Question about HP OfficeJet 7310 All-In-One InkJet Printer
'Fast draft print' is the same quality as normal
When I print 'fast draft', it is certainly quicker, but the density of the ink is identical.  I am using far too much black ink.  I would be most grateful if you could be kind enough to help me. Best wishes, Jan
    Problem Solver:
  • 8 Answers
In printer preferences menu reduce the resolution
Posted on Dec 29, 2008
HP Officejet 5610 All-In-One InkJet Printer - printing any kind of document, from many formats (docs, pdf, photos) takes more than 15 minutes for one page to print. Tried restarting computer, printer,...
When you click to print something, you will get what's called the Print Dialogue box. Before clicking "OK", click the Properties button.26849353-6c28-4abb-ab9c-b5e445a1b08b.jpgThis will take you to a screen with some tabs. Click on the Paper/Quality tab. Somewhere in that window you will see some options for "Print Quality".
By default, it is probably set to "Normal". That's the middle setting. To save ink, you can set it to Fast Normal (better for ink saving) or Fast Draft (best for ink saving). This means the printer will use less ink to print the page. The final copy will look a little lighter but certainly still readable.
This option "fast draft" will print very fast and also save your ink.
Oct 16, 2013 | HP Officejet 5610 All-In-One InkJet...
The large black cartridge is not working
Hi Cecile,
Check if you have selected Best Quality printing under Printing Preferences.
Open Control panel - Printers Folder - Right click on printer icon and click Printing Preferences.
Under Features Tab you will find the Quality mode - Fast draft - Normal - Best.
It could also be due to low on ink issue as well.
Regards,
Suhail
May 16, 2012 | Canon PIXMA iP4300 InkJet Photo Printer
Whenever I sending a job to HP 1007 the print quality of the printer is very poor / weak.
Check your preference to see what quality it is on, you may need to increase your quality from fast draft or normal to a higher setting. Also make sure you have plenty of ink.
Feb 08, 2011 | Computers & Internet
When i print a pen and ink drawing it prints very lightly
Try changing the color quality of your printing under your printing preferences to best to get darker prints.
You might have set your printing quality to fast draft or fast normal.
If you do not know how to go to your printing preferences. Follow these steps.
1. Go to your Printers and Faxes(XP), Printers(Vista), Devices and Printers(Win7) 2. Right Click on Your Printer Icon 3. Click on Printing Preferences 4. On Print Quality, Choose Best. 5. Under Features -- Check the box for Print in Maximum DPI.
I hope this one helps. :)
Feb 04, 2011 | HP Deskjet 5440 InkJet Photo Printer
It really prints so slow
Try setting the printing properties to fast draft or draft. It provides a average quality document faster using less ink.
To do this, go to Start->Control Panel and then Printers. Right click on your printer and choose printing preferences. Find the setting for the quality and select Draft or Fast Draft if it is available.
Please note that this printer has a rate of 5.36 pages per minute, so even with the draft you will not see much difference.
Regards,
nicolasiac
Feb 22, 2010 | HP Photosmart C6180 All-In-One InkJet...
The ink cartridges need to be replaced very often epson 810
You can try to change your print quality to a lower setting. This saves a lot on toner. If you are not printing for anything super important you can set some printers to "fast draft" or "draft" quality and that saves a ton. I personally dont usually need to print anything of high quality so I went to my local "Everything" store(not sure if I should use company names) and bought an HP, the cheapest color printer they had which was $30.00 The black and color cartridges together cost about the same as the printer. But I use the lowest setting which is the "fast draft" setting and set it to print in black ink only, and only change that when I NEED something in color and it uses very little and prints very fast.
Aug 10, 2009 | Epson Stylus Photo 810 InkJet Printer
Won't scan, copy, or fax
You need to change the ink cartridge, the fact that it prints in fast draft is because it does not use as much ink to print as normal letter quality.
Jan 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Fast draft printing and 'normal' printing are the same
I'm having the problem too in addition to not being able to print on both sides (duplex printing).
ld
Dec 28, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Going through ink cartridges too fast
Check the capacity of the ink cartridges (in ml). HP usually has high-yield cartridges which cost more, but have more ink. Also check your printing preferences to see what your quality setting is. Draft quality is fine for most text and saves alot of ink, Normal or High is only needed for photo printing. I believe Normal is the default.
Dec 07, 2008 | Office Equipment & Supplies
Print Quality Settings
Go into your control panel
Select Set Printer Properties
Then printing preferences
Select Fast Print
Then ok all windows
This will now print is fast draft on each document.
Feb 15, 2008 | Canon PIXMA MX310 All-In-One Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
2,068 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
