Question about HP OfficeJet D135 All-In-One InkJet Printer
Print Heads Getting an error message "bad print heads" I replaced the yellow, magenta and black print heads as indicated by the self test report. Still says black print head is bad. What to try next?
  • Anonymous Mar 29, 2008
    it is same problem with you
    do i need buy the new print heads
  • Anonymous Apr 03, 2008
    Hi, I just got this d135 used, and says the same about print heads. Change INK but don't know what else to do.
    Any advise since I don't even know what print heads are. .....
I had this problem in the past. I was given "reset" instructions for the printer, which helped for quite a while. Can't find those now, though - does anyone have the steps to reset the printheads on the D135?
Posted on Apr 01, 2008
  • 328 Answers
Make sure the printheads are not expired. Check the dates. Order new from HP direct
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 02, 2007
Please I have an oki printer C831 that's printing only yellow and black on any printing am using it to print please help
I would think you have broken ribbons cables to the cyan and magenta LED print heads. As all the heads are the same I suggest you swop the black and cyan print heads around and see if cyan prints and black does not. That will prove is the print heads are ok. If they are then the ribbon cables need replacing or they are dirty at the heads. It could be just a case of unplugging them, clean them, then plug them back in again.
Oct 21, 2017 | OKI Office Equipment & Supplies
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Trying to copy and nothing printing. Ink levels are good, paper is coming out
Perform "clean print heads" in printer properties select printing preferences,service then click clean nozzles, perform twice or thrice then do the nozzle test, if print heads are recovered your will be in safe, other wise***Two print heads are in this printer each print head leads two colors, left print head leads black & yellow and other one leads cyan & magenta. You need to replace the print heads based on the color which missed.
Jan 03, 2012 | HP Officejet 6500 Wireless All-in-One...
My HP 6500 only prints yellow and black. I refilled all three color cartridges and only the yellow is working. Any ideas?
This printer having four cartridges and two print heads.Each print head having two pens, black, yellow & magenta,cyan. As you said yellow & black are OK.. So replace Magenta & Cyan print head..
Oct 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Hi i have a hp officejet 4355 all in one printer at my place. i m having problem fixing with the cartridge as it is showing error. pls guide
Problems with Hewlett Packard Officejet 4355 printing can often be due to issues with the cartridges. The printer has two cartridges, one black and white, and one color. Both can be physically inspected for problems. The printer also has a self-test report to determine if there is a non-obvious problem with the cartridge. The report can provide valuable information, including status.
  • 1
    Take the black ink cartridge out of the slot on the right. Be careful not to touch the ink nozzles or the copper contacts.
  • 2
    Look at the cartridge and make sure that the plastic shipping tape isn't still attached. There shouldn't be any tape covering the ink nozzles.
  • 3
    Replace the black cartridge and then perform Steps 1 and 2 on the color cartridge. The color cartridge is the one on the left side.
  • 4
    Print a self-test report. Load paper in the tray and press "Setup." Press "2" and then "4." The HP Officejet 4355 will print a report. Make sure the lines of color extend across the page. Missing, faded or streaky lines can indicate a cartridge failure. If the color bars don't show as black, cyan, magenta and yellow, you should clean the cartridges.
  • 5
    Press "Setup" and then press "6" and then "1." The print cycle will commence. Allow it to complete and then print another test report. If the test still shows errors, replace the cartridges.
  • Feb 01, 2011 | HP Officejet 4355 All-In-One InkJet...
    I have replace all of my ink jet cartridges and it sees the black and magenta, but I am still getting the ink empty error message for cyan and yellow. I have removed and reinstalled atleast 20 times,...
    did you make sure to remove the stickers covering the print heads? double check. other than that you can clean the heads with a qtip and isopropyl alcohol, they may be dirty with old ink and not able to see the new cartridge properly.
    Jun 18, 2009 | Brother MFC-210 All-In-1 Print/...
    No black ink printing
    Ah, solved already. Cleaning the black print head a few more times did it for me.
    Mar 11, 2009 | Brother MFC-5840CN All-In-One InkJet...
    Printer makes noise while cleaning heads
    Grinding noise is most likely caused by the carriage lock getting stuck and holding the print head at the home position. The noise is caused by the toothed belt that pulls the head back and forth, skipping over the splines on the motor drive wheel. If you have been able to print since the problem occurred, chances are that it has freed itself up and will be fine. Regarding the loss of cyan & magenta output, follow the solution given in my previous posts to complete a manual under-head cleaning cycle. This should get you going. Check this previous post for cleaning info: http://www.fixya.com/support/t137335-problem_print_outs_from_printer
    Jul 05, 2007 | Epson 1000 ICS All-In-One InkJet Printer
    HP OfficeJet D135 All-In-One InkJet Printer Logo
    282 people viewed this question
    Clive
    Clive
