Tv has power, but will not turn on
Red power light is lit, but cannot power on TV with either remote or manual button.
  • Anonymous Jan 19, 2009
    same problem has power will not turn on brand spanking new tv Hitashi P50S601
  • Tim McD Jan 28, 2009
    My remote and manual on switch does not work and now the TV just clicks on and off - no power, just clicks
I have a Toshiba and was just reading through the manual. It suggests that if the tv won't power on or off, you should try unplugging it, plugging it back in, and try again. I hope this helps a little.
Posted on Dec 28, 2008
Where can i get the living solutions jumbo universal remote code for the samsung syncmaster 1701 mp tv
You should use the search remote code feature:
  1. Hold the device button you want to program for 3 seconds & release.
  2. Push & release the power button & the red light will remain lit.
  3. Push the CHANNEL UP button over & over slowly until the device turns off.
  4. When device turns off press OK button.
Hopefully that works for you.
Jan 07, 2015 | Samsung Televison & Video
Haier HLH406BB 40 in. LCD HDTV - tv will not turn on. is not responding to either panel or remote power buttons. red off input light is still lit.
hi sounds like a power supply fault could be capacitors, look for tech in your area good luck
regards
shaun
Jan 15, 2014 | Televison & Video
Need a code to program an innovage jumbo remote to an RCA tv. nothing fancy just the tv code please
The Innovage Jumbo users manual lists over two dozen RCA TV remote codes. They are:
000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
If you can't be bothered to enter each of those codes one at a time, you might consider the auto-search function.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Dec 09, 2009 | Innovage Jumbo Remote Control
I have a jumbo universal remote,how do I programit to an rca tv?
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Nov 23, 2009 | Innovage Jumbo Remote Control
Need code for Innovage jumbo universal remote for a rca tv
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Sep 17, 2009 | RCA TruFlat 27F520T 27" TV
I have a Jumbo universal remote by Innovage and I need the programing codes for the tv. Do you have them???
To program your remote by entering a code from a manufacturer's list, follow these steps:
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Aug 21, 2009 | Innovage Jumbo Remote Control
My remote does not work for my Apex TV
it may be a time to buy a new tv. it would cost more to fix that one than to buy another tv
Nov 22, 2008 | Samsung TV Remote Control
How do i program my remote
1. TV on.
2. On your Dish Network remote PRESS AND HOLD the small clear tv button until all buttons across the top of the remote light up and release.The only button lit should be the clear tv button that will be flashing.
3. Press the small red tv button next to the power button and release it. This should leave the clear tv button that was flashing lit solid.
4. Now slowly depress the channel up key until the tv turns off.Each time the up channel button is depressed the clear tv button will cease being lit and once it is released the clear tv button should remain solid. If the clear tv button flashes multiple times it usually means there is no known code for your tv, there may be another code that will work so continue on.
5. Once you are successful in getting the TV turned off press the channel down button once and then the channel up button. This should turn the TV back on.
6.Press the # key button on the remote. The clear tv button should flash three times then press the record button and try the volume up/down and the small red tv button. You should be able to turn volume up and down and turn tv on /off. If only one of these function it means that you have only found a half code and need to try the process again. Not all TV's have full codes or any codes at all especially combo units.
Aug 25, 2008 | RCA DISH Network(r) 311 Satellite System
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
