Question about Samsung Syncmaster 192N 19" LCD Monitor
Samsung SyncMaster 192N loses picture; requires re-boot
I have had this monitor for maybe 3 years -- NEVER a problem. Normally it goes black upon "hibernation"(?) when left on for awhile, but the green light is still on and a swish of the mouse brings the display back quickly and beautifully. All of a sudden yesterday the display *NO LONGER* comes back from hibernation -- I have to hard-REBOOT it, blind, whereupon the display comes back just fine and asks me for my password, etc. and it works -- until I leave it for a small length of time and it goes BLACK again, and the green light is on, but my mouse can't engage it. [Otherwise, the mouse is just fine...] I am very concerned that I could have something important on the screen, get distracted, and then really screw things up as I would be flying blind and yet maybe... Perhaps I caused this by unintentionally changing a setting somewhere? I'm definitely NOT a techie... any words of wisdom for me? Thanks, Chris
  • 589 Answers
Unfortunately, you two have two unrelated problems. CB, the monitor isn't asking you for the password, that's the computer itself going into hibernation, which shuts down the video output, hard drive, etc. You need to go into the power-save settings and either disable hibernate, or change the settings to your liking.
The other question about the screen staying on for 5 seconds... thats an inverter board problem.
Posted on Jan 08, 2008
  • rebates111-3 Dec 23, 2010
    I'm experiencing the same problem as cb-nickname, where the screen on my SyncMaster 192n goes black, and the only way to turn it back on is by hard re-booting my computer; sometimes even ctrl-alt-del doesn't work, and I have to turn off the power strip several times. It didn't used to act this way; a simple mouse-swipe used to re-activate it.
    When the screen does come back on, it usually works fine, so it's not the same problem as the second poster. I decided to run an experiment, and hooked up a different computer tower with a different OS to the monitor, and the same thing happens after several hours. To be sure it's something with the SyncMaster and not my computers, I dragged up my old CRT monitor, and both computers and old CRT monitor operate perfectly well.
    I don't understand why I should now have to disable hibernate on my computer in order to resolve the problem, when I didn't have to do it before...is there any way to do a power-save setting, or am I just going to have to power-down every time I step away from the computer for a couple of hours?
I posted my "comment" and detailed explanation of the problem above, and afterwards, went back to see exactly what my power-save settings were....Hibernate was NOT enabled in the first place. Any other ideas of what the explanation might be, given that the Syncmaster monitor didn't behave this way when it was new?
Posted on Dec 23, 2010
I have the same problem with my Syncmaster 192N. I can hit the power button on the monitor and the picture comes back for about 5 seconds...then black screen. It just won't stay on. Hopefully someone knows the answer.
Posted on Jun 01, 2007
SOURCE:
My monitor stays on for approx. and goes off. Taking the power off for a few minutes, it goes back on for a few minutes then goes off agoin. What is the problem?
Seen a spate of these issues of late, I'd think its caused by failing Power capacitors, either bulging or blowing or leaking. You need to get this checked by a technician or TV repairman
Dec 30, 2010 | Samsung Syncmaster 192N 19" LCD Monitor
After several hours of inactivity, the screen on my SyncMaster 192n goes black, and the only way to turn it back on is by hard re-booting my computer. Sometimes even ctrl-alt-del doesn't work, and I have...
My guess is your video card driver has been altered and is causing the problem. Try rolling back the driver before reinstalling the monitor. Here is a link to the manual for your monitor: http://www.flatmonitors.com/Samsung170N.pdf
From the above manual: "The PowerSaver system operates with a VESA DPMS compliant video card installed in your computer. Use a software utility installed on your computer to set up this feature".
FFFF
Mar 18, 2017 | Samsung Syncmaster 192N 19" LCD Monitor
Can't find the place to put in speakers for syncmaster 192n monitor
lemoncaketre, 192N is basic VGA only type monitor!!!! No AUDIO capabilities!! Use a set of external speakers for audio!!!
12fixlouie
Sep 14, 2010 | Samsung Syncmaster 192N 19" LCD Monitor
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
Samsung SyncMaster 713BM
Hey!
Follow the instruction below to solve your problem:
Restart your computer and enter Safe Mode (press F8 right as the computer starts booting up. Choose Safe Mode in the menu, press Enter twice).
While in Safe Mode, open Control Panel and go to Add/Remove Programs (Programs and Features on Vista/7) and uninstall the display driver software/drivers.
Restart your computer and boot normally. Now you should be able to see everything. Things might look bigger and uglier, that because there's no display driver installed. All you have to do now is reinstall the display driver. Use it's original disc or go to the manufacturer website and download the latest driver.
Pelu.
Mar 27, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
I have an old Samsung 192N LCD computer monitor, and I have been having problems with it. There is a large black, vertical bar about the size of my thumb on the side of the monitor. I don't have a cable to...
you need to repir the power supply and replace the screen. the power supply may have had bad capacitors on it . crowned or leaking. it will be cheaper to replace the monitor with a preowned on rather than repair it
Dec 25, 2009 | Samsung Syncmaster 192N 19" LCD Monitor
Syncmaster 226CW showing picture only for a second + flickering
Call and get the RMA for your monitor, the problem is in the power supply and it will only get worse. This is a common problem with LCD monitors after 2-3 years of use.
Buddy
Corporate Computer
www.ccl-la.com
Oct 17, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Screen went black while i was on it and i have not gotten a picture since
try this first if you disconnect the cable and you get warning on the screen that the cable is disconnected,chances are the monitor is still good,next you might want to check if its set to digital or analog,
Good luck
Aug 26, 2009 | Samsung Syncmaster 192N 19" LCD Monitor
My three year old Samsung SyncMaster 192n keeps turning off. If I unplug the power supply and plug it back in it will turn on for a while. Any suggestions?
You need to replace either the caps or the inverter board. You may require an assistance from a repair person in replacing it. Check this link so that you could see how the inverter board looks like:
http://www.shopjimmy.com/catalogsearch/result/index/?q=inverter+boards&stock=all
Have a good one!
Jun 23, 2009 | Samsung SyncMaster 192 T (Silver) 19" LCD...
Samsung Syncmaster 192N 19" LCD Monitor Logo
585 people viewed this question
Top Samsung Computers & Internet Experts
asber
Stormi  Paulk
Stormi Paulk
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
