Question about Smeg 24 in. DWF612SS Free-standing Dishwasher
Water pump out malfunction lights flashing on new SMEG DFC 612 S
We have just bought a 24in freestanding SMEG DFC 612S dishwasher. We have connected it up and we have checked that the water inlet pipe and oulet pipe are not blocked. However when we start the machine it appears to start but after about 30 sec the water pump out malfunction lights start flashing. The manual suggests checking the siphon but we are not sure how to do this. Please advise
3 Suggested Answers
zeusfaber
  • 247 Answers
SOURCE: smeg dishwasher
The second problem is almost certainly a symptom of the first - leaking water is reaching some of the electrical terminals and shorting them to earth.
First thing to do is to make sure the strainer in the bottom of the cabinet is clear - if it's really badly choked, you can brew up quite a spectacular flood.
After that, best I can suggest is to move the machine onto a piece of dry carpet, run it for a short while and see whereabouts the carpet gets wet first. Use this to guide your subsequent leak-hunting.
If there's any hint that the leak is from the front of the machine, check the seal between the lower edge of the door and the bottom of the washing chamber. On some machines, this gets covered with a thick layer of hardened grease (which is fine, until bits of the grease start to break off). If this is your problem, scrape the remaining gunge off, give the metal surface a good clean,and expect the last vestiges of the leak to cure over the next couple of washes as the seal recovers its proper shape.
Next thing to look for is the device which senses when the machine is full enough (and tells it to stop filling). Let the machine get to the stage when it is leaking nicely, then turn it off, open the door, and see if the cabinet has filled to overflowing. If it has, then drain it, then unplug the machine and take the back cover off. Look for a thin hose coming out the bottom of the washing chamber and running up to a small unit mounted on the case some way up with a pair of wires going to it. Check this hose for cuts, splits and blockage.
If the leak is coming from further back, then you are going to need to look inside to see how much of the inside of it is wet. Use this to guide you to where you need to do a more detailed inspection.
Check all the nearby hoses, looking for splits - especially where they push onto fittings, cuts (especially anywhere they're pulled over sharp edges) and just generally to see if they've pulled off completely.
Next, check any plastic fittings in the area to make sure they haven't cracked, and look to see if there's any evidence of water seeping out of the joints between the different fittings (in case you've blown an O ring, rotted a gasket away, or just had some screw work loose)
A.
Posted on Apr 13, 2008
SOURCE: Smeg DI 612 C Domestic Dishwasher
I was told by a SMEG engineer that I needed to replace the detergent dispencer. Just waiting for him to get back with a new one.
Posted on Sep 06, 2009
My smeg Module DF 612 SDX7 dishwasher tripped the circuit last night early into its cycle. We could smell burning coming from the dishwasher. Any ideas and what we can do to fix it?
If you can get it to operate for a few seconds, that will at least tell whether the motor is still good and turns freely. Otherwise it sounds like board may have failed.
Jun 21, 2015 | Smeg Dishwashers
Error 8 light on. I think all lights flash, then far right light stays on. Recently had issues with it. Not emptying properly. How do I fix it??
6. Troubleshooting
In case of a malfunction, the dishwasher will identify the program by switching on a combination of lights.
When an alrm is present, all the PROGRAMS lights (4) come on, while the PROGRAM PHASES lights (7) identify the error code:
E2
The system which limits the water level inside the dishwasher (safety unit) has been tripped.
E3
The appliance is not able to pump out the water.
E4
Temperature sensor disconnected.
E5
The appliance is not able to take in water.
E6
The appliance is not able to pump out the water from the tank.
E7
The appliance is not able to measure the amount of water loaded accurately (on models with turbine flow-regulator only).
E8
Anomaly in the system which distributes water to the basket (where installed).
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
The anti-flooding system (if installed) has been tripped.
The maximum level of water for loading has been exceeded (on models
Jun 02, 2015 | Smeg 18 in. DWD409SS Built-in Dishwasher
Error 8 . How do I rectify it?
6. Troubleshooting
E2
E3
E4
E5
E6
E7
E8
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
Thjere is something wrong with the distribution. Check for blockages.
Code troubleshooting
White knight dishwasher flashing red light and. Won't. Empty .
could be something in drain pump need to bail the water out of dishwasher best way is a small scoop take filter out and you can get to the lowest point of sump. Take water out and use sponge for the dregs . Un plug appliance and turn water off remove inlet hose and waste pipe. Lay the appliance on its back and remove the base of the appliance you will then see the drain pump remove 3 screw and gently remove pump head and remove object but watch finger if it's a shard of glass .
Jul 15, 2014 | White Knight Press DW1260WA 600 mm White...
Smeg D1 612 CA dishwasher wont run
You may have to give a little more information.
Have a look at the manual, here -
http://www.manualslib.com/manual/343502/Smeg-Di612ca.html
and check for error codes/lights etc (p17; faults E1-E9)
Hope this helps
Oct 28, 2013 | Smeg Dishwashers
Aug 15, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
Smeg dishwasher
You don't say what you're missing. Smeg maintains websites with contact info to get what you need. www.smeguk.com is in the UK.
What you should generally have is all sliding racks and a utensil holder. Included should be a drain hose and a manual. If a door panel is interchangeable, that is usually bought separately. Water inlet fittings are not included and neither is an exhaust drain connection.
Dec 03, 2007 | Smeg DWI614 Built-in Dishwasher
Open Questions:
Smeg DWF612SS leaking & not functioning The dishwasher seems to attempt to run program's as normal but after a few minutes when the water is supposed to start spraying around inside, there is only a humming noise and no water seems to be coming in to the machine. Also, a small leak of water is coming out of the bottom of the machine. I have removed the covers and laid the unit on its side and it would appear that water is coming out of the salt reservoir/ water softener unit. I can see no other visible problems and no evidence that the water inlet pipe is not functioning and I have ensured that the drain is working normally. What I can see is that there is a darker, coppery coloured content inside the water softener reservoir, alongside the fresh new salt I put in this week. But right at the bottom of the white salt appears some grime or grit. Up on the Side, in the water softener tank ( the complex routed flat shaped tank), there appears to be a white calcified surface on some of the channels and there is water high in the tank which appears to be blocked by the calc deposits. So I can imagine if water pressure is being pushed into this whole system and water is unable to flow, then the whole reservoir will begin to leak. Do all of these components need replacing or can I remove them and maybe wash out with some mild acid to remove the offending calc? Or am I barking up the wrong tree altogether? One concern is that if I remove these parts then I may damage other seals. Help/ advice would be very welcome, thanks.
Feb 28, 2017 | Smeg 24 in. DWF612SS Free-standing...
See all Smeg 24 in. DWF612SS Free-standing Dishwasher Questions
Smeg 24 in. DWF612SS Free-standing Dishwasher Logo
239 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
