Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Yellow status light blinking
TV wont turn on yellow light blinking.
  • Anonymous Mar 19, 2014
    wont turn on yellow light blinks
  • 179 Answers
Tour air filter cover door is either not tight, or off, or the small switch behind it is bad. it is on the side opposite the ac plug.
Posted on Dec 29, 2008
4 Suggested Answers
doin12volt
  • 233 Answers
SOURCE: yellow status light
It is doing this because the filter cover on the side of the tv has come loose, or the microswitch that senses the cover has gone bad. It is at the bottom right corner of the filter cover.
Posted on Jan 21, 2009
  • 556 Answers
SOURCE: Solid yellow lamp light AND flashing yellow status light
start with the lamp.
Posted on Sep 21, 2009
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
Mitsubishi WD-73638
lamp is gone needs replacement
Jul 08, 2013 | Televison & Video
Just changed the lamp and the "status" light is
you must install the lamp door after lamp replacement to get the "yellow" blinking to stop. if the status is blinking red then you may be having a fan failure internal to the tv. also make sure that the side filter door is installed and secure
Dec 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Status Light Problem
Is the status light yellow or red? If it is yellow, then check the dust filter cover. That cover might be off or not secure. If the status light is red and blinking, then try unplugging the TV for a minute. If the error doesn't resolve the TV needs service. If it is out of warranty, you might want to open up the set and look for any obvious problems on the circuit boards (scorch marks, soot, bulging or leaking capacitors (look like cylinders on tripods)).
I hope this helps.
Jul 19, 2010 | Mitsubishi WD-62528 62" LCD HDTV
Yellow light keeps blinkingand the tv wont turn on
If the status light is blinking yellow it means the filter cover is open ( On the left side of televison)
If the lamp light is blinking yellow it means the lamp cover door is open. ( Behind front lower panel) If both covers appear intact the switches may be defective or not engaging properly.
Dec 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Solid Yellow light and blinking yellow status light after bulb replacement. TV wont turn on.
Sounds like Mitsu is getting sued left and right about their DLP problems. There is a potential overhaul if you contact their parts department.
Oct 13, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Jul 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
390 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
