Question about Xerox DocuColor 12 Color Copier
Docucolor 12 Why does my docucolor 12 has no power at all? Also, why does the docucolor 12 have waste containers for the developer and toner and the docucolor 2045 on has it for the toner?
  • howsimple Jan 02, 2009
    There is no noise at all, however I get a reading of 120V coming out to the machine. Do you know what it can be?
    Problem Solver:
  • 8 Answers
The 2045 has a toner and Dev collection as dev ages ist looses its ability to charge and discharge and is then deposited into what is called the toner waste container. It has a different name but serves the same purpouse. TO answer the Question on the no power somemore info is needed. When you turn on the DC12 can you hear the fans run? do your hear any other noises when you turn your unit on??
Posted on Jan 02, 2009
9-357 problem
Hi there! The Black Toner Dispenserof your machine is broken. Please check the following
1. The Toner Dispenser Motor located at the back of the Toner Cartridge Housing Assy (Behind Black Toner, larger Motor at the top)
2. Black Toner Dispensing Auger set located just below the Toner Cartridge.
3. The Dispensing Assembly behind the Developer Waste Container.
Apr 27, 2011 | Xerox DocuColor 12 Color Copier
Which toner Dry Ink Waste
The dry ink waste container is located behind the front panel in the lower left area. Only the handle shows, it is about 18" long.
The other waste container that is clearly visible when you open the front panel is the developer waste container.
Apr 12, 2010 | Xerox DocuColor 12 Printer
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
9-xxx Codes are all Xerographic problems such as toner problems, developer problems, Drum Cartridge problems, ADC (Auto Density Control) problems too.
Aug 12, 2009 | Xerox DocuColor 12 Printer
Prints aren't plain, it have some texture like crayon
its problem of toner
its of good quality
and also check proper supply of toner into develper assembly
trying to add some extra ink directly in developer assembly
if problem solve
cartridge motor running
and supplying toner proeprly
May 24, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 Problem
You can find the POWER SUPPLY box at the bottom right corner on the right side of DC12.
Dec 28, 2008 | Xerox DocuColor 12 Color Copier
Docucolor 12 Power problem
Check the fuse in the plug, 13 amp, the trip switch on the back of the machine, if not then its probably a power supply problem on the machine. you dont actually state the docucolour which has this problem.
Also as for the waste containers, why do you want to know about something that is a given. The answer is they work differently, if you really want to know about the inside workings i will tell you but you will be bored
Error code 9 - 358
Hi,that means ,cleaning auger is stopped.Probably toner waste container is full.Try to remove and replace waste toner container(or vacuum toner from container).
Feb 20, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Color Copier Logo
170 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
