Question about Syntax SV266A SKA KT266A Motherboard
Pci universal serial bus, pci ethernet controller
Under device manager, i keep getting yellow flags for the subject above, and no matter what i do, i cannot repair this. i am trying to get an amd athlon 2000 computer with a syntax sv266a mb to work properly so i can give it to a friend who needs one to communicate with his work and emails to others. i cannot find the disk that came with this unit, and do not know where to get the proper stuff to repair the drivers needed, or if i really need drivers for these problems. can you help please. thanks much. joe v.
  • 385 Answers
Http://64.168.125.230/support/Syntax/Motherboard/SV266AD/USB%20driver/ Try the usb driver from this website. It might work. As for the network card. If you right click on it, go to properties, select details, give me the exact numbers that looks like below: PCI\VEN_10EC&DEV_8139& I need to get the driver for the network card from its original manufacturer. Awaiting the numbers
Posted on Apr 25, 2007
    President:
  • 2,961 Answers
Syntax, is i think, now no more, but there are drivers available on the site link below, or you can rifgt click on the exclamation marks and click update driver and search the net. http://list.driverguide.com/list/company2307/page3/index.html You will have to register free first
No usb ports recognized
W 7
First, please disconnect all USB devices and then perform the following steps: Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
Mar 25, 2014 | Systemax Venture C11R PC Desktop
USB DONT WORK
W 7 First, please disconnect all USB devices and then perform the following steps:
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Mar 12, 2013 | Compaq Computers & Internet
Usb bus does not notice drive plugged in
w7
for xp or earlier
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope it helps
Oct 18, 2012 | SimpleTech Simpledrive Computers &...
Hi sir, I need help on my pc, i install a usb 2.0 pci to usb card on the mother board but cant get it working, i have on device manager under other devices have an exclamation mark on universal serial...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Available in this download are drivers for VIA USB 2.0 host controller on a system running on Windows 98/98SE/Me. Due to licensing agreements, USB 2.0 drivers for Windows 2000/XP are not available for download. They are supplied on CD with new mainboards or available through Windows Update. This version is a bug-fixing release.
hope this helps
Jul 30, 2011 | NEC Televison & Video
USB DRIVER
You might have to re-install your "Universal Serial Bus Controllers" here is how you do that:
1.Locate "Device Manager" usually by pressing start then typing "Device Manager" into your search menu if you are using windows 7. If not then it is easily found under Control Panel.
2. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the "Host Controller", click "Uninstall" and click "OK".
3. Repeat step 2 until all item under "Universal Serial Bus Controllers" are uninstalled then restart you computer windows will re-install everything for you.
Mar 25, 2011 | Computers & Internet
Plugged in my new webcam Trust spotlight 16428 and keep getting error code 43
Support file isrt.dll not installed during loading of wusb300n I unloaded device and reran. I get "Cannot install this hardware. There was a problem installing this hardware." I followed Microsofts...
That would be correct. If it is USB attached and not PCI (internet/ethernet card)
I would try updating drivers for the linksys and then reinstall the software and manually set configuration
Jun 30, 2009 | Linksys WUSB300N Wireless Adapter
Acer extensa 5620
i have laptop acer extensa 5620z, install windows xp professional os 32 bit, inside device manager open that time
Ethernet controller
Ethernet controller
Mass storage controller
Pci device
Pci device
SM Bus controller
Universal serial Bus (USB) controller
biling the yellow(!) mark, and usb device put in the usb port not open how to solve this problem, please reply me, thankyou,
my email senthil_japan@yahoo.com
Jan 26, 2009 | Acer Extensa 5620 Notebook PC
Dell Inspiron 710m PC Notebook Problem
Go to "Device Manager" and look if any yellow or red alerts are being displayed next to any devices. To access the "Device Manager" go to the 'Control Panel", "Administrative Tools", "Computer Management" and select "Device Manager" located in the left side column.
If there is an alert, double click on that device to determine the problem, i.e.… device not configured, cannot start this device, etc…
It sounds like all your software drivers got blown away or can’t load. If that’s the case, try running diagnostics. Press and hold the <Fn> key while powering the system on. This will initiate a diagnostic routine to check your hardware.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 31, 2008 | Dell Inspiron 710m Notebook
Syntax SV266A SKA KT266A Motherboard Logo
422 people viewed this question
Top Syntax Computers & Internet Experts
Gbenga
Roy May
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
