Picture goes out but the sound stays on
I have an R52WH74 RCA projection 52" HDTV. Turns on just great then in about 10 to 15 mins, the picture goes out but the sounds stays on, please help.
  • deleon2349 Dec 30, 2008
    I'm going to check to see if the lamp is overheating due to dust in the vents and need to be cleaned or just replace the lamp. My TV is a 2006 model.
    R52WH74 model RCA rear projection HDTV, 2006. Please help, anymore suggestions? Joe.
    Guru:
  • 449 Answers
That's one of the common symptoms, may run 5min to a few hours then no picture but sound stays on then back on in 45-60 seconds. lamps are easy to change but, and i cannot stress this enough DO NOT GET A GENERIC LAMP!!!! use only the original lamp, the cheap knockoff lamps are all over the internet & they are junk - when the factory (sylvania or osram) build the lamps they are tested and graded, the "A" grade lamps are sold as OEM parts but the poor quality parts (that failed inspection) are sold to other companys who repackage them then sell "SAME AS NEW" - 99% will fail within 2 weeks.
Posted on Dec 30, 2008
  • 13,433 Answers
Hi
it might be either a problem with the lamp or the lamp overheating. how old is the set how many hours do you suspect you have used the lamp for? might be time for a replacement.
some people have reported success in cleaning the tv from dust it improved the airflow so it might be a overheating issue or lamp failing. if its not a lamp issue it will require a professional inspection. the issue maybe in the power board, can't say over the internet.
I have a RCA R52WH74. When you turn it on there's
replace the deflection board. You need the ITC222A deflection board PSB-260 you can get a replacement deflection board from www.tvrepairworld.com which also has the CD that shows how to remove the old board.
Apr 11, 2010 | RCA HD52W56 52" Rear Projection HDTV
R52wh74 fades to one color then dark, then black
awewryte,
I have the same TV and now have the identical problem that you described. Did you ever get it fixed or find out what the problem was? If so, will you please pass the information on?
Thanks.
Aug 08, 2009 | RCA Televison & Video
RCA r52wh74 tv powers on then powers right off
one solution to maybe solve the problem of it not staying powered would be to take the panel off the back and use a blow dryer in the lower left hand corner and heat it up. It worked to get our tv turned on.
Jun 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Tv picture goes off but still have sound.
Resolder all poor connections on power supply board and this should fix your problem.
Feb 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" D52w20 problem
My goes off a few seconds after turning it on. It does make a funny sound, like static on the tv.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
HDTV R52WH74 TV WILL NO TURN ON
I would contact RCA support, and they should be able to provide you with the authorized RCA service centers in your area.This is the RCA customer Service number 580-634-0151
Jul 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
