Question about Canon PC-921 Black and White Copier
Cannon phtocopier machine
One side image not clear
  • rsbhal bhal Apr 25, 2007
    And i want to buy phtocopier machine
  • 62 Answers
If the image on one side is not clear it means that : 1) the toner cartridge neds to be replaced or 2) The copier needs servicing by a qualified Tech
Posted on Apr 26, 2007
SOURCE:
HOW TO CLEAR ERROR CODE E000002-0000 IN CANNON IR3300/2200
http://www.copytechnet.com/forums/canon/24451-canon-ir3300-error-e000002-0000-a.html
Thread Canon IR3300 Error E000002 0000
Quoting:
wilson Technician Join Date Feb 2009 Location PASIR MAS , KELANTAN
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
Jul 02, 2018 | Cannon Office Equipment & Supplies
Cannon image runner 2525 error code E0000002
on the control panel press:
aditional function
aditional function
should appear ins screen "#sssw"
search with the left arrow until "CLEAR" appear on screen
press ok
search with the left arrow until "ENGINE" appear on screen
press ok
the screen displays: ERRCLR press ok again
turn off the machine from the main switch (located on the left side of the machine) for 5 seconds
turn back on the machine and try to make some copies
if problem persist replace fixing film assembly
Apr 28, 2014 | Canon imageRUNNER 2200
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Sep 25, 2009 | Canon imageRUNNER 2200
Cannon Image writer 2870 -trying to retrieve a confirmation log for the past week (todays date 5/22/09)
At machine you can select 'monitor'from the bottom of the screen and select the log for copy or print. If you have network access to the machine you can use the RUI, it's much clearer. Just type in the IP address of your machine and the RUI interface will be displayed. You'll find print, scan and copy logs easy to find there and print.
May 22, 2009 | Canon imageRUNNER 2870 Copier
Can't fine servers during LDAP search
hi
try to change the setting of lancard speed to half duplex of photo copy machine
Dec 11, 2008 | Canon imageRUNNER 210S Copier
Cannon IR 2200
OK i am having the same problem but here is the solution that I have found online that I am going to try in the next 5 minutes:
waste toner container is placed left-rear side of the machine. Take out one screw,small cover will come out then pull out plastic container. Empty the container and clean the head really well as this can cause problems with the fuser.
good luck!
Aug 26, 2008 | Canon imageRUNNER 2200
Cannon image class d880 printer driver
Hi go to thise site www.canon-europa.com and down load the driver if its not there thats mean the driver not supported yet tray to contact the deler on your area
thanks
May 17, 2008 | Office Equipment & Supplies
Canon PC-921 Black and White Copier Logo
104 people viewed this question
Clive
Clive
old marine
old marine
