Wired optical notebook mouse
Stops and starts. Works ok on the desktop
    Problem Solver:
  • 17 Answers
This is most likely a problem with the USB port you are plugging it into or a problem with memory - you could just be running too many programs simultaneously which causes everything to lag.
If it is a problem with your USB, try all other USB ports on your computer. If none of your USB ports are working and you have determined that it is not because of other problems like memory, you can get external USB expansion ports, which would plug into other ports on your computer.
To check if you are using too many programs, press ctrl, alt, and delete simultaneously to bring up the task manager. Click on the the Performance tab which will show you the usage of your computer's resources. If CPU usage or Physical Memory are near maximum capacity, you should click the Processes tab to see what programs are running and see if there is anything you do not need which can be shut down.
Another good tip to reduce memory usage is to download the free program Spybot Search & Destroy, which finds and removes harmful spyware, which can endanger your privacy as well as slow down your computer.
Posted on Dec 29, 2008
Wired mouse sometimes lights up but even when it does it does not work pointer
These optical mouse do not work on a shiny surface. Try using it with a mouse pad or place the mouse on a piece of paper.
Nov 27, 2012 | Gateway USB Optical Mouse MOAKUO 7010867R...
Microsoft wireless optical desktop 1000.....keyboard wont type
then it is the problem of driver so reintall the it
and you can check the batteries for replacement
Sep 11, 2009 | Microsoft Wireless Optical Desktop 1000...
Microsoft Notebook optical mouse 3000 not working
Have you tried changing the port in which the USB wireless receiver is plugged?
Or is the receiver internal to the notebook?
If the receiver is internal, try updating the drivers for your machine by navigating to the manufacturer's support site.
If you plug a wired mouse into the machine what happens? If you get the same result, it may indicate a problem with the USB settings on your machine. I would, again, suggest updating the drivers for your machine.
If that's the case, try plugging another USB device into the machine and see if it works properly.
If none of those options provide results, I recommend you return the mouse for a refund or a replacement, especially if you have the receipt.
I hope I was able to help you. Good luck!
Aug 08, 2009 | Microsoft Wireless Notebook Optical Mouse...
Can I use a new MS wireless mouse to replace my existing MS wireless mouse. Currently my mouse and keyboard connect together on the same wireless USB device. Could the new mouse be detected and be used...
I suppose there is a reset button on the keyboard or the software provided so I suppose it could be possible, I don't know.
I use a Microsoft Wired Keyboard...
But Best of luck.
Jul 21, 2009 | Microsoft Wireless Optical Desktop Pro +...
Mouse works perfecly well for couple of minutes then stops.
try a new batteries most likely it is the batteries and sorry to hear about this issue
Apr 15, 2009 | Microsoft Wireless Notebook Optical Mouse...
Optical mouse stops working then starts again
Hello faust_4456,
Make sure that the mouse is secure in the USB socket also check the cable to make sure it is not damaged, also in your BIOS make sure that the USB ports are enabled on system boot up so that the BIOS loads its information into the Kernel rather then the OS Drivers loading the USB information at OS boot-up. This has helped me avoid a lot of USB issues.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 28, 2009 | Samsung Pleomax PKB-7000X
My computer will not go into standby mode when I'M using MS Notebook Optical Mouse 3000. I use WinXP.
cuse mouse dontlike standy by mode sum mouses cant do it unless u manaual config deep inside windows to make it under vista avacaed powerr ocntrols xp ect if avb u do not wnan sleep a not book u wann shut it down never sleep a notboook over night always shut down use on hard surface ok or else heat kill it
Oct 07, 2008 | Microsoft Wireless Optical Mouse
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
