Question about Alpine Air XL-15 Air Purifier
Alpine XL - 15 Fan Stopped Working
Hi JSEhandyman,
Thank you so much for taking the time to reply to my question. I hope you don't mind me contacting you and asking a follow up or two.
I copied and pasted your reply to me below for reference, as since I asked the question, I've discovered another quirk with the fan. I can give the fan blades a push when the unit is on and the rotary dial is set to high, and the fan will start up and run normally, with me being able to adjust the speed up and down with the dial. However, after running for an hour or two normally, the fan just stops dead for no reason. I can give the blades another nudge and it starts up and does the same thing again.
My question is this: is this more indicative of a switch problem or a fan motor problem? I haven't had it running for a couple of months now since I messed with pushing the blades for a couple of days, for fear that I would hurt something.
Even though I'm a girl, I do own a multi meter. But, I'm not very familiar with how to work it other than what I rarely use it for at work, which requires a high voltage probe to measure transformer loads for neon signs. (I make the neon, and from time to time I have to measure the load on the secondary side of the transformer to test for an over load.)
Thanks again for your time, and letting me pick your brain again.
night light
Hello night light,
How you proceed is going to depend on how comfortable you are taking it apart.
Given it's age and purchase condition, warranty isn't an issue. You will either be able to dis-assemble the purifier and try taking the motor apart and reassembling, or you can find a replacement motor (I've seen some on the web, they start at ~$50).
Another possibility is that the fan pot (the rotary switch that the knob turns to adjust the fan speed) may be out. If you have a multi-meter, see if you can get a signal through (when it's all the way open). If not, try replacing that first. Parts are available onthe web, I can't advertise per FixYa's terms of use.
Hope this helps.
  • teresaholm Jan 11, 2009
    WHEN I TURN MY LAIR PURIFER SMELLS LIKE A WET DOG I WANT TO KNOW WHY
    WHEN I TURN MY FLAIR PURIFER SMELLS LIKE A WET DOG J WILL LIKE TO KNOW WHY
  • 368 Answers
Hello again, night light,
I don't think you hurt it by nudging the blades - I have one where it does the same thing unless I have it set on "max".
The challenge is that I don't know which is more likely the problem - I haven't worked much with the electrical aspects of them recently - - I might have to try working with one, although it may vary between models - the one's on the circuit board would be harder to swap-out. What was the vintage of yours again?
Good for you on having a multimeter, and being willing to learn to use it!
All I was talking about earlier was using the CONT (continuity) function to check for a circuit (some models have a little buzz or beep that sounds when you have a connection. If you have the fan pot. wide open, you should be able to get a good signal between the terminals of the pot.
Another option - crude, but effective - would be to "jumper" (short-circuit) the fan terminals (at the pot.) together to see if it runs with the pot. bypassed out of the circuit. This shouldn't harm the motor, and if it still doesn't work, that points to the motor being bad. As always, use common sense and be safety-concious, don't bypass the safety cut-out switch or the like.
I may have to check with one of my brothers (biomedical electronics tech.) for a little additional guidance - - he could probably give me better insight without spending a lot of time on trial-and-error. If that happens, I'll follow-up with another Solution entry in the next few days.
If I can be of further assistance, or if you have additional questions/comments for this item, please let me know.
If/when this solves the issue to your satisfaction, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 01, 2009
Where can I find a ozone control for the XL-15? The part # is 21-80414-5, Phase-1.
i contacted Living air about this and they replied back stating that you can not buy this that you have to send the unit in for repair. Sounds like a rip-off to have to pay to ship it off just to have someone to plug in a new module that takes all but 1 minute.
Dec 22, 2010 | Alpine Air XL-15 Air Purifier
I have the living air xl15 its not working properly, I cant smell ozone no buzzing sound no uv light no green led coming on. I guess the only thing working is the fan. I don't have a manual and it blows my...
I have an extra user manual for the alpine. You have to clean the plates at least once a month to get maximum performance. Get back to me at nick61@telus.net for the manual. Also the ion emitter sometimes needs to be replaced. I use one of mine in my FIR sauna. It seems to be OK at those high temps. 50*-60* C..so far.
Jul 29, 2010 | Alpine Air XL-15 Air Purifier
I just purchased a used Alpine Air XL-15 from ebay.no ozone spell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 10, 2010 | Alpine Air XL-15 Air Purifier
REPLACED FILTER AND THEN UNIT STOPPED WORKING
I was ready to send mu unit out to get repaired at the minimum cost of $ 179.00 and then saw JSEhandyman list a website for the manual. The manual was not only so simple to read an understand it saved me the time and money of having it fixed. It was a simple solution. I was putting new air filter in on the side and wrong way. THANK U SO MUCH
http://www.ecoquestintl.com/support/US50300_Living_Air_Owners_Manual.pd
Jul 22, 2009 | Ecoquest Living Air Classic Air Purifier
Round Metal Disk type thing in Alpine Living Air XL-15
Hi Chipster7_20,
It sounds like the little round electrical spade terminal is what has broken off. If you aren't comfortable working with electrical (this is a fairly high-voltage environment, BTW), you might want to find a local electrical repairman to replace and re-attach it. EcoQuest no longer does support for XL15s, so it's up to little independent dealers/handymen like yours truly to keep these machines going. You could ship it to me, but it would probably cost more for shipping than having a local do the work.
If I mis-understood your description, please write back with more details. If you could reply with a digital picture it would help. (use the little tree-picture icon in the toolbar above to post it).
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Feb 11, 2009 | Alpine Air XL-15 Air Purifier
Alpine XL-15 fan has stopped working
Hello night light,
Hope this helps.
Sep 28, 2008 | Alpine Air XL-15 Air Purifier
No lights no fan on Alpine Air XL-15
Use a DVM continuity function to see if the fuse is blown, and check all the DO FIRST literature packed with the thing. You probably get to take a note out of the ionizer chamber.
May 13, 2008 | Alpine Air XL-15 Air Purifier
I cleaned my alpine air XL-15 and it will not go on.
Yes, the plates contact the screen. If you used soap on the plates there may be a residue. Use nonsudsing ammonia OUTDOORS and a toothbrush, then rinse thoroughly and let it dry before putting it back. It may take a few minutes of running to get the ozone going again after that. The interlock switch on some units is pushed back to go on, on others pushed down. Make sure the little plastic doodad (or metal on older units) is pushing the switch properly - you'll know if the fan doesn't go on.
- Robert
www.rawfoodlife.com
Feb 03, 2008 | Alpine Air XL-15 Air Purifier
Alpine XL 15 not working after cleaning
Bottom small plastic covered screw is a trigger for interlock switch, won't work if it doesn't push in the metal trigger.
Jan 14, 2008 | Alpine Air XL-15 Air Purifier
Alpine XL 15
Also make sure the safety interlock switch is properly closed when re-assembled. It's the springloaded switch inside the little notch in the chassis - the small tab on the lint screen should fit in and push that switch closed. If you do it wrong, the unit won't work. You should hear an audible click when the tab closes the switch.
Nov 17, 2007 | Alpine Air XL-15 Air Purifier
Alpine Air XL-15 Air Purifier Logo
183 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
