Question about Philips 42PF9431D/37 TV
Phillips 42 inch plasma redlight blinking 8 times
No picture just a red light rt bottom corner blinking 8 times?
  • waldesm Feb 14, 2009
    Front panel has a blinking read light and no image, tv does not start, I can't turn it on. What could be the problem and how to fix it? Can anyone help please!
  • petep1689 Apr 11, 2009
    I have the same problem. If I unplug it and plug it back in a couple of times it will come on. Did anyone figure otu what it was?
CAYPIANAN
  • 227 Answers
SOURCE: Red Error light
check the filters caps in the power supply board that could be your problem
good luck
caypianan@yahoo.com
Posted on Dec 29, 2008
fwadley
  • 482 Answers
SOURCE: PLASMA GE 42 INCH COLOURED LINES
If you can take the TV to a repair place, they can look it over for you and give you a price and tell you want the problem really is, cost is around 50 dallors to look it over, and then you can make up your mind if you want it fixed, a lot all times this is the chippest way out. if its not worth fixing your only out your time and only $50. The price to fix it could cost you what a new one runs.
Posted on Dec 03, 2007
D_LLAMA
  • 6 Answers
SOURCE: 42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Posted on Mar 03, 2009
  • 44 Answers
SOURCE: gateway 42 inch plasma p42m303 6 blinks on power supply
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
dsacco86
  • 1077 Answers
SOURCE: No power to my Phillips 42 inch Plasma
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at Shopjimmy.com
Posted on Sep 06, 2009
Phillip 42 flat screen plasma blinking red light 6 times
most likely the power supply, buy it from http://www.shopjimmy.com/ they have the best prices anywhere. and techs to help if needed
Sep 06, 2012 | Philips 42PF9631D 42 in. Plasma Television
50" phillips plasma wont turn on
I'm having the same problem and am about to try this solution. I truly believe this is going to work. I hope this helps!
http://www.youtube.com/watch?v=OsJSzYVUWVA&feature=related
Dec 28, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
My panasonic 46 inch plasma tv has no display, the red light turns on but no picture, then after a few seconds the redlight turns off
i have the same problem on my tv and i call to bestbuy since the tv is only 2months so still on the manufactures warranty the problem is SC Board shorted, and they replaced the sc board.
Dec 27, 2009 | Panasonic TC-P42U1 42 in. Plasma HDTV
No power to my Phillips 42 inch Plasma 42pf7321d/37, just a red blinking light
Sep 05, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips 42 inch LCD 42PF9730A Redlight flashing
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Jun 16, 2009 | Philips 42PF9631D 42 in. Plasma Television
for more detail.
Jan 06, 2009 | Philips 42FD9932 42 in. Plasma Television
Red Error light
good luck
caypianan@yahoo.com
Dec 29, 2008 | Philips 42PF9431D/37 TV
Philips 42PF9431D/37 TV Logo
1,416 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
