Question about Xerox DocuColor 12 Color Copier
Docucolor 12 Power problem
Why does my docucolor has no power at all? Also, why does the docucolor 12 have waste containers for the developer and toner and the docucolor 2045 on has it for the toner?
  • howsimple Dec 28, 2008
    It is a docucolor 12. Does the trip switch say 20amp? I see a black
    switch at the bottom left corner. Yes, this works because I get a
    reading using my voltage meter going to the boards. Exactly, where is
    the power supply box? I would like to check to see if it works?
    By the way, I would like to know why they work different, if you don't
    mind. From what I understand, the docucolor 2045 does not have a waste
    container for the developer is because it has 4 different print
    cartridge that can be recycled and the docucolor 12 has one. If you use
    one, then the toner gets mixed and needs to be replaced much more
    often. Is this right?
    Thank you!
  • 62 Answers
Check the fuse in the plug, 13 amp, the trip switch on the back of the machine, if not then its probably a power supply problem on the machine. you dont actually state the docucolour which has this problem.
Also as for the waste containers, why do you want to know about something that is a given. The answer is they work differently, if you really want to know about the inside workings i will tell you but you will be bored
Posted on Dec 28, 2008
  • 4 more comments
  • oooimstuck Dec 29, 2008
    The power supplys are at the bottom at the rear of the machine. the Low voltage is on the right hand side as you look at it from behind. The AC power supply is on the left. If the power saver light is on when you switch the machine on it is the Low voltage. It is very very rare to have an AC power supply problem, not that it hasn't been done i suppose. Check the voltage that is going into the low voltage ps and see if anything is coming out. If there is nothing going into it then it is the ac ps.
    The DC12 and 2045 are built entirely differnetly. One is designed for speed and production. You have 4 seperate drums sitting inside the Developer housings. This means that the drive for both the drive and developer are in line for each colour. This also means that the waste for each is in the same line for each colour. The waste container at the back is an accumulation of developer and toner waste. On a dc12 these drives are completely seperate, and the waste for the developer just happens to run to the front of the machine.
  • oscar melendez Sep 30, 2010
    where is the 13 amp fuse ?
    where is the 13 amp fuse?
  • oooimstuck Oct 01, 2010
    in the plug!
2 Suggested Answers
  • 8 Answers
SOURCE: Docucolor 12
The 2045 has a toner and Dev collection as dev ages ist looses its ability to charge and discharge and is then deposited into what is called the toner waste container. It has a different name but serves the same purpouse. TO answer the Question on the no power somemore info is needed. When you turn on the DC12 can you hear the fans run? do your hear any other noises when you turn your unit on??
Posted on Jan 02, 2009
Faded yellow printing on docucolor 12
As long as the problem it's only on yelllow, first of all you must check the max setup (on service menu) and later check the developer, developer unit and the developer bias.
May 16, 2014 | Xerox DocuColor 12 Printer
9-357 problem
Hi there! The Black Toner Dispenserof your machine is broken. Please check the following
1. The Toner Dispenser Motor located at the back of the Toner Cartridge Housing Assy (Behind Black Toner, larger Motor at the top)
2. Black Toner Dispensing Auger set located just below the Toner Cartridge.
3. The Dispensing Assembly behind the Developer Waste Container.
Regards
Apr 27, 2011 | Xerox DocuColor 12 Color Copier
Which toner Dry Ink Waste
The dry ink waste container is located behind the front panel in the lower left area. Only the handle shows, it is about 18" long.
The other waste container that is clearly visible when you open the front panel is the developer waste container.
Apr 12, 2010 | Xerox DocuColor 12 Printer
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
DOCUCOLOR 12 NO POWER UP
Hy, your dc 12 has a problem whith the ac driver pwb is the one with some relays on it close to the lvps pwb. The reley who have to mantain the current flow to the lvps is brocken. That is the solution.
Apr 19, 2009 | Xerox DocuColor 12 Printer
Docucolor 12 Problem
You can find the POWER SUPPLY box at the bottom right corner on the right side of DC12.
Dec 28, 2008 | Xerox DocuColor 12 Color Copier
Docucolor 12
Error code 9 - 358
Hi,that means ,cleaning auger is stopped.Probably toner waste container is full.Try to remove and replace waste toner container(or vacuum toner from container).
BR
Feb 20, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Color Copier Logo
160 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
