Question about Dynex Televison & Video
Strange channels showing up on Dynex TV
I have a Dynex 22" flat screen LCD TV. There are weird channels showing up on this TV that don't show up on our main TV. We are hooked up with a local cable company and we have our main LG TV hooked up to a digital receiver. The Dynex does not have a digital receiver. I see a lot of strange channel numbers, i.e. 26-13, 6-1, etc. Also, I have noticed that we are getting Pay-per-view movies showing up now and then on some of the higher numbered channels (129-9). We have not ordered any movies and we can only order movies on the LG TV. Any idea what is going on?
SOURCE: Trutech 35" LCD connecting to cable box
The official website for this item is http://1800customersupport.com/trutech. Try emailing them, or call them at 1-888-252-6252. Trutech is the store brand for Target stores. So many companies make their products. This website isn't the official site for all Trutech products,just some of them, like this 15" LCD TV.
Posted on Aug 20, 2007
SOURCE: G-Link
Here is a link to Toshiba support website, looks like it is related to your issue.
http://www.tacp.toshiba.com/resource.asp?resourceid=22
Posted on Oct 31, 2007
bhiga
  • 119 Answers
SOURCE: Only channels 2-13 show on new Dynex 19" LCD TV
You'll need to find the Cable/Antenna setup and change it from Antenna to Cable. Sometimes the setting you want is called CATV.
Posted on Aug 13, 2008
  • 5261 Answers
SOURCE: can't get all digital channels
There are several possibilities assuming you have an outdoor antenna with the amplification. You are too far from the transmitter or the station is still on a low power digital transmitter until the analog broadcasts end. Additionally, there may be buildings, hills or trees in the way. The first one is called the digital cliff - you either have enough signal for your tuner or you don't. Some stations may need to add transmitters to cover the secondary areas that could still receive the analog signal. The second possibility will either resolve on Feb 18 or June 12 or anywhere in between. (It will depend on your station and the Digital TV transistion delay bill. Some stations are changing frequencies with the transistion and can't go to full power until another analog station moves its frequency.) The last one can't be resolved.
If you have an indoor antenna, you can try moving it around to get better results. My household has an amplified outdoor antenna with a rotator to get the antenna to line up with the signal. We have two analog stations that give problems when we look for their digital signals. We hope the issue will resolve with the changeover since we have seen the signals on both stations improve when they wanted to broadcast football games.
Posted on Feb 07, 2009
SOURCE: I need to hook up to digital cable
Thank you for your time.
I turned on the router supplied by Verizon, which I did not do yesterday, I'm embarrassed to say....
I called Sanyo and received step by step how to set up.
It was the same procedure I used yesterday with the exception of making sure the router was on,
I apologize for any inconvenience.
Reva L,
Posted on Apr 02, 2009
Dynex TV came on black and the buttons aren't working?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Dynex Televison & Video
Dynex 19 inch lcd tv does not show picture standing up but will show it laying down
check the ribbon cable that connects the screen to the mainboard may have a loose connection
Feb 02, 2013 | Dynex DX-LCD19-09 19 in. LCD TV
A BOX WITH THE FOLLOWING INFO KEEPS POPPING UP ON THE SCREEN: 480P SD, HOWEVER I HAVE A 1080P FLAT SCREEN. IS THIS A CABLE ISSUE OR A DYNEX ISSUE?
It is most likely a cable issue. If you have a 1080p television your tv might be trying to communicate with your cable box. If your cable is broadcasted in standard definition that message can show up. I would recommend checking with your cable company and see if you have HD channels or not.
Aug 01, 2012 | Dynex DX-L42-10A 42 in. LCD TV
Envision flat screen tv has 5 channels that don't play volume but show pic
Check the volute settigs to these channles. Check whether system set is compactable with input.
Feb 04, 2012 | AOC Envision L32W461 32 in. LCD HDTV
Dynex 22 tv has sound no picture
Power supply caps or backlight inverter! Common issues with LCD flat screens for some reason.
Dec 28, 2011 | Dynex DX-L22-10A 22 in. LCD TV
DX-L22-10A quickly shows "please wait"
Contact DYNEX for assistance (Mexico) Be patient...(siesta time...) They will talk you thru a RESET !! (I hope...)
May 03, 2011 | Dynex DX-L22-10A 22 in. LCD TV
My screen is all white with channel showing
Hi, are all the tv inputs displaying the same white screen, ie, when you plug in a dvd player of games unit etc to one of the scart sockets? cheers George.
Nov 03, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Aug 12, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Televison & Video Logo
93 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
