I had my EMachine desktop in storage for a year and when I got it out and hooked everything up it now says I need a password to get into the computer. I have tried every password I could think of, to no avail. Is there a way to override this without losing the other things I have in my computer??
SOURCE: system recovery
hello,
Yes, everything will be lost when you use system recovery, but if you can do backup you files in your computer, you can do system recovery., So if you cannot back up your files maybe i suggest you to scan your computer online. www.precisesecurity.com/antivirus/online-scan.htm
and then uninstall all the unwanted programs, after scanning you should install antivirus, i recommend AVG, free edition, (search in google)downloadable. if you connected to the computer.
but if you has been backup you can proceed to system recovery using the CD installation disk.
may this help, melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
SOURCE: forgotten log on password
Well you can use the admisintrator account you set up to begin with or any other account that has admin abilities to change the password. But if you dont have that then you will have to hack the password to change it.
to do that go to source forge and download ophcrack live cd http://ophcrack.sourceforge.net/
and burn it to cd.
Then boot to the cd. (put it in the drive and rebioot then hit key when asked to boot to cd. you may have to go into your bios and activate cd as a boot device.)
Then it will start to crack the password (I say crack for a lack of a better word)
Once its done you chould see a list of passwords found.
Write down the one you need and then reboot the computer without the cd in the drive.
Then when it asks for password use the one you wrote down and then imediately go to users and change the password to something you will remember.
hope this helps.
SOURCE: Hooking up printer to computer
As long as you have a suitable connector, either USB, the new standard or a parallel port (old) and an appropriate cable, it should work fine. I'm not sure if E-Machines even sells printers, and if they do, they are most likely made by someone else.
SOURCE: Administrative password override!
http://trinityhome.org/Home/index.php?wpid=1&front_id=12
you should be able to do it using the above, if not then use orphcrack
SOURCE: i have a emachine computer desktop and a lexmark
Hello my friend if your printer has usb connection or parallel connection yes it will be OK but i don't know about the drivers because you don't mention what operating system you have but i think will be OK.
Bypass eMachines password with recovery disks created before lost eMachine password
When input an incorrect password at the login screen, click "Reset Windows Password" and insert the eMachine password reset disk. The Password Reset Wizard will lead us create a new password to remove forgotten eMachines Windows 7 password.
Retrieve eMachine Windows password by DIY a password reset disk after forgotten
It is considered as the most instantly and easiest way to recover lost eMachine password. A .iso file, bootable CD/DVD/USB disk and accessible PC will solve problem within minutes without special techniques for a green hand on PC.
We can get the .iso file from many Windows password recovery programs. Just take one of the most popular tool - Ainorsoft Windows Password Recovery as example.
A. Download the suitable Ainorsoft Windows Password Recovery program and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible computer;
B. Boot the burned CD/DVD or USB Flash Drive from the PC password locked;
C. Reset the new eMachines password.
Ainorsoft Windows Password Recovery tool concludes Basic, Enhance and Corporation versions. The Basic is opted for Windows 7, XP, Vista, 2008, 2003,etc. CD/DVD disk suits for it! The Enhance version can be used with USB disk for the former OS. While, the Ainorsoft Windows Password Recovery Corporation is designed to Windows 7/Vista/XP/2000/NT/Server 2008/2003/2000 with bootable CD/DVD or USB Flash Drive.
Main methods on eMachine password reset are shared as above. Recover forgotten eMachine laptop password from Safe Mode or unlock eMachines password with password reset disk. Hope the any one help our eMachines computer users!
Article source: http://windowspasswordrecovery.net/article/emachines-password-reset.html
