Question about Hitachi CM811 Plus 21 in. CRT Monitor
Color adjustment for CM 811U
Has anyone got this figuired out. The color must be adjusted after CRT replacement.
  • Larry Bloomer Apr 27, 2007
    There is a serial connector on the monitor which it appears that some type of programming box attaches to similar to a viewsonic monitor that we repair. This appears to be the only way of getting to the menus to adjust colors. We spoke to a authorized Hitachi repair center and they said that this box exists but would not release any further information. We had the same issue in changing tubes (CRT) on a 21" Ilyama model. We have sinice found out that all we need to do was short 3 of the pins on the serial connector and that would then enter a color adjustement menu. We have about 75 of the Hitachis that the only problem is burned marks on the CRT and would like to get these repaired.
Benimur, To clarify we are the tech people who changed the tube. Normally we hook a sencore color generator to the monitor and use that to adjust the color. This monitor will not allow you to do this from what we can gather without some type of external box that plugs into a serial type connector inside the monitor. We have a similar setup that we use for some viewsonic monitors. Hitachi told us that this exists but would not provide any further info on it.
Posted on Aug 15, 2007
    Brigadier General:
  • 6,966 Answers
Hi, if you are referring to the replacement of the picture tube, then yes, the color will have to be adjusted. However this should have been done by the tech personnel who did the replacment with a color bar generator and alignment tools. You can also try pressing the degauss button on the monitor to see if the color balances back. Hope this be of some help. Good luck
Posted on Apr 25, 2007
  • Louie  Role
    Louie Role Apr 26, 2007
    Hi again, maybe I did not understand your concern correctly, can you please elaborate on your question.
Color bleeds
test first a) Video detector, then 2) AGC, adjust control, circuit 3) color Sync 4) color occ 5) color killer 6) color i-f 7)DEM red-gree-blue+videoamp red-gree-blue finally YOKE.see the b.diagram attached.
God bless you
Oct 17, 2012 | Televison & Video
Color is over red
The color of the Television is compose three color,the Red,Green and Blue.First thing to do is try to adjust the color adjustment.Adjust and balance the color.
Aug 18, 2011 | Sony KV-XR29M50 TV
How to adjust picture color
To adjust color first of all set contrast and color controls to minimum,adjust the brightness to see clear picture than add contrast to get perfect black and white picture than add color to it for a good quality color picture.
Jan 22, 2011 | Symphonic ST419E TV
How can you adjust the color?
On your remote control, press video, will give you options to adjust, press video until it gives choice of color adjustment, press video agiain for tint, pressing again gives you other picture choices.
Nov 28, 2009 | Mitsubishi CS-35405 TV
Toshiba 65H14 is all green... Tint doesn't change it..
As TVs age, the rate at which the CRTs begin to decline in terms of light output increases. If you go into the customer menu and adjust the color setting to zero. ( no color) observe the image. Is it good gray scale? Or, is the image still green tinted? If so, its definitely a problem with the CRTs( picture tubes) You may need to just re-adjust the screen settings for the CRTs or it may be more serious, a CRT may be bad. Replacing the CRT is a job for an expert and will cost $500-700.
michtech
Feb 17, 2009 | Toshiba 61H70 61" Rear Projection...
Bad color on sony kv-36fs16
Possible bad CRT....check video out on C board,video drivers on
A board.........................T.
Dec 23, 2007 | Sony KV-36FS16 36" TV
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
Screen
What you may have needed to do was adjust the green & blue crt screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white px. Now adjust each crt screen so that you end up with a true black & white px. Then adjust each focus control to get a sharp px, have your tv on a channel like the home shopping network so you can adjust each crt focus one at a time for clarity by cover the other 2 up. Then go back into picure adjust & turn color ahlf way up, you should see a better px.
Jul 01, 2007 | Philips 60P8341 60" Rear Projection...
Can't adjust the color
Sounds like a technician will have to determine if the blue CRT is failing or just needs to be adjusted.
Apr 23, 2007 | Hitachi 43GX01B 43" Rear Projection...
Color Adjustments
Why would you want to change the color settings after changing a CRT? changing a CRT should not affect the color settings! please describe the nature of the problem with more details.
Jan 30, 2006 | Hitachi CM811 Plus 21 in. CRT Monitor
Hitachi CM811 Plus 21 in. CRT Monitor Logo
71 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
