Question about Nintendo Wii Remote Controller
Wii controller disconnecting
After setting the controller up on the options page it automatically disconnects itself when you exit. The battery is full and it does it whateer CD is in the WII.
5 Suggested Answers
  • 7 Answers
SOURCE: Rock Band wireless guitar won't sync with Wii
They are not compatible.
Posted on Dec 27, 2008
AegisKay
  • 51 Answers
SOURCE: Wii Fit Doesn't work
Do not stand on the Wii fit board until it says to. The board needs to reset itself before any tests are completed. For best accuracy, complete all the initial tests and follow the instructions to the letter.
Posted on Feb 06, 2009
  • 8 Answers
SOURCE: My second Wii controller does not connect. It used
Have you tried one time syncing it? (By pressing home and then pressing reconnect controllers)
If you have make sure you're not trying to connect it in a single player game. If you do, the second controller will not connect.
Posted on Jul 29, 2009
SOURCE: Wii Balance Board Not Syncing
ahh yes, that happened with me - just press the red sync button on the board first, then the wii - and dont hold it ... if u hold it for 2 long the wii remote is "unsynced"
Posted on Feb 26, 2010
I am using belkin N150. F9J1001v1. WiFi is disconnecting frequently. When I restarting it ,it works again. But 15-30 min again it disconnect. Looks like every time I need to restart the router. advise
1. Try resetting the router. You will have to set it back up after.
2. Update any firmware - go to Belkin's site, or there may be an option in the router's control page/application to check for and apply any updates.
3. The router itself may just be going bad and need replacing. It happens after a while.
Jun 17, 2016 | Belkin Computers & Internet
Adjusting power seats
That is an option that can, is set to fit the drive/ drivers needs of the vehicle..ThIs can be reset.you will need the owners manual to do this..sometimes if the battery goes dead or disconnected options like this need resetting..not an aftermarket that I have heard of..good luck.
Feb 26, 2014 | Computer, Chip, Cruise Control for Honda...
What's your problem? the wii wont turn on
    • 1 Disconnect any accessories, such as GameCube controllers or SD cards.
    • 2 Unplug your Nintendo Wii AC adapter from the wall outlet and from the back of your Nintendo Wii. Leave the adapter disconnected for two minutes. Reconnect the adapter to the console and plug the outlet end straight into a wall outlet, not a surge protector.
    • 3 Remove the AC adapter from the wall outlet again. If the Wii has yet to turn on, the problem may lie within your electrical outlet. Plug a lamp, nightlight or something electrical into the outlet the AC adapter was connected to. If the outlet appears to work, then you'll have to test the AC adapter itself.
    • 4 Run your fingers along the AC adapter cable and visually look for any damage, such as frayed wires or a cracked piece of cable. Also look for the model number "RVL-002" and "Wii" on the adapter. If you don't see the "RVL-002" model number and "Wii" on the adapter, then you are using an unlicensed adapter, which can cause instability and power failure. If the adapter has incurred any damage, you will likely have to buy a new adapter.
    • 5 Spray air to clean out the vents on the back of the Nintendo Wii. If your Wii has been sitting for a long time, then dust and dirt may have built up around the vents, preventing the console from cooling itself. If the console cannot cool itself, it overheats and shuts down.
    • 6 Click "Start," "Internet Explorer" and visit the Nintendo repair page (see Resources) to open a repair claim. If you tried the above steps and your Wii has yet to power on, your system probably needs professional repair.
Oct 05, 2011 | Nintendo Wii Console
I disconnected the wii at the back of the tv and installed a piggy back plug so I could watch my vcr or play wii. Now I have no color when I use the wii although the tv is fine. I removed the piggyback...
Your wii automatically set itself to HD but your tv doesn't support it. You need to change your wii to standard definition under video settings.
Mar 20, 2011 | Nintendo Wii Console
The wii hand is not showing we tried unplugging and plugging back in it will appear very shaky then dissappear. put new batteries in remotes and still nothing
There are a few possible causes for this issue. I'm sure you have tried most of these steps but I'm going to list them any way. So we have a complete picture of the trouble shooting process.
1. Try another controller.
2. Disconnect the sensor bar and reconnect it.
3. Check the sensor bar settings for the wii console. This can be done by clicking on the wii logo at the bottom left of the screen. Then with in the console setting click on sensor bar. There will be 2 options. Above TV and below TV. Verify that the correct setting is chosen.
3. Try your controller on another wii console.
If the above steps do not resolve the issue contact Nintendo directly.
I hope the info listed above has helped in some way.
If possible please rate this solution.
Aug 27, 2010 | Nintendo Wii Console
My compaq evo n610c switches itself on when the
Disconnect the power cable from the Notebook and then remove the Battery pack. While the Battery pack is removed, press and hold the power button on the Notebook for 15 seconds.
Next, reinsert the Battery pack and connect the power cord to the Notebook and turn it ON. While the Computer is booting, you can view the information on the bottom of the screen to get to the Setup Screen.
On the Setup screen, use the right arrow key to highlight the "Exit" menu, then select the option "load/get default" and press the Enter key followed by F10 keypress to reset the BIOS and save and exit the screen.
Feb 26, 2010 | Compaq Evo N610C Notebook
Problems with a Wii game
if you are in the mulitplayer mode and still have trouble adding the remote then try syncing the remote with the wii first by pressing the home button then go into the wii remote settings on the bottom then re-sync each control. Then try going back into mulitplayer mode and try again or while the screen is on when you want to add more players press the '+' button.
Dec 28, 2008 | Video Game Consoles & Games
Turns on all buy itself
dont have it pluged in
May 07, 2008 | Nintendo Wii Console
Nintendo Wii Remote Controller Logo
243 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
