Question about American Standard Evolution 1599.205.020 White Lifetime Bath Drain
American standard bath drain problem
I can't find any instructions for how the stopper assembly connects inside the drain. I had to pull it to get hair out but can't seem to reassemble where the stopper will actuate from the plunger device that opens and closes the drain.
  • richcurtiss Jan 04, 2009
    I finally found the diagram on a plumbers web site. I was able to reinstall the device according to the diagram. It was a little different than your explanation but the plumb bob apparatus is pretty much the same. Thanks.
    Novelist:
  • 148 Answers
The stoper assembly has linkage and a plumb bob aparatus
Step 1 remove the 2 screws that hold the chrome overflow cover,
Step 2 you will see a wire connected to the up and sown handle
Step 3 you should be able to fish out the linkage which will have a bumb bob attached
mae sure this is all connected if not reattach if you do not see the blumb bob reach your fingers in and grab the wire
Step 4 inspect the linkage the first link is about 3 inches from chrome cove, second is about 8 inches down and final is at the bob itself bob is pointed and slides in by gravity
If this all looks ok then fish it down , put chrome cover on and move lever up and down ( you should see the stopper mve up and down
Step 5 If stopper is not in just insrt in drain hole and move the lver flow lever up and down and drain should work sometimes the stoper does not go up or down far enough there could be an adjustment on the linkage to reduce or increase the length of the linkage
Good Luck
Posted on Jan 01, 2009
  • Steve Archer Jan 04, 2009
    Sorry
    I misunderstoood yes you had a up and down actuator which had a chrome rod that went into a ball joint in the drain area under the sink
    I am glad you got the problem solved and welcome to plumbing 101
    The key is you got it fixed!
How to remove bath tub pop-up stoppers
Put the lever in the open position so that you can grab the stopper. After you get a grip on it, put the lever in the closed position and the drain plug and rocker assembly will pull out in a horizontal direction.
Sep 25, 2014 | American Standard 1583.470.020 Universal...
We have american standard bathroom faucets with speed connect drains and they're draining slow
Disconnect the speed drain and pull the stopper out to see if it drains fine with the stopper out and if it does then you need to clean the parts and reinstall same.
Feb 11, 2011 | American Standard Hamilton 4 In. Centerset...
The cable system on the pop up assembly is not working. lifting up or pushing down on the stem does not engage the plunger(in the sink drain).
One of two things can be wrong.The first is the drain plug itself has become disengaged with the plunger inside the drain line. You can check this by pulling up on the drain stopper itself, if it comes all the way out then all you need to do is to reinsert it and give it a little twist to get it reseated on the plunger hook. The other may be the drain handle on the top of the faucet may be disconnected from the rod. Open up the doors underneath the sink and inspect it. The rod should go down and the plunger handle should connect to the rod via a bent metal clip. Ensure it is in the correct position to activate the handle in the drain pipe when the top is pulled up.
Nov 29, 2010 | American Standard Swan 4 In. Bathroom...
Very slow drainage of a small bathroom sink. Liquid Plumber does not help
probably hair stuck in the drain. did you remove the stopper "pop up" if no hair or blockage there or in the trap, then its further down, you will need a small snake. 1/4 inch cable works well in bath and kitchen drains.
you can purchase one at home depot.
Aug 05, 2010 | American Standard Home
Drain stopper won't engage to keep water in tub for bath
Hi, looking at this straight on, you will see 2 screws going through the lever plug section. What it looks like on the inside, is a long brass rod connected to another brass rod with a adjustable section on it and a brass looking piston at the end. If you remove the 2 screws, grab hold of the lever and chrome plate and pull straight out and up to remove the assembly.No worry, nothing will fall in as it is all one piece. You can try cleaning the lever section up and add some wd-40 to it and this may help some. It sounds to me like the lever ball joint is worn out, so it is best replaced. Home Depot has them for under $20.00. Take the old one with you and if need be you can adjust the new one to the same length as the old one. It will keep hanging up on you believe me. Good Luck,
Shastalaker7
Nov 17, 2009 | American Standard Plumbing
The tub/water stopper...how do you take that off to unclog hair in the drain?
The overflow drain / stopper lever has 2 screws holding it in place, place a rag over the drain and remove the 2 screws. then remove the drain assembly, it should slide right out. You can now clean the assembly, you may still need a piece of wire to fish the hair out.
Jul 24, 2009 | American Standard 2771.018WC.222 Cadet 5'...
I HAVE THE AMERICAN STANDARD WALK IN TUB WITH THE QUICK DRAIN AND WHEN I FILL IT UP TO USE THE JETS, THE DRAIN WILL NOT RELEASE TO LET THE WATER OUT. WHAT MIGHT BE THE PROBLEM?
It could be the pressure on the drain isn't allowing the rubber around the drain pop up to come unlodged from the floor of the tub. I have ran into this problem a few times. the best way we found to take care of it was to install a push pull type drain assembly or try and adjust the drain pop up so it pops up higher allowing the rubber around it to break the seal and start to drain. take some pictures and post them i might be able to help more
Jul 19, 2009 | American Standard 1583.470 Universal...
My bathtub drain stopper won't stay open
Do you have the type that has a lever on the wall of the tub?  If so, remove the two screws tat hold it on and pull out the whole assembly that will be connected to it.  It is the spring that is worn out behind the lever and needs to be replaced.  The only problem is that you can't buy just the spring.......for ~$10 you can replace all of it from Lowes or HomeDepot
Apr 10, 2009 | American Standard Scala Bathtub Only ...
I need the installations for a American Standard
I had a similar problem where the Drain-Kit that I ordered was missing a part. After contacting American Standard and requesting a schematic. I realized that the missing part was the rocker assembly with stopper. I have a PDF of the schematic that I can send you if you still need it. Let me know. The alternative is to contact American Standard directly between 8am and 6pm Eastern and request the information. The phone number is (800) 442-1902 Option 3 then 1 then 2. Tell the person that you need the installation instructions for a 1583.470.xxx universal bath drain.
Mar 03, 2009 | American Standard Plumbing
American Standard Evolution 1599.205.020 White Lifetime Bath Drain Logo
457 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
Mike
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
