Question about IBM ThinkPad T30 2366 Notebook
I have an IBM T30 that recently had the windows XP reloaded on. New problem, when starting up only get to window that shows shortcuts on desktop. Will not progress past that point. Also noticed the fan does not appear to run. Starts then stops. Don't want to burn anything up like processor so would like to know if fan is thermally triggered or it is designed to run at all times notebook is turned on? Thanks,
  • tedlutkehaus Dec 29, 2008
    Thanks for response. Will pursue running down a new fan. Notice after removing the fan and heat sink that it has 3 wires. 1 black and 2 red. Is this a 2 speed fan?
    thanks again, ted
    thanks for response. good feedback.
    President:
  • 2,692 Answers
Designed to run all of the time. Repair or replace fan. CPU may be freezing because of overheat.
Posted on Dec 28, 2008
  • Thomas F. Schneider Dec 29, 2008
    Possible ; more likely a controlable fan through motherboard that supports veriable speed fans via voltage control..
Tip
Recreate the Show Desktop icon on the Quick Launch toolbar
To re-create the Show Desktop icon on the Quick Launch
toolbar, follow these steps....
1. Use any text editor (such as Notepad) to create a
file with the following lines:
[Shell]
Command=2
IconFile=explorer.exe,3
[Taskbar]
Command=ToggleDesktop
2. Save the new file as a file named Show Desktop.scf
in the WindowsSystem or WinntSystem32 folder. Note
that Notepad may automatically append a .txt extension
to the file name. Remove this extension if Notepad
adds it. These steps do not work if the file is named
Show Desktop.scf.txt.
3. Quit Notepad.
4. Using Windows Explorer or My Computer, right-click
the Show Desktop .scf file, and then click Create
Shortcut.
5. Copy the new shortcut to the appropriate folder. In
Microsoft Windows 95 or Windows 98, copy the shortcut
to this folder: WindowsApplication DataMicrosoftInternet
ExplorerQuick Launch
In Microsoft Windows NT or Microsoft Windows 2000,
copy the shortcut to this folder: WinNTSystem32
In Microsoft Windows XP, copy the shortcut to the
following folder: WINDOWSSystem32ConfigSystemprofileApplication
DataMicrosoftInternet ExplorerQuick Launch
6. Rename the shortcut to Desktop.
The Show Desktop icon automatically appears on the
Quick Launch toolbar.
Reference:
http://support.microsoft.com/kb/190355/EN-US/
on Jun 24, 2010 | Microsoft Windows XP Professional SP2
Can IBM 380XD ThinkPad Laptop,loaded with WINDOWS XP
Yes, your laptop support Windows XP, so there should not be any problem in installing Windows Xp softwares.
Jan 01, 2010 | IBM ThinkPad T30 2366 Notebook
Ibm desktop cannot start windows xp But have drive windows. problem windows loading beak down.
try to install another operating system if it show the same problem means it's yours hard drive problem.
Dec 25, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
T30 cant find os
when you start does it come to point where it shows xp and ibm
Jan 17, 2009 | IBM ThinkPad T30 2366 Notebook
ThinkPad T30 shows DVD rom as a removed component
try this....
copy and paste this to notepad then SAVE AS cd.reg
REGEDIT4-jdm
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
"UpperFilters"=-
"LowerFilters"=-
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Cdr4_2K]
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Cdralw2k]
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Cdudf]
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\UdfReadr]
after saving as cd.reg, right click the files then select MERGE....then restart your pc
Jan 03, 2009 | IBM ThinkPad T30 2366 Notebook
T30 boots but stop , in windows inst.
I have a ibm 2373 that will only start up and show the ibm and windows xp logo briefly,then the screen goes blank,but i can hear the fan running.
Oct 01, 2008 | IBM ThinkPad T30 2366 Notebook
No sound in my ibm T30 laptop
ok, go to start>control panel>system>hardware>device manager. then expand the "sound devices" category, try to find what looks like your sound card and double click on it to open the properties window. Then go to the "driver" tab and click on update driver....hope this helps....if you know any information about your sound card, that'd help......you can search for the currect drivers and firmware online.
Jun 28, 2008 | Microsoft Windows XP Home Edition
Desktop icons lost
Sadly, there is no straightforward command you can use to recover them, but well, there are three ways, really, that you can get your icons back, depending on which ones were lost, that you are referring to. for this, I'm assuming you're running a more recent version of Windows.
----- For Windows XP ------
1) for recently deleted icons- check your Recycle bin, they could still be there.
2)for system-installed icons, such as My Computer, and Internet Explorer- you can recover these by going into your Display Properties (Start -> Control Panel -> Display). Select the Desktop tab, and click on Customize Desktop. Make sure the "General" tab is selected, then, under the "Desktop icons" section, tick off the icons you want to restore. click on "Ok" when you're finished, and Presto! those icons are up on your screen.
3)If the above two options don't work, you may have to add them manually ( a pain, I know). To add a shortcut in this fashion, right-click anywhere on the desktop, and select New -> Shortcut. you will have another window appear on your screen, asking you where the file you are making a shortcut to is located, and what you want to call it. follow the steps, and when you're finished, you should have a working icon. (another option would be to reinstall the software that made the icons, but that's also a pain in itself.).
----for windows vista ----
1) check the Recycle Bin (same procedure as Windows Xp, although, if your recycle bin option is deleted, then you have a problem that can be solved by using #2)
2) For system-installed shortcuts- follow This excellent tutorial.
3)Manually installing shortcuts- same as for XP.
Dec 17, 2007 | Computers & Internet
IBM ThinkPad T30 2366 Notebook Logo
89 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
