I found this manual just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
That could be a number of things. Too much heat inside welder could also do this by creating more resistance in your leads. The easist place to start would be to take the cover off your welder and blow all the dust off your electronics so it has a way too cool properly. Make sure all power is disconnected before attempting this. Try this simple fix first. Any welding machine on the market can benefit from this simple preventative maintenance!
if you disasembled the phone to clean it, check the flex cable and see if it is all the way on, also use some epc (electrical parts cleaner) on all the contacts including the male and female ends of all the flex cable. this promotes proper connection of contacts. just be sure to completley blow dry it before sending a charge through the circuitry
you can delete the handset in the menu and go through the hanset registering with the other base as per the normal instructions (available on the Philips website).
HELLO . AM JAMAL FROM SYRIA , I VE THE SAME PROBLEM WITH THREE PREVIOUSLY USED XALIO 300 WHICH I BOUGHT FROM SOME BLACK MARKET. I SUGGEST U TO INSERT THE CODE ACCORDING TO UR COUNTRY , FOR EXAMPLE :
PRESS FIRST " R " BUTTON THEN 99 THEN " RC " CODE WRITTEN UNDER BASE UNIT THEN " R " OR " PAGING " AT THE LOW RIGHT CORNER OF HANDSET .
