Question about Plantronics Explorer 340 Wireless Headset
Plantronics 330 no longer pairs with Blackberry 8310.
When I try to pair my 330 Plantronics to my 8310 Blackberry I se the bluetooth symbol that normally indicates that the Plantronics has successully connectd to the Blackberry, but I hear nothing.
Furthermore, when I push 'Transfer Address Book' I get the message that "Unable to locate Object Push Server"
The other interesting thing is that I also get another message saying that the Blackberry is still waiting for the 3xxx and this is desoite the fact that the Blackberry also says that they are connected!
Normally the 330 connects easily and reliably to the Blackbery but as of yesterday it has decided to be difficult - any help will be most appreciated.
  • Wainster Apr 24, 2009
    Had the same problem for BlackBerry Curve 8320 and this totally solved it! Thank you!!!
  • 30 Answers
I believe that the bluetooth symbol that you see indicates that bluetooth is enabled on your Blackberry, not that you are connected to a device (at least that's how mine works).
Here are some suggestions:
First, if you are on BES, check with IT to make sure no changes were made (they can block bluetooth).
Next, make sure you are using the most current software. It should be: v4.5.0.108. If you are using an older version, definitely update your software because the 8310 is known to have bluetooth issues.
Do you see your headset listed on "paired devices"? If so, I suggest that you delete it before upgrading the software.
Once your headset is no longer listed (or if it wasn't in the first place), re-connect it to your Blackberry as follows (apologies if you already know this part):
1. Re-set your headset:
Turn the headset off.
Press and hold down the control button.
After 6-10 seconds, the light will flash blue, then it will flash red, then blue.
Release the button when you see the red/blue.
2. On your Blackberry:
Open "Options"
Open "Bluetooth"
Open menu within Bluetooth
If not already on, click "Enable Bluetooth"
Open Bluetooth menu again.
Open "Options".
Turn "Discoverable" to "Yes"
Open the Bluetooth menu a 3rd time.
Click on "Add Device".
Your Blackberry will search for your headset.
If you are prompted for a Passkey, use 0000 (that's 4 zeros).
After a short time, your headset will appear on your Blackberry.
It should appear as Plantronics 3xxx.
Make sure you go back into Bluetooth Options and change "Discoverable" back to "No".
Once you have established a new connection with upgraded software, you should have no trouble with "Transfer Address Book".
Hope this solves your problem.
Posted on Dec 28, 2008
Plantronics 330 unable to get the bluetooth in discovery mode
Once you make your cell phone discoverable, then put the Plantronics Explorer 330 headset into pairing mode by holding the call control button until the headset flashes red and blue. Click on the link below for the Explorer 330 user guide with the pairing instructions.
Plantronics Explorer 330 User's Guide
Good luck from Headsets Direct!
Jan 05, 2011 | Plantronics Explorer 330 Headset
How to connect plantronics 330 bluetooth headset with my iphone 4
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Jul 20, 2010 | Plantronics Explorer 330 Headset
Can't get new Blackberry 9630 to discover Plantronics 330. I've followed the pairing instructions for both instruments, but the Blackberry doesn't detect the headset no matter how close it is.
Once you make your BlackBerry discoverable, then put the Plantronics Explorer 330 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Explorer 320 user guide which has the pairing instructions, it will be the same for the 330.
Plantronics Explorer 320 User's Guide
Feb 02, 2010 | Plantronics Explorer 330 Headset
I am trying to pair my Plantronics Explorer 330 headset to my new phone, an HTC Eris. the phone does not recognize the device. Do you have any ideas?
Dec 21, 2009 | Plantronics Explorer 330 Headset
Need to reset plantronics explorer 330 because it might to connected to a phone i no longer have and im trying to connect it to a new phon. or, if there is an alternate solution to this problem, any advice...
This is probably far too late now, but I'll post it for future reference. You first shut off your 330 then restart it, but continue holding it for around 8-10 seconds (usually it takes less than that) and the headset will start flashing blue and red.
You are now in Pairing mode a.k.a. reset mode. While it is flashing, tell your phone to start looking for Bluetooth devices and when it displays "3XX-Plantronics" (or something similar), you know you have the right thing.
Simply select that and enter the default factory code: 0000 and you now reset and paired the headset!
Jul 12, 2009 | Plantronics Explorer 330 Headset
I have same problem: cannot pair with 6133 but pairs with 6126
Here is a link to the users guide for your Explorer 330 Bluetooth headset. Look at the pairing instructions and make sure you are following them correctly.
Jun 09, 2009 | Plantronics Explorer 330 Headset
Need numeric code to pair with blackberry pearl 8100
when pressing the call button to turn on hold it a little longer then usual after the headset has turn on, it will flah red and blue, then simply do a bluetooth scan with your phone, it will detect the headset.
May 30, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Pairing plantronics bluetooth 330
The code is four zero's (0000).
Mar 01, 2009 | Plantronics Explorer 330 Headset
Blackberry 8310 Bluetooth device no services
I just experieiced this for the second time on my 8320 using a plantronics 510 bluetooth. The solution was to take the battery adn SIM card out of the phoine and leave it out for a full minute. It appears that the phone needs to be rebooted once in a while. I suspect Bill Gates designed some of the internal code.
Oct 15, 2008 | RIM BlackBerry Curve 8310 Smartphone
Troubleshooting?lost manual
Begin with headset turned off.
1. Press call control button for
6 seconds. Release button when
indicator light flashes blue and
red. Headset is ready to pair with
Bluetooth device.
NOTE The headset can pair to
multiple Bluetooth devices, but
will only connect to one device
at a time. The headset will automatically
connect to the last
device to which it was connected.
2. While the headset is flashing red
and blue, use the phone menu
to search for Bluetooth devices
and select “3XXPlantronics”.
3. When prompted for passkey enter
0000. Headset will flash blue when
paired successfully.
Apr 15, 2008 | Plantronics Explorer 330 Headset
Plantronics Explorer 340 Wireless Headset Logo
567 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
