Question about Vizio L37 Television
Cannot hook up DVD and VCR to Vizio 37 inch flat panel 2003 model
I have tried the red, yellow, white RCA plugs and no connect. I have Dish network sattalite service. What cables do I need?
  • gungho31340 Jan 12, 2009
    same as you hookup but no sigal
    Novelist:
  • 152 Answers
Try connecting the output from the sat reciever into the in ant incoming signal of the vcr use the dvd as one of the inputs to the vcr use remote from vcr to switch from vcr to dvd.
hope this helps
Posted on Dec 28, 2008
How can I connect VCR?
Hi if U just want to play videos the easy way is to connect 3 RCA VIDEO CABLES colour coded red white yellow yellow is picture red & white r left & right audio from the output sockets of VCR to input of TV ..then set TV to AV INPUT good luck
Mar 08, 2016 | Vizio M3D650SV 65-inch 1080p 3D LED TV...
I just need a diagram to show me how to hook the dvd/vcr up to my television. I have Dishnetwork as well. I un-hooked and now I can't get a picture.
Not knowing the model of the TV its hard to tell you how to hook it up. Howeever let's assume that yu TV has an auido in and a composite video input. it it does is should have three RCA jacks on the back...one red, one white and one yellow.
Assuming Dishnetwork is being used as a analog video.
Connect the VCR/DVD player via a patch cable ( usually has three cable all color coded, red, white & yellow) Red and White section is used for the audio Left and Right. The yellow cable is video.
Connect the audio out of the VCR/DVD player to the audio input on the TV. Do the same with the videoout of the VCR/DVD to the TV may be marked "Composite Video". Now connect your Dish Network receiver RF Out to the TV. This should be a coaxal cable.
Now when you want VRC/DVD use your remote and select input. Some older TV's have the aux input just before Ch 2. Some remotes have an input button.
once you have aux inpsut selected turn on the dvd and play your movie to view Dish go to Ch 3 or 4 depending on how your TV and system is set up.
Again not knowing the model TV you have, this is a general hook up.
Thank you Let us know if it helps
Tom Miller
Broadcast Engineer
Sep 09, 2011 | Televison & Video
I HAVE DISH NETWORK AND WANT TO CONNECT MY NEW ZV427MG9 A UP TO RECORD A SHOW, ON DVD. MY TV HAS RCA CONECTIONS IN THE FRONT, BUT I HAVE TO BE ON VIDO 4 TO USE THOSE. MY DISH BOX HAS A SET IN THE BACK, I...
you need to hook the dvd recorder up to the dish net work, yellow to yellow port, red to red port, and white to white port.
the dvd recorder should have had a book in with it to show you how to hook it up
Mar 03, 2011 | Philips Magnavox DVD+R/+RW Recorder/VCR
Need instructions to hook up dvd
Check Carefully on the Back on the DVD You will see different color RCA plug yellow, Red and white Input and Output The yellow output from your DVD go on the input TV ...Then the red output go in our red TV input Same for the white RCA plug sample to do ...
Sep 21, 2010 | Vizio VX42L 42 in. LCD TV
How to hook up dvd to tv through dish network box
I do hope that you have gotten this resolved, but if not, here are some steps.
From the receiver box:
You will want to connect RCA (red/white/yellow) from the TV1 slot to the IN on the back of the DVD. You can also use coax, which would then be connected to TV SET OUT on the back of the receiver.
From the DVD:
You will want to have more RCAs going from OUT on the DVD to the TV. Then the TV needs to be on channel 3 or 4, and on an input. Usually Video 1 or 2. The DVD will need to be on whenever you are watching the DISH.
Becki Barned
DISH Network Customer Service
Jun 26, 2010 | Vizio L32 32 in. LCD HDTV
Can't hook vcr to tv
on the back of your VCR there will be a yellow colored port - most likely labeled "OUT" as well as possibly a white/red pair of ports.
The yellow is for a VIDEO hookup, the white and red are for AUDIO hookups.
These ports use what is called an RCA type connection.
Radio Shack, or just about any department store should be able to sell you an inexpensive set of RCA cables.
now on the back of the TV (possibly on the side) you will also have the yellow, white and red ports.
Hook one end of the RCA cable to the colored ports on the VCR, the other end of the cable to the colored ports on the TV.
last thing - the TV most likely has multiple inputs. there is probably a input button on the TVs remote, you need to press that button to cycle through the inputs until you get to the one the VCR is hooked up to.
its easiest to put a tape in the VCR and press play - when you get to the right input, you will see your tape...
good luck
Apr 05, 2010 | Dynex DX-L32-10A 32" LCD HDTV
Where is the output to return to my vcr
the order i normally use for the sound system (if thats what your asking) is run everything including the vcr to the tv then on the back there should be a red plug and a white plug labeled audio out then run that to the sound system any input on the sound system will work long as the colors match and its labeled input...hope this helps!.
Aug 24, 2009 | Vizio VW37L 37 in. LCD HDTV
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
How do I connect my Magnavox DVD/VHS player to my Element Flat screen TV?
Do you have a newer TV or a older one lets start with a newer models does your tv have 3 or more jacks on the back or front you should see a RED, YELLOW and WHITE if you have a HDTV you should see more. (LETS HOOK UP) Did your DVD/VCR come with a cables if not you will need to buy at least 2 they are called RCA cables Lets start with the dvd/vcr combo on the back you should see a (LINE OUT) this is where playback or your picture and sound come out. On the back of the TV you should see a (LINE IN) this is where you plug it in to. RED goes to RED, WHITE goes to WHITE and YELLOW goes to YELLOW. To Record you will need to hook up the line in on your combo and the line out to your tv. ( IF YOU HAVE AN OLDER T.V WITH NONE OF THOSE JACKS ) you will need to buy a RF- MODULATOR the are cheap it is a box that let you hook a cable wire to a little box and the RCA jacks to you combo and you will turn your tv to channel 3 or 4
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Hooking up a d.v.d player to a vcr/tv combo?
RCA plugs (the yellow, red, and white outlets you speak of) consist of a video plug (yellow) and stereo plugs for audio (red and white). Just match the colors from the DVD RCA colors to the RCA hook-ups on the TV (ex. Yellow the Yellow, White to White).
You don't need to worry about the red one, it just makes the DVD player play stereo audio. Instead, you'll have mono, which is fine, and most modern players can detect mono and switch it for you so don't worry about changing settings and what not (unless you're missing sound on one side.)
Sep 13, 2008 | Optical Coating Model 108 VHS VCR
Vizio L37 Television Logo
382 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
