Question about Kenmore 63942 Dryer
Kenmore dryer not heating
Just so I don’t waste my time and money on my problem…my dryer stopped heating. I pulled the heating element which looked like a twenty year heating element because it is. There were no breaks in it so I put an ohm meter to it and it had good continuity. I then pulled the thermal cut off kit out. The thermostat had good continuity. The top part of this kit is, I take it, the fuse. If that is correct and it is a fuse, it is bad because there is no continuity. My question is should I put the money out for a new heating element or just go with the one I have? How long do they last anyway?
  • userm1555 Dec 29, 2008
    Thanks for the help. I did clean all the lent out from behind the dryer and the vent tube.
  • 318 Answers
Just replace the thermal kit. it will come with both the upper thermal fuse and the lower high limit. dont change the element as they are just like light bulbs, they either work or they dont. they dont have a life span they just work until they break. and if yours is not broken and has continuity then it is ok.
one thing to do is to figure out why the thermal fuse failed. probably because of an air flow problem, either the lint filter is not clean or the vent is pinched off behind the unit. it may also be the vent in your home needs to be cleaned out.
change the thermal kit and it will work again until it gets too hot again. that is unless you fix the vent.
Posted on Dec 29, 2008
  • Kenmore Master
  • 8,220 Answers
I would leave the old one in there till it breaks.The replacement parts don't seem to last as long as the original equipment.
Posted on Dec 28, 2008
Dryer heats in a 'no heat' selection
it sounds like you have a grounded heat element and the heat will stay on all the time,very easy to check,unplug the dryer,pull the two wires off of the heat element,with a meter touch one lead to the outside metal cover of the heater and the other lead to one of the element,then check the other side of the element the same way,if it shows continuity on one end of the element it's grounded and needs to be replaced with a new heating element.and every year or 18 months you have to clean out the dryer,i use a shop vac and a leaf blower,unplug the dryer,remove the bottom panel,remove the lint filter and the metal duct that the filter slides into,vac up all the lint you can see,brush out the hole where the filter goes and with a long thin screw driver dig out the lint that's in the right and left sides of the plastic slots where the filter slides in,now with the shop vac set it to blow and blow all the lint from the back forwards and blow the motor off and vac up the lint,after you clean out the cabinet go to the back and remove the vent line from the dryer,stick the leaf blower into the vent line and blow it out to the outside,if you do this every year you'll have less problems with the dryer,your clothes will dry on time and you don't have to worry about a dryer fire.
Feb 01, 2014 | Kenmore Elite HE4 Electric Dryer
Our Whirlpool Senseon Dryer stopped heating. It's
I had the same problem. I replaced the thermistor,heating element and another part and still didn't correct problem. i finally had a friend come check it and believe it or not it was the 30 amp fuse in my fuse panel of the house.Come to find out the dryer will run and everything works like it should on 1/2 of the 220 plug but the other half runs the heating element.Both fuses must be good. I replaced the 30 amp round fuse and it works and heats perfect. I hope this helps you and saves you some time and money.
Tommy
Mar 16, 2010 | Whirlpool Dryers
Dryer Stopped Heating
Use a multimeter to check the heating element. You can't always go by looks. Check continuity and if there is none, the element is defective. Another thing to check is the thermal fuse. It is about an inch long and is usually attached to the exhaust duct. Use the meter to check it as well and if defective, replace it. Sure hope this helped and best wishes.
Jul 28, 2009 | Whirlpool LER5636P Electric Dryer
Dryer will operate but won't heat up
thermastat or element at fault
Jan 17, 2009 | Dryers
Trying to determine if it is worth replacing the heating element on a 12-15 year old electric dryer?
Are you kidding me? Light bulbs don't last for 15 years, why would ya think your dryer heating element would last longer. Me I replace the element every time. Todays newr electronic **** is worthless.
Dec 14, 2008 | Dryers
Older kenmore electric dryer
This is a element problem, all you have to do is on your meter, is put it on tone, and ck both ends of element, it should beep.The easiest way is to pull off and ck coils for any breaks( look carefully). Make sure unplugged at all times.
Oct 22, 2008 | Kenmore 63942 Dryer
MAYTAG PYE2300AYW ELECTRIC DRYER - HEATER SHUTS OFF PREMATURELY
First off, how are you looking to check this situation. Either way, it would be normal for this to happen. When you are looking at the elements heating, you more than likely have the door open to see them. The heater will do what they call "short cycling" because the airflow has outside source air getting into the heat stream. The door and lid almost always has to be shut for this system to work correctly. You can sometimes crack the top just enough to see the element heat. Usually, if the element is coming on at all, then the system should be fine. If you have a dryer thats not drying your clothes completely, its more than likely you have a ventilation issue (i.e vent tube restriction, grass growing in the end of the vent, etc). Also remember these Maytags have two thermostats on them most of the time. One directly over the top of the element, and one in the fan housing at the front of the unit. Try those, if there isnt a change, write me back and will look from there. Good Luck!!!!
Feb 01, 2008 | Maytag PYE2300AY Electric Dryer
Dryer spins fine but no heat
First and most importantly you have to be sure the venting is completly clear of debris and lint. Then remove and inspect the heating element and all thermostats with a multi-meter. Unless your familiar with this type of procedure you might consider calling a technician. Your wasting too much energy and money drying clothes for 2 hours. Technician much cheaper in long run. Good Luck tatau.
Dec 09, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 63942 Dryer Logo
142 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
