Question about GE Spacemaker JVM1640SJ Microwave Oven
VENT NOT SUCKING
YOU CAN TURN THE FAN ON AND HEAR THE SOUNDS BUT I DON'T THINK IT IS REALLY SUCKING OUT THE SMOKE
JVM1440WH01 GE
  • GE Master
  • 9,098 Answers
I would suggest checking the filters, checking the duct work (including the outdoor vent) and if that doesn't turn up the problem, the hood vent exhaust fan blade assembly may have come loose on the shaft.
You can download GE owner's manuals and installation instructions here to help you verify the filter status and duct work.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 28, 2008
Owners manual for a GE Spacemaker over the range microwave model #JVM1440WH01
GE has the manuals for most of their products on their support site: http://www.geappliances.com/ge/service-and-support/literature.htm?icid=GEARsupportflyout-manuals . The direct link to the Owner's Manual for the JVM1440WH01 is currently https://www.myapstore.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40473.pdf . This particular model's support page is https://www.geapplianceparts.com/store/parts/assembly/JVM1440WH01 .
I hope this helps.
Oct 15, 2017 | GE Microwave Ovens
Exhaust fan vent not sucking in smoke
make sure the filters are not clogged with grease and oil. Try removing the filters to see if it works better.
Nov 28, 2015 | In Microwave Ovens
GE Spacemaker JVM1640SJ Exhaust Fan Whines & Doesn't Do a Good Job
The vent fan assembly's blade assembly may be freewheeling on the motor shaft (which can be fixed with a couple of drops of super glue or epoxy) or there may be a foreign object or critter in the fan blades.
You will have to remove the oven from the wall to inspect and remove and inspect the vent motor. You can download the installation instructions here.
At my Web site, you can get details, plus I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can order any needed GE parts from the Pros here, my favorite affiliated supplier.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 04, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Microwave JVM1850 will not heat unless I put the vent fan on.
That's really odd. I don't believe I've heard of that one before.
I would suspect the problem is on your control board, which in most can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | GE JVM1850 1000 Watts Microwave Oven
GE Gold Over The Cooktop Microwave condensation - help!
It sounds like insufficient air flow. The damper must be one that doesn't require too much air flow to open it.
Was the damper he used to replace it the same as supplied by GE in the install kit? Otherwise, if the new damper has too strong a spring in the door, it will restrict air flow.
For more free DIY and other help & advice, feel free to contact me.
pupista@gmail.com
Mar 15, 2017 | Microwave Ovens
My Whirlpool microwave hood combination was installed when I bought my home. I can hear the exhaust fan run when I turn it on but it does not pull any smoke, steam or odors from the stove top. I can put...
sounds like they forgot to flip the vent louver,
it sits atop the microwave and needs to be rotated to the proper direction for venting.....
Oct 13, 2009 | Microwave Ovens
GE Microwave Profile Spacemaker Runs on its own
Your microwave turning on by itself is a "self preservation feature" of the GE Profile Advantium and maybe some other models. Read the manual, When your over the range oven gets warm enough, for whatever reason the venting fan comes on until a satisfactory oven temperature is reached. You are not permitted to shut the vent fan off. Also it seems a temperature near room temp must be achieved before it shuts the fan motor off, it is very annoying. We had to return our Advantium because of fan noise. I configured the ovens vent fan to the recirculate direction because we do not have a vent duct that exits the house over our range. When the vent fan acting as the ovens cooling fan automatically turned on we would have to leave the house to hear each other talk. Too bad we really liked the oven other than that major problem. G-Man
Apr 19, 2009 | GE Profile Spacemaker Over-the-Range...
Suction fan on GE over-the-range microwave
If the blade is not big enough, the motor not powerful enough, or the vent size is wrong then it will not work properly, On thing you can do is check the vent cap and make sure that it has not falling down onto the vent pipe and blocking air movement.
Feb 11, 2009 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
346 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
