Question about HP Pavilion ze2000 Notebook
HP ze2000 battery charging problem
Everything works fine except it won't charge the battery.
Charging light stays on constantly for a short while - 5/6 mins and then starts to flash (presumably indicating a flat battery)
Have tried:
New battery
Cleaned battery connection contacts both external and internal (if you have ever taken a ze2000 apart you'll know what I mean) with alcohol. Checked soldered joints all ok.
Lap top is a 2005 model which has had very little use.
Also trying to get a retro fitted internal wifi card to work but i'll chuck that up in a separate post.
Cheers in advance.
  • andyj123 Dec 29, 2008
    I'll see if I can find someone with a HP AC adaptor and see if it makes any difference.
  • 142 Answers
Could you need a new charger???
Posted on Dec 29, 2008
Battery light stays on after changing battery,alternater & plugin.
Is the system charging? You should have 14.2 14.6 volts at the battery. The charge light is controlled by the alternator internally. If the charging system is working, you could have a bad diode inside the alternator keeping the light on or a short/grounded circuit to the battery light
Apr 11, 2015 | 2003 Ford Windstar
I have hp notebook compaq 1610p battery won't
The battery is dead, replace it. If the power cord works and the battery is not charging, then the battery is dead. The battery only has a useful life then it has to be replaced.
Apr 26, 2012 | HP Computers & Internet
Battery light stays on. Had the alternator checked and is fine. Have replaced the battery and checked the connections. What else could it be?
have the charging system checked out find out if its charging anything.this may have been why the battery light stays on.usually a bad battery won`t turn on the battery light as its used to let the driver know that the charging systems needs to be checked out.
Nov 03, 2011 | 2000 Ford F250 Super Duty Crew Cabs
My laptop is not charging. it says 0% available (plugged in, not charging) plz help i have a stock hp pavilion dv5
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 25, 2011 | HP Pavilion dv5-1138nr Notebook
Have had a HP ipaq rx1950 for about 2 years and last month it has stopped charging the battery. I bought 3 batteries and each one does not charge. I put these batteries in another person's ipaq and...
its just 3 things.
1; battery
2: charge regulator on the device.
3: power pack
one is bad.
so its not battery, now its #2 or #3
seen the regulator is toasted
very common
why not buy as used spark same device, and mix part to get good
or ditch it and upgrade,
Mar 12, 2017 | HP iPAQ rx1950 Pocket PC
My hp pavilion was fine but it discharged
ok it sounds like your battery was damaged when it discharged. try removing the battery and plug in to wall socket. boot computer ,.. if it boots up completely then you will need to replace your battery
Sep 22, 2009 | HP Pavilion ze2000 Notebook
Toshiba A135-S4527 laptop ** Battery not charging!
Check the power input jack soldered connections for cracks, resolder them as necessary.
May 15, 2009 | Toshiba Satellite 1135-S125 Notebook
HP Pavilion ze2000 will not power on
My ze2202AP,AMD sempron2800,not power on,the problem is one cermet capacitor short,part number PC35 10u/35v.It is 927245a.jpgin the 18VDC input circuit.
Oct 21, 2007 | HP Pavilion ze2000 Notebook
HP Pavilion ze2000 Notebook Logo
206 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
