I have a 1.5 hp motor makes loud noise on start up then goes away
Is it something easy to fix or would have to replace the pump?
If this is a high pitched sound, then this sounds like you have bearings that are starting to go out. There is not much that you can do to prevent eventual failure.
The only other option that I see is that there is something causing friction inside the pump between the impeller and diffuser.
like air noise or buzzing noise?
