Question about Pioneer DVR-520H DVD Recorder
Loses power after timer recording
After my Pioneer records on timer recorder it turns itself off (which it should do) but loses all power to it (which it shouldn't do). I then turn it off and after 30 mins or so it comes back on. The time for recovery is becoming increasingly longer. I have taken the player in to be repaired they have changed some parts. Whenever the Pioneer is in the workshop this problem does not happen. The repairman says he has spoken to Pioneer but has no clues. Can you please help? Cheers Saturn
  • 1 more comment
  • ATSE Jan 08, 2008
    I have similar problem and would like to seek help. Thanks.
  • Anonymous Jan 10, 2008
    I have had the same problem and eventually I could not power the unit at all. Its presently in with Pioneer to be repaired so will see how it goes.
  • Ray Hayward Jun 24, 2008
    Nothing yet. Will check the caps in the p/supply as suggested and post result in a day or 2. Have all parts ex stock...just gotta warm the soldering iron up ;)
Hi Saturn et al,
I had similar issues with my Pioneer DVR-520H. It completely went off for quite a while when it should be going to standby after a timer session. At the start it would come good after a few days. Eventually it went off altogether and nothing would bring it back.
With my father-in-law being an electronics person we investigated with the help of the service manual which I found on the net. The finger was duly pointed at the power IC (MR2920) on the power supply board (Pioneer will sell only the complete board). I ordered the IC from the UK (nikko-electronics.co.uk) GBP8.99 which was the only place I could find it online and soldered it in myself (easy, if you can solder).
All fixed and working again.
Hope this helps.
Posted on Jul 21, 2008
I have similar problem with my Pioneer DVR-530H-S at the moment. Can you elaborate more on how to fix the problem?
Posted on Jan 07, 2008
    Genius:
  • 1,074 Answers
Hi saturn The tech missed a cap that is not filtering properly this should be in the power close to the regulator it is a 10mfd to 470mfd at 160 volts.good luck
Posted on Apr 26, 2007
Why do I get OPC error when trying to record on aCDRW ON a philips cdr 785
Common issue. The lasers/transports in these are terribly unreliable.
More of these hit repair stores and skips than pints of beer down a football thugs throat.
cut your time and loses and invest in one from any brand other than Philips. pioneer and Yamaha make exceedingly good CD-R recorders for the home user. Hhb, marantz, fostex for the pro market
Feb 16, 2016 | Philips CDR785 3-Disc CD Recorder
I have a Techview H.@64 Model 3036. Records during daylight hours but loses video recording at night?. Any ideas on how to enable the infrared recording at night? Marilyn
If you have IR capability make sure you have power to the camera as well as a video feed. There should be a tail at the camera that supports the power and a plug in for the other side.
Dec 28, 2014 | Hardware & Accessories
Set vcr to record after timer is set
You need to turn off the Timer and then add your new program to the schedule. Then turn the Timer back on (power off).
On most VCRs, the Timer is enabled by turning off the unit. Thus turning it on will work (as long as a program isn't currently being recorded). If a program is currently being recorded, press Stop to interrupt the programmed recording. Then add your new program - that doesn't conflict with other programmed recording or exceed the number of available timed recordings for the unit. Then turn off the unit.
At least one VCR I owned was a bit trickier. You had to press the Timer button on the remote instead of the power button.
I hope this helps.
May 16, 2013 | Emerson New Original VCR4010A Remote...
Pioneer DVR-440HX-S DVD Recorder / HDD Recorder ignores timer list
You have an issue with the programming circuitry in Pioneer.
Repair might just not be cost effective given labor and parts costs.
Mar 19, 2017 | Pioneer DVR-440HX-S DVD Recorder / HDD...
How to remove childlock
Hello
To unlock the receiver from child lock, Press '/Power ON button on the recorder. The recorder turns OFF and ' CHILD LOCK' appear on the display. The timer indicator remains lit if there is a timer setting. The recorder will not workexcept for timer recordings.
To unlock the recorder, Hold Down '/Power button on the front panel of the recorder itself, until the "CHILD LOCK" display disappears from the front panel display.
Mar 02, 2012 | Sony RDR-VX515 DVD Recorder/VCR
Will pioneer dv 410v have record timer?
It does not have any Record Timer.
Thanks.
Sep 20, 2009 | Pioneer DV-410V-K DVD Player
DVR loses the time setting.
Make sure your using the correct time zone
Nov 11, 2017 | Toshiba Televison & Video
At the finish of time recording, it keeps turning it self off
how to finish a dvd that it will work on any dvd player
Mar 24, 2009 | Pioneer DVR-520H DVD Recorder
Hi, Have just purchased Samsung DVD HDD recorder (DVD-SH855). Everything works great except the timer recording. When i schedule a recording, the system wont start recording. The recording light flashes...
I had the same issue. It turns out that the recorder has to be switched off otherwise it won't record. The unit will power itself on at the scheduled time and record your program. It doesn't make any sense to me why this would be a requirement but it solved the problem for me.
Jul 06, 2008 | Televison & Video
MyFi loses proper index to recorded music
Sometimes this will fix itself if you take the battery out. Otherwise, the best way seems to be to empty the memory, and start all over, recording on a blank slate. These are really pretty awful machines, with endless problems.
The on/off switch on mine just broke, and I say "good riddance."
Feb 03, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Pioneer DVR-520H DVD Recorder Logo
423 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
