Question about Whirlpool GEW9250 Electric Dryer
No heat dryer runs normal but there is no heat
  • Whirlpool Master
  • 3,463 Answers
Try this link.
In your browser bar type in----youtube.com
Then in the search box type in----repairing whirlpool dryers
Then click on the appropiate video, this should help with your prob, it would take too muc explaining to give you all the info.
Plz rate this solution.
Thanks.
Posted on Dec 31, 2008
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
Kenmore 70 series dryer 110.96573220 only heats on time dry and delicate, not on normal
I would check the temp switch located in the console panel, sounds lile maybe the contact is burned since you have heat on delicate and timeddry.
Feb 02, 2013 | Kenmore 60172 Electric Commercial Dryer
Running the dryer with normal settings. Dryer runs, tub spins, but NO HEAT. Error code popping up after a couple of minutes is "Ad". Any ideas on what the issue might be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Frigidaire AEQ6000ES Electric Dryer
My dryer will run like normal but no heat will come out
check for a broken coil in the heating element. if it is ok, then you will need to check the thermostats mounted on the heater housing.
Oct 24, 2009 | Kenmore Dryers
Maytag dryer runs but will not heat
Sounds like your problem is a faulty heating coil or thermostats.
Unplug the dryer.
Normally if you remove the back of the dryer, locate the air tube from the blower to the drum. The heating coil and thermostats are normally located inside of the air tube.
Remove the wires from the heating coil...Use a continuity meter across the two terminals and check to see that you get a reading of full continuity.
Good luck,
I hope this helps
Oct 05, 2009 | Maytag Dryers
The dryer is not heating
Look for the air tube that runs from the blower to the drum.
The heating element is normally located inside of it.
I hope this helps
Oct 03, 2009 | Dryers
Whirlpool mdl LER3634EW0 runs but no heat?
Normally this problem is caused by the heating element being faulty.
Sometimes can also be caused by the thermostats being faulty.
If it is an electric dryer (you did not say) then you could pull the back off and check in the dryer air tube, it comes from the blower assy to the drum of the dryer. That is where the heating element and thermostats are normally located.
Sep 27, 2009 | Whirlpool Dryers
Dryer runs but doesnt heat
check the heating element and the limit switches there are the first things to look for when theres no heat
Jan 29, 2009 | Roper REX4634KQ Electric Dryer
Dryer does not get hot
pleas4e help my dryer is working but it won't get hot it just blows cold air please help me fix this problem
Jul 20, 2007 | LG DLE0332 Gas Dryer
Whirlpool GEW9250 Electric Dryer Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
