Question about Panasonic Lumix DMC-TZ3 Digital Camera
Doesn't power up. Lens cover doesn't open, lens doesn't open
I've tried charging the battery and reinserting it. Then I go to put the carera ON and the lens cover does NOT open and the lens does not expand. So, naturally I can't do anything from that point on. THANK YOU
Well, I'm not sure if I can solve it but I did have a similar problem with my out of warranty TZ3. One day it just died - wouldn't power up, no display, nothing. I tried changing batteries, re-inserting them, recharging, checking contacts but to no avail. Nothing. I did some research online and found that there were a few others out there with the same problem and the fix was basically to throw it away and buy a new camera. The cost of having digital compacts professionally repaired these days is such that you may as well spend a little bit extra to get the latast model.
That being the case I figured I may as well dismantle it and see if there was anything obvious that I could do. It's not that difficult and if you are reasonably careful and comforable with components and printed circuit boards you won't have any problems. It turned out the problem with mine was one of the ribbon cables that connnects to the PCB that runs along the top of the camera - the connector is just below the on/off switch. It had come partially detached from the connector. I re-made the connection, re-assembled the camera and it all worked perfectly. And the good news was there were no components or screws left over - amazing.
More good news - I saved myself a few hundred dolllars. The bad news, I don't get to buy that TZ5 that I had almost justified purchasing. Good luck. If you need help dismantling the camera the service manual at http://tsn.pasc.panasonic.com/viewing/ALL/DMC-TZ3P/SVC/DSC0703019CE_PRINTB/DSC0703019CE.pdf
should help.
Good luck
Posted on Dec 29, 2008
My Sony DSC-S700 froze with the lens open yesterday while I was taking pictures. I took the batteries out and put them back in but it would not turn on. I went home and charged the batteries and it still...
The lens can become bound by grit and dirt, it can be off its tracks, or it can be sitting crooked due to dropping it or rough handling. First make sure you have a fully charged known good batteryc:%5cusers%5charry%5cappdata%5clocal%5ctemp%5cmsohtml1%5c01%5cclip_image001.gif in the unit and it is turned off. Plug your Audio/Video cable into the camera. Lay the camera down on its back on a firm smooth surface. Press on the shutter button with one hand and while holding it down turn the camera on. If the lens becomes free, immediately point the lens down toward the floor and use the zoom to zoom it out. Take a soft brush, such as an art brush, and brush around the base of the lens to make sure you have removed any sand, dirt, etc. from the crevice around the lens where it enters the camera body.
If that doesn't free the lens there are a couple of other things you can attempt, but these may damage the camera too. If the camera is going to be tossed in the trash if it doesn't work try these two steps.
1. Take the battery out of the camera. Grasp the camera by the edges of the top and bottom with the lens facing downward. Cup your other hand slightly and smack the face of the camera into the palmc:%5cusers%5charry%5cappdata%5clocal%5ctemp%5cmsohtml1%5c01%5cclip_image001.gif of your cupped hand several times. Reinstall the battery and try the camera.
2. If step 1 didn't work, look closely at the lens seating in the camera. See if the gap around the lens is even all the way around. If it is not, take a thin tool of some sort that will fit into the gap at the narrowest point and softly pry the lens slowly toward the widest part of the gap. If the lens is off the pins, sometimes that will snap it back on. If you hear a small light snap. reinstall the battery and try the lens. If it works, point it face down and run the lens in and out several times using the zoom.
If this doesn't work, and again, ONLY if the camera is going to be trashed if you can not fix it, try prying the the lens out forcefully, but gently. This has worked as a last resort many times. Good luck.
Aug 22, 2012 | Sony Cameras
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
Some how my Samsung SL820 digital camera's shutter door got stuck and it is not closing how many ever times I try to switch the camera off and on. Because of this the camera doesn't work. I've...
Did you happen to drop it accidentally? Or accidentally applied force into your camera? If yes, then there is big chance you will gonna have to replace the whole lens! If not, then it might just be dirt stuck inside your lens mechanism. To fix it, hold your camera with the lens facing the ground. Then, tap your camera repeatedly. Start with light tapping to moderate. If that doesn't work, spray condensed air directly into the lens part of your camera.
Sep 21, 2011 | Samsung SL820 Digital Camera
My screen is blank can not see anything
do you have the lens cover open? do you get any error code or warning message? do this: make sure you have fully charged battery. close the lens cover.make sure cam is off.open lens cover by sliding it down until click is heard.if no go.close lens cover.make sure cam is off.remove the battery from cam for at least 15secs.reinsert battery.open lens cover until you hear the click.if no go try this. can you see the operational buttons and icons on the screen? if you do try to initialize the camera. touch HOME ->settings (looks like a toolbox icon) -> Main Settings (touch OK) -> [Initialize] -> [OK]. if it doesn't work service might be required.thanks :)
Mar 19, 2010 | Sony Cyber-shot DSC-T9 Digital Camera
Lens not going in & getting stuck
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Samsung S760 Digital Camera
Lens do not come out
TIPS:
..to fix this...
Do as i say..
1.) Remove battery
or...
or...
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 26, 2008 | Canon PowerShot S70 Digital Camera
Lens cover error
TIPS:
..to fix this...
Do as i say..
1.) Remove battery
or...
or...
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
Jun 17, 2008 | Nikon Coolpix S1 Digital Camera
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
Camera doesn’t start
The only solution that I found is to take off the battery from camera. After I reconnect the battery, the camera starts without any problem (lens are moving, LCD is on, AF is also on). The battery status is full.
Sep 12, 2005 | Samsung Digimax V5 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
364 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
