Question about Saeco Royal Exclusive 30153 Espresso Machine
Overheating boiler I've owned this machine for about 7 years. I've replaced the boiler once when it developed aleak after about 3 years of everday use. The leak occured again, I ordered a new boiler, replaced it and now it overheats continuously, when I try to make coffes steam is injected into the brew unit instead of hot water, making a mess. I tried replacing the thermostat and temp control sensors on the boiler but that didn't solve the problem. The thermostast says it's "150 degree", but botht he old and new one don't open when over 200F (tested this with a multimeter and boiling water emersing just the tip of the sensor). They can't both be malfunctioning, can they? I've worked on two of these machines over the years, I have a tub of spare parts and have fixed a variety of problems but this one has me stumped.
  • steve389 Dec 29, 2008
    Thanks for the idea. I thought of this, had it happen once before. The thermostat and the temp sensor are well seated, and I reapplied the thermal conductant grease. I'm going to try to lower the temp setting in the menu, it's currently set to high.
    Problem Solver:
  • 6 Answers
Try replacing the temp sensor the green wire coming from the boiler to the board
Posted on Dec 06, 2010
  • 2,039 Answers
It hapen to me it was the thermostat that was not seated properlly put grease on it white grease and make sure it seat good good luck pierre
Posted on Dec 29, 2008
Boiler Replacement -When to do it
Your boiler is on the blink. Now you have some big decisions to make. Do I get another opinion? How much will it cost to replace the boiler as opposed to fixing it? How much energy will be saved? Home heating with a hot water heating system is a very good way to heat. However, when the boiler does not work or leaks there are many things to think about. The troubleshooting ideas in this article will work for both steam and hot water boilers.
If there is no water running out of the boiler and it is just a control issue it may be best to get another opinion. If there is water running then there is a stop leak liquid that can be placed into the boiler as a temporary fix. It should be viewed as temporary and not a permanent fix. Either a section of the boiler will have to be replaced or the boiler may need to be completely replaced.
If the boiler is fairly new and the warranty will pay for some of the cost then replacing a section may be the way to go. Bear in mind though, that the warranty rarely covers the labor cost. Labor will need to be paid by the homeowner. If the boiler is more than 20 years old then it is a no-brainer, replace it, the increased efficiency combined with the age of the existing boiler make it a simple decision. Oil boilers especially are very much on a down hill slope by 20 years, gas boilers are often in better shape even though the efficiency is way down from what today's are. So bottom line, replace if older than 20 years. For boilers in the 10-15 year range it is often a very difficult call. Work with your heating service expert to figure the best option and I would definitely get a second or even a third opinion.
The next cause of trouble could be a failure of the controls on the boiler. Once again I would go with the 20 year rule. Unless the control that failed is relatively inexpensive I would replace the boiler. Often I have seen that when one control fails other controls are soon to follow and the beast becomes a money pit. This is especially true of oil burners. Many new boilers now come with a five year full replacement warranty that even cover labor. Once again the really hard questions come for those boilers in that five to fifteen year old age bracket. The questions get even harder when you are without heat, it is freezing outside and you do not have the time to get other opinions. At this point you have very limited options. Do make sure that you get a cost for the repair before you give the permission to fix the boiler. Electrical controls are not returnable once they have been installed. So once installed you bought them.
Questions about boiler failure and replacement are many. This should give a brief overview of the options that are available for the homeowner. There are many variables and often no answer is the completely right one. Many things depend on the situation of the homeowner, the age of the boiler, the cost of the repair, and the efficiency of the existing boiler as opposed to the efficiency of a new boiler. Many times that all adds up to a judgment call between the homeowner and the heating company.
on Dec 06, 2009 | Heating & Cooling
Yesterday, my Keurig was giving me trouble with the menu, but it still made my coffee. That was the first time my coffee machine has ever given me trouble over the nearly year and a half I've owned it....
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
Jul 05, 2011 | Keurig Elite B40 Coffee Maker
Ok guys this is my own opinion on descalling and I have to tell you firstly I have been repairing saeco machine for over 8 years so I think I know a bit about them by now. Scheduled Descalling to me is a waste of time and money, now I'M NOT saying to "never descale your saeco" but when that descale light or word comes up on your machine it does not necessarily mean your machine needs to be descaled. Your Saeco machine DOES NOT have a magical sensor inside that tells you there is calcium build up inside the boiler. All Saeco machine use a timer device built into the Electronic main board. As a pre set number of coffee's are made, Saeco has set a timer to bring up either a light or Symbol on screen to tell you your machine is in need of a descale. Now with different countries , States and living conditions not all water outlets consist of the same water purities, so how can Saeco say at a certain time your machine needs descalling? . I can only go by experience where I repair machines in Australia (Melbourne) and I have had many machines fail due to being constantly descalled. How many of you have been having a good run from your machine until the day you thought you had better off descale your magic deluxe as it hadn't been done in a while. Upon descalling the machine you hear and see water leaking from the unit and Bang , the machine stops dead , or if your very lucky you shut the machine off just in time before the circuit board gets wet and you send the Deluxe to Saeco and now your up for a new boiler and service.
What had happened is that in time the seals of the boiler have broken down and the calcium lining the boilers internal walls have been sealing the boiler from leaking. Upon cleaning the boiler , calcium is removed and the seals don't hold and you know the rest. I have personally given a machine to a family member and told them never to descale just to see what happens ( will the boiler go , or water stop flowing due to blockages? ) I can honestly tell you that this machine was made in 1996 and I had replaced the boiler 8 years ago , to this day the machine has not missed a beat and no leaks on boiler. Ah they hardley use it I hear you say , quite the contrary , Italian family, machine used every day and even taken once in a while to their local social gatherings making coffees for over 30 people. I also have a customer who every so often after 2 years will come back for a new boiler fitted ( machine used in pannel beating shop ) I told him to try not doing any descaling until he could see any water flow restrictions. It's been over 3 years now and I havent seen the machine back yet but I do time to time come across him and ask how the Saeco is going , he says "all is well". Now not doing a descale at all is madness as I have had many blocked or semi clogged boilers due to high calcium deposits ( expecially around the beach coast areas ) But if you feel that your machine is pumping a little less water and the brewer is clean form any blockages then a well deserved descale is probably needed. With older machines you only need to reset the descale light or display if not needed. With other types like Saeco Incanto you need to only go through the descale process without the additive or cleaning fluid introduced into the water tank and decsale will reset.I hope I have shed some light on this issue and I'm not trying to say Saeco are pulling the wool over your eyes when it comes to descaling. I am going by my experiences only and what I have seen during my time with these machines. Enjoy your Coffee.
Mar 12, 2010 | Saeco Magic De Luxe Espresso Machine
I have Saeco Vienna digital coffee machine already for 7 years. It was working fine but now I have problems. Only small amount of water/coffee goes to the cup and rest (clear water) goes to the tray and...
You boiler is leaking. You need to replace the boiler. sorry. Your water hardness might be set to low if you have been descaling when it tells you to. Boilers usually last 7 to 10 years, but need to be replaced. If you need one let me know. I have some new and rebuilt boilers for that machine.
Mar 08, 2010 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna Coffeemaker won't heat/reach 'ready' state
May be time for a new machine.
Its either the electronics or the boiler, or worse. Both.
Vienna's have a typical life expectancy of about 4 to 7 years. 10 years is very commendable.
If the electronics and boiler are both bad it will end up costing almost as much as purchasing a new machine.
Aug 08, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Magic Deluxe water leak
Hi Boilers leaking are usually a sign of not descaling enough. It is not recommended to take apart your machine unless you have knowledge in electronic repair. There are a lot of wires and hoses.
Once the boiler starts leaking it needs to be replaced. email me for directions since it won't fit on this page.
Mar 04, 2009 | Saeco Magic De Luxe Espresso Machine
Overheating and heater bloing cold air
a coolent pressure test will tell you if its a head gasget or maybe aleak someware else. if its head gasget it will either fill up cyl.or go into oil pan. its posible to be intake gasget too. pressure test is in order.
Jan 27, 2009 | 1989 Cadillac Brougham
How do i descale
I had the same problem. I own 2 of the same machine. They have a limited life and need to be refurbished every 2-3 years. As far as I know there's only one guy who does this. He's in Vancouver WA. His company is Espresso Resource Northwest......Here's the link: He does great work at a very reasonable price. He also sells refurbished versions of your machine for about half the price of a new one.
Nov 27, 2008 | Saeco Magic Comfort Plus Espresso Machine
Water leaking into machine
This happens when the boiler develops a leak, usually due to scale buildup. Order a new boiler and o-rings and replace.
Sep 29, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Royal Exclusive 30153 Espresso Machine Logo
243 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
