Question about Ridgid 17038 4.5 Gallon Oil Free Twinstack Air Compressor
Ridgid air compressor OF45150A twin stack
When i turn on the air compressor atfter 2 seconds it pops the braker on the main pannel. I tested the motor winding on the motor with an ohm meteter and i have about 1.4 ohms. Can you help me Thanks Mike
BLOWEN PISTION ROD ON OF4515A RIDGID
Posted on Nov 04, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Habit-Forming:
  • 112 Answers
Sounds to me like u do not have it on a big enough circuit, look on the name plate for FLA, this is the amps it pulls to start up, and size ur circuit for that amount.
Posted on Jan 07, 2009
Compressor starts vary slow and sometimes blows the braker
Hi anthony krim...
You will need to replace your start capicator for the motor, it is faulty
Please take time to rate me
Sep 08, 2011 | Stanley Bostitch CWC200ST 3HP Oil Lube...
Builds up air pressure ,motor shuts down
We are distributors of all plastic materials, including complete fabrication of plastic parts, components and assembles like Acrylic sheets, polycarbonate sheet and UHMW.
1)Turn off your compressor or disconnect the power.
2)Remove the connector tube that sends air to the tank.
3)Remove the head bolts on top of the pump.
http://www.plastic-craft.com/novus-plastic-polish-buffing-kit.html
Aug 09, 2011 | Campbell Hausfeld 04 Gallon Twin Stack...
My compressor suddenly quit cycling what went wrong?
hi there!
there are several factor on cycling failure, most common on it is the pressure switch device,checking on this,plug out or switch off main circuit breaker for compressor, disconnect pressure switch if this is a single phase connection,there are two supply wire coming in and two wire coming out on pressure switch.direct connection of compressor motor on power supply to test if it is cycling manually,after direct connection of motor compressor to power supply w/out pressure switch,switch on for 5 to 10 minutes o build a low [pressure then swict off again,then switch on again even there is a low pressure observe if there is cycling motor running if this done replace pressure switch.if still have same problem motor tripping another case not to cycle bring this to electric motor service center.have a nice day dont forget to fix my rate.
May 07, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
Starts up, runs for 10 seconds sticks and pops circuit breaker
your motor start capacitor on the side case of the motor is bad,get it replaced before you ruin the armature from excessive heat generated from the motor not coming up to speed soon enough and drawing excessive current to try and keep it running
Apr 16, 2010 | Ridgid 17038 4.5 Gallon Oil Free Twinstack...
I have a 33 gallon craftsman compressor model #919.167330. If the air is totally out of the compressor and you plug it in, it will build to full pressure and then turn off normally. When you begin to use...
i think you will find there is nothing wrong with the compressor part of this its all down to a faulty motor
if it cant start up the motor the motor will hum at first then the circuit braker pops out? yes???
check your getting full mains power first as if its trying to run on a very long extenshion lead its not getting the full power to start up, and you will need a much heaver lead,,,if its in a plug on the wall, change the capasitor on the motor,,,this is the part that hold a lot of volts to kick start the motor over when it first trys to start,,if this capasitor has droped in holding its charge there wont be enough volts in it to kick start the motor over,,so the motor starts to hum first trying to start but it dont stand a chance of spinning up
so it keeps pulling more and more amps till the braker pops out,,,watch this capasitor it can realy bite you if you tuch the two ends that are live????
the motor has two windings in it,,a start up winding and a running winding,, if its been humming for some time now it could have damaged the start up winding
Mar 28, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Which air compressor is better-the rigid twin tank or the emglo twin take?
I think Ridgid has now lifetime warranties. You have to fill out papers and mail them. I have a few Ridgid tools and I love them. So check out the Ridgid, you can't go wrong.
Mar 16, 2010 | Ridgid 17038 4.5 Gallon Oil Free Twinstack...
Have rigid twin stack air compressor. Only keeps about 75 psi and keeps running. I do hear air from the exhaust port (seems normal). Haven't used it for a while. Any ideas? Thanks, in advance.
possiably the " reed valves under the head are not closeing off all the way. These may be bent or somehow distorted their tension most of the time from exsesive heat. Good luck
May 18, 2009 | Ridgid 17038 4.5 Gallon Oil Free Twinstack...
Ridgid 17038 4.5 Gallon Oil Free Twinstack Air Compressor Logo
1,935 people viewed this question
Top Ridgid Hammering Experts
Tim Whalen
Hippy_dd
Are you a Ridgid Hammering Expert? Answer questions, earn points and help others
