Question about Hotpoint 24 in. HDA2020Z Built-in Dishwasher
Glasses on top shelf
My glasses always have a gritty feeling on them like bits of dried food or particles were left behind i use electrasol 3 in 1 tabs should i use something different ? what do you recommend ? any suggestion would be appreciated thank you
  • golden bear Feb 29, 2008
    crosley mod.cdc5j
    grit baked on glasses at the end of cycle
    President:
  • 1,462 Answers
Possible grit you are feeling is from the water softener breaking down. the softener contains a brown resin. this ofted happens if you have connected supply to hot water. best connect to cold
Posted on Apr 27, 2007
  • 247 Answers
Apart from Tresilla's suggestion, you might also check that: Filters and strainers are clean Upper spray arm is clean (take it off and wash it through to make really sure) Upper spray arm is free to turn (if you jam it by putting too-large itmes in the lower shelf, you will almost always get the symptoms you describe). Upper spray arm is on the right way up (I'm the only person I know who's put one on upside-down, but gess what the symptoms were). If this is one of those machines where the upper spray arm is attached to the upper shelf, and fed through a vertical telescoping tube, make sure the tube telescopes freely. A.
Posted on May 01, 2007
My maytag W10199645 is leaving gritty residue on my mugs & glasses. how can i troubleshoot this?
Try using a dishwasher cleaner. You can get it at any supermarket that sells dishwasher soap.
Nov 06, 2014 | Maytag Dishwashers
Siemans dishwasher model SE55A560GB/42. Upper rotating spray bar not turning but botton spray bar is rotating. Dishes are left with a gritty feel to them.
Check that the arm rotates freely when spun by hand, then check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Apr 13, 2011 | Dishwashers
Built in machine - top shelf only - cups tea-stained, dried on particles of food
Check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Feb 13, 2011 | Whirlpool 24 in. ADG7540 Built-in...
There is so much debris left on the dishes after the dishwasher has run, it's almost not worth running it. The debris is mostly small hard bits on the inside of glasses from the top shelf. Is this a...
this is a maintenance problem.. if the bits look like grains of sand it is actually food particles that breaks down during the cycle spraying the cups and glasses (usually the top shelf that gets hit worst). solution is to run a dishwasher cleaner through the system on a hot wash. To remove and wash bottom filters and spray arm jets. Lastly when loading the DW make sure excess food are scraped/rinsed off ...you will get better results. Thanks
Jun 22, 2010 | GE Dishwashers
The dishes/glasses on the top shelf are not getting clean
Here is a link to a procedure I put together to clean out your pump. A plugged up sump is the most common reason for poor washing on the upper rack.
Let me know if this helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 30, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Small food particles getting stuck
Check your drain filter and clean them. refer user manual for location
Apr 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Food remnants left on top rack of glasses and ceramic mugs.
Before loading into the machine clean the particles that are sticking to the dishes.
Check the drain filter at the bottom rack and clean. It is user cleanable
Apr 06, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
A gritty feel is left on glasses and some dishes
Hard water! Try Cascade Rinse Aid.
Mar 25, 2009 | Dishwashers
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
Smeg dishwasher
riff...not sure what the bits are...first, they may be food crumbs or the like. Dishwashers have macerators to grind up food particles but they have no really good way to get rid of them in the wash cycle. Scrape plates of any solids before loading them. If the material is shaped like water droplets, you may have hard water stains. Use Jet Dri or a cleaning product which claims to help and use the amount specified. Your water temp may be low...it should be 125F or better. If you can run the hot tap and put your hand under it...it isn't hot enough. You can also use the heated water setting to deal with this.
Dec 11, 2007 | Smeg DWI614 Built-in Dishwasher
Dishwashers Logo
197 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Jim Goldsmith
Jim Goldsmith
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
