Question about Apache Colco Ah 64 Longbow R/C Helicopter
Gyro LED will not stop flashing
After I connect the battery to the flying unit, i here a mechanical whir for 1/8th of a second, then the GYRO LED flashes, and never becomes a solid light to allow it to fly. I have been trying for awhile to get it working, trying various startup methods, but the light never becomes a solid light. Is there anything I can do?
I had the same problem. The problem eventually turned out to be a bad connection to the antenna inside the controller. That was one of my first checks trying to trouble shoot it and it seemed tight. I got some replacement parts, changed the receiver but that wasn't the problem, I changed the antenna and it started to go intermittent. I put the old antenna back on and the connection inside finally had worked loose. So I tightened it back up and it has worked perfect ever since with original parts. So I suggest you completely loosen the antenna connection then tighten it back up again and try that.
Posted on Jan 24, 2009
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
Front led light just blinks
Make shure transmitter is on and ready BEFORE powering heli and let rest the heli without any mouvement while and after powering up ( gyro setup ). Receiver maybe need to be bind for it to work, look for binding procedure in manual.
Nov 24, 2013 | SWANN Micro Attack Military Blue Gyr
My new MJX F645 won't fly
Does it power up and the main rotors spin? If you have no power it could be a faulty battery.
Kind regards, Julian
rccontrolfreak.co.uk
Nov 05, 2013 | SYMA Toys industrial Syma S032 Ready to...
No power
Check the channels and make sure your on the right channel A / B usually..
give the blades a gentle turn with your fingers, they stick sometimes.
Dec 28, 2012 | FocalPrice BR6008 3.5-channel Infrared...
How to replace s032 tail rotor
Look at this posting. Should help ya. I am looking into a similiar issue with my tail rotar. :) Once I find out more info, I will update if I get any different answers. ;)
Posted by avatar3.jpgtom_howar714
how to replace rear rotar
Feb 07, 2012 | SYMA Toys industrial Syma S032 Ready to...
My helicopter (SO32 Gyro) having previously worked perfectly now will only hover. I have tried recharging it but it makes no difference. I wonder if I have overcharged the battery and if it is possible to...
Batteries are available online (amazon and many others) and change easily with only small screwdriver. Overcharging is not the issue. Nearly impossible with PCB (overcharge prevention circuit) hard wired into battery AND in charger. Problem is likely UNDERcharging, overDIScharging, or improper battery care. Battery MUST be allowed to cool 10 minutes after flying. Charge until light on charger doesn't get any brighter when helicopter is unplugged... light comes on (dim at first) well before full charge. 10 minute cool-down after charge also a MUST. And, most important, when flying, as soon as you are unable to maintain altitude, land helicopter and power it off. Li/Po batteries should never be fully drained. Even one full discharge can cripple or ruin entirely your helicopter's battery.
hope this helps.. let me know,
r
Feb 27, 2011 | SYMA Toys industrial Syma S032 Ready to...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
I just got an r/c helicopter ( gyro s032 ) i've just tried it once but then i tried charging it for second run, but when i plugged the charger cable in the helicopter. It din't want to charge,i looked,and...
couple of things possible. 1) change outlet. 2) call customer service for the helicopter (should be on manual in contact section) 3) the helicopter has a loose cable connected to the battery inside the helicopter so you probably need to sodder it.
Dec 26, 2010 | SYMA Toys industrial Syma S032 Ready to...
Just got the syma s032 gyro charged it to full and it wont fly for more than 20 seconds
So your only getting 20 seconds of flight time when your charging for a full cycle?
I purchased the Syma Chanook and it had the same problem , If you keep running into this problem using the remote control charger than I suggest to aquire a new charger . One that is a plug in the wall . I really dont like to rely on the usb chargers they just dont work as well. If not you still have a 30 day moneyback warranty and I would make them replace the battery or better yet the whole unit if the second charger doesn't work!
Dec 24, 2010 | SYMA Toys industrial Syma S032 Ready to...
I can't fit back together my gyro brake system on my gt fly 2007. is there an instruction manual available please?
http://www.bmx-zone.com/en-article-id-931.html
Try this link. I'm putting mine back together after stripping and repainting the frame. I consider myself mechanically inclined but this is a confusing set up! My problem is that the kid I bought the bike from had it set up incorrectly?? I hope. because from what I can tell, the bottom plate should directly contact the frame, thus i need to remove the headset, install the bottom plate (which says odyssey gyro) and then tap the headset back into place. from there, install top bearings and refer to the picture in the link. I'm doing some research to figgure out what the hell I am doing wrong, and why cant I figgure this thing out!! I think I have it, gonna try again tonight. SO if any of you ppl who have actually installed these things correctly notices that this is incorrect, please inform us! Hope this helps!
Mar 14, 2009 | Odyssey Bike Bmx Gyro 1 1/8 " Rotor...
Apache Colco Ah 64 Longbow R/C Helicopter Logo
396 people viewed this question
Top Apache Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Apache Toy Expert? Answer questions, earn points and help others
