Question about JVC RX-880V
Connect a sony 165W RMS active subwoofer into a jvc rx-880v
Is it possible to connect a sony 165W RMS active subwoofer into a jvc rx-880v.  I have a jvc rx-880v av without manual and i am not sure i can do it. btw, where can i get the rx-880v manual for download?
thanks in advance, werner
SOURCE: jvc rx 318
did you find a manual? I have this stereo and the manual if you need some help.
Posted on May 06, 2008
sparky1500
  • 1066 Answers
SOURCE: No subwoofer output-JVC RX-8020V
this is a self-powered sub, correct?
Posted on May 23, 2008
  • 51 Answers
SOURCE: speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Posted on Jan 02, 2009
  • 24 Answers
SOURCE: Connecting Powered Subwoofer to a Receiver
you will need a line-level converter to use this subwoofer- it is a rectangular-shaped box with wires coming out on one end and red-and-white RCA plugs one the other. The end with the wires coming out will hook to the receiver, and the other end will need to plug into the sub.
Posted on Feb 21, 2009
SOURCE: Trying to find JVC RX 717V User Manual(Free)
Try this. It is the Service Manual but also has User Info.
http://www.audiocircuit.com/index.php?c=JVC&m=RX-717-VTN&models=2
Posted on Oct 06, 2009
How do i hook up a sub-woofer to jvc rx-6040?
Any old subwoofer or is there a specific one? It's manual might give some clues.
Register and download the JVC RX-6040 manual for free at audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/jvc/jvc_rx_rx6040b.html
May 14, 2011 | JVC RX-6040 Receiver
Can I connect a active subwoofer to my SONY STR-DE597 Powerful 6.1 channel AV Receiver
Yes, it only supports an Active Subwoofer. That's what the Sub Pre-Out is for.
Your sub will take that input, possibly split to two RCA connectors, and its internal amplifier will do the rest. Its own manual will give the specifics.
Feb 07, 2010 | Sony STR-DE597 Receiver
AV receiver single line output to two line input on sub woofer
You are trying to connect the powered sub output of the receiver to a standard (unpowered) subwoofer. Can't be done.
May 05, 2017 | JVC Audio Players & Recorders
Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
Jun 06, 2009 | JVC KW-AVX800 CD Player
Subwoofer doesn't produce sound
just check out for proper connectivity of cables to back penal of main system.
Jul 08, 2008 | JVC RX-E100 5-Channel Amplifier
Rear Surround speakers
Best thing to do is to put the unit in 5 channel or 7 channel mode. That will send left ch information to the front left and rear left speakers ( both will get the same information). Ditto with the right channel. The center channel will get centre channel information.
If all the speakers work, go out and rent TOP GUN. ( yes its old), BUT there are a few extreme scenes , one of which is the elevator scene, where the camera changes perspective and suddenly you hear the elevator doors close BEHIND you through only the surround speakers ( have the unit in surround mode....NOT 5 or 7 ch mode ). If this works ok, then you have no problems.
Remember, surround sound only produces information in the rear channels when the information is there. To check out the digital and DTS decoders, get an action flick. If you can, get a remote too, because that will unlock many features about the receiver that you cant get to with the front panel controls. Also go to yamaha and download the owners manual ( its free !!).....that should get you going.....
best of luck...
Rob
Jun 08, 2008 | JVC RX-880V
Subwoofer-no output
ther should be a diagram in the left hand corner of display of speakers hooked up, make sure sub is shown right under the left right (and possibly) center speaker icons. under adjust, there is a subwoofer volume level. Under settings there is sub (yes, and no for on and off) there is a sub crossover frequency, and i believe there is also a "LFE" att, which is another subwoofer level.
May 23, 2008 | JVC RX-8020V Receiver
Speackers
Hello 6423,
The RX-664VBK is capable of having 6 speakers connected to it, 2-front, 1-center, 2-surround and 1-powered subwoofer.
Hope this helps.
cancerags
Dec 28, 2007 | JVC RX-664V Receiver
JVC RX-880V Logo
63 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
