Question about Roper RGX4634KQ Gas Dryer
Dryer tumbles, no heat
MODEL: RGX3514PQ0- i need to find where heating element is located on my Roper gas dryer... HELP !!!!
  • jonn2121 Feb 19, 2009
    Roper gas dryer model RGD4440SQ0 dryer tumbles with no to little heat have to dry load 3 to 4 times to get it done
  • 640 Answers
Its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Posted on Dec 28, 2008
My Roper dryer, model RED4100sq0, will tumble but not dry. Also, the timer does not run so the dryer runs continously after starting. There is no heat from the element. Both of these problems started at...
I fixed a roper dryer with a no heat problem and I did a youtube video you can google Roper Dryer no heat if my movie does not show but I gonna post it for you.
Sep 30, 2013 | Roper Dryers
MY Roper Dryer model # RED4340SQ1,Will Tumble but not Dry Clothes
For this job, all your work is going to be behind the machine. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced
Apr 25, 2012 | Roper REX4634KQ Electric Dryer
I have Roper Dryer model RED4340SQ1,SER -MU1914782,it will tumble but no heat
For this job, all your work is going to be behind the machine. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced.
I have a roper gas dryer and have replaced the thermal fuse twice, the dryer will heat and dry a load of laundry and then next time i try to use it the dryer doesnt heat what else could my problem be???
Hi
If your dryer is not heating, then check if the power cord is plugged into the wall. It may be loose or disconnected. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working. Now, check whether the heating element in your gas dryer is burned out by using an ohm meter to check for continuity. If the continuity is not there then you would need to replace the element. After checking the element, check out the thermal fuse to see if it's burned out. The thermal fuse is attached to the exhaust duct on the back panel of the gas dryer. It's usually surrounded by a black resin material situated in a housing made of white plastic. If the fuse looks like it
Sep 20, 2010 | Roper Dryers
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
No Heat. Roper gas dryer model # RGX3514PQ0.
Hay Bud, you have an excellent excuse to buy a multimeter congratulations.. when you do, access the burner assembly and controller circuit board, on your disassembley you will likely find a wiring diagram, this will be very helpful in diagnosing your fault, let me know when you have the meter and the diagram and i will step you through the diagnostic proses.
Apr 28, 2010 | Dryers
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
Roper Gas Dryer not heating.
Is the fuse on the picture is the one you bypassed:
The thermal fuse
- The wiring diagram which may help you.Here is information about prices n more elements that you may need.http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/Dryer-Thermostats-and-Fuses/index.aspx "Did I answer your question ?
Did it solve your problem?"
Jan 19, 2009 | Roper RGX4634KQ Gas Dryer
Roper model #rgx4635ew1
replace thermal fuse when no heat in dryer will not advance timer will continue to run all day long
Nov 30, 2008 | Roper RGX4634KQ Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
365 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
