Question about HP DeskJet 6122 InkJet Printer
Ink cartridge light is blinking, I replaced the #45 ink cartridge
The light is still blinking and printer does not work. I've tried unplugging it, restarting computer, turning it off and back on and it still blinks and won't print.
  • kkyadavjbp May 11, 2010
    light printing & blinking light
Just had the very same problem. Probable Cause: On the cover of the printer there is a small piece that fits into a slot on the printer when you close the lid (to tell the printer that it is ready). If this is not engaging properly the ink light will continue to blink. As you close the lid try giving it a gentle pull towards you as you close it and see if this causes the light to go out for you. It worked for mine.
Posted on Jan 29, 2009
  • 45 Answers
What's the printer's model. The print heads may need to be cleaned.
Posted on Jan 07, 2009
Blinking light
Try to Reinstall the cartridge , if the blinking continue , try to remove ink then unplug the power cord and reconnecting power cord with ink then see blinking for ink , then install the cartridges , if hope this help
Mohamed Hejazi
Afaqnama - Tripoli, Libya
IPG@hplibya.com
Mar 20, 2013 | HP DeskJet 5150 InkJet Printer
Epson R2400 paper and ink lights blinking red. Ink waste pad replaced and counter reset to 0. Lights still blinking red. Close inspection for any loose objects in printer but none found. Please advise....
Try to turn on your printer without the ink cartridges. When the printer starts and ask for the cartridges, put them back in.
(To remove the cartridges turn on the printer, watch the print head carriage move, when it is at the center quickly unplug the power cable, move the carriage by hand to a position where you can remove the cartridges, after removing the cartridges push the carriage to the right where it should be parked.)
Sep 02, 2010 | Epson Stylus Photo R2400 InkJet Printer
Hp deskjet D4155...Both power and arrow lights are blinking and I have tryed turning it off and un-plugging the printer multiple times, Every time is comes on, they both are still blinking. Please help....
Please remove the ink cartridges, unplug the power cord. You may also remove the paper from the paper tray. Now, try inserting the cartridge as well.. after about 20 seconds, plug in the power..
put in the paper, and ensure that you have inserted the paper properly. Then insert the ink cartridge. This should resolve the problem.
But if the light is still blinking , try by replacing the ink cartridge.
Aug 12, 2010 | HP Deskjet D4160 InkJet Photo Printer
Ink cartridge installed but cartridge light continues to blink
Have you only replaced the magenta cartridge, or have you also tried the print head. A bad print head can cause the ink to read as empty or clogged.
Mar 15, 2010 | HP OfficeJet Pro k550 Printer
The ink warning light flashes, and won't go off, even after I've put a new cartridge in. I've unplugged the printer, turned it off and on, plugged the cable back in, and it won't go off.
A blinking orange light means an empty or incorrectly installed ink cartridge. Ensure that the cartridge is not empty or dried out. Also be sure you installed the number 45 black and number 78 tri color cartridges. The 41 tri-color, for example, looks the same but would generate an error. Also, check that the panel in the back, or duplexer if you have one, is seated firmly in the printer as this can generate odd errors.
Oct 01, 2009 | HP DeskJet 970cxi InkJet Printer
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
Ink cartridge light is blinking without need. and won't print
try to unplug the power cord let it set for about 5 to 10 min then plug it back in and turn the printer on should work fine then
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 23, 2009 | HP DeskJet 932c InkJet Printer
Reset the ink memory level after replacing cartridge
Have you tried to unplug your printer and plug it back in?
May 31, 2009 | Dell 962 Photo All-In-One InkJet Printer
HP DeskJet 6122 InkJet Printer Logo
312 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
