )anytime during the message to delete.
3) You will hear a confirmation tone and the message is deleted.
You can also delete all the messages.
1) Press the [ø] key in standby mode.
You will hear an announcement “To delete all messages, press delete again.”
2) Press the key [ø] again.
You will hear a confirmation tone and [ 0 ] is
displayed on the base. All the messages are deleted.
When you try to delete all messages without first listening to your new messages, you will hear several short beeps followed by an announcement “Please playback all messages.” This means it protects you from accidentally erasing messages you have not yet reviewed.
hope it help ; )
May 27, 2009 | Lands Phones
RAM Cleared
This is kinda a weird situation. Because it's usually the other way around. Your ram will clear if your calculator is frozen. So take out all 5 batteries from the back. Even the back up battery. Then reset it again. 2nd then + then 7 then 1 Then 2. Good luck.
Oct 22, 2008 | Texas Instruments TI-84 Plus Calculator
Nintendo Wii Fit for Wii Logo
409 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
