Question about ASUS P4VP-MX Motherboard
Sound card drivers can not installed
I have installed a creative vibra128 sound card. I disabled the onboard sound and windows detected the new hardware and it installed the generic drivers. But i cannot listen sounds and can not installed the drivers came with the sound card. when i go to install drivers it says can not find any vibra card in your system. But windows can recognize the new hardware.
main board is ASUS P4VP - MX
OS winXp Professional with SP3
    President:
  • 948 Answers
Your card isn't supported by Creative anymore, it is too old. As such, you would have better results by using a newer card. But the drivers are located here - http://support.creative.com/Products/ProductDetails.aspx?catID=1&subCatID=207&prodID=4851&prodName=Vibra%20128&subCatName=Others&CatName=Sound+Blaster
Posted on Dec 28, 2008
I can't installed it
Windows XP should load drivers for the card automaticly, you may want to upgrade you system to SP3 if you havent already, Go in BIOS before start up and uninstall your onboard Audio driver under Onboard Periferals, click disable/turn it off, If you have an XP instulation cd you may be able to point windows to the Legacy driver.
Jul 17, 2012 | Compaq Creative Sound Blaster PCI 128...
What should i do to get my sound device and controller?
Hi riteshscorpi,
Since you have a multimedia audio controller or Sound Card installed to your motherboard, reboot your PC and enter the CMOS/BIOS setup and disable the Onboard Audio.
Save your new settings.
The PC should immediately detect your Sound Card and ask for driver.
Install the Sound Card driver completely and reboot your PC.
Finally, configure the Audio properties to your desired adjustments.
Hope this helps you a lot.
Thank you for using FixYa!
Oct 30, 2011 | MSI 945GZM3-L (7267-020(945GZM3-L))...
I have a sound blaster audigy 24 bit 7.1 sound card . it worked fine on windows xp but when i inserted the card in the slot for my new computer on windows 7 it says that no card was found :/ when i install...
Move the card to a different pci slot on the motherboard. It may have a conflict with another device. Make sure there is no power to the pc when you do this. If you still have the problem after trying all the slots then i suggest you empty all of them and just try the audio card on its own. If it works then fit the card/s you removed into other slots. good luck.
Apr 27, 2011 | Creative Labs Sound Blaster Live 7.1...
My computer no sound after installing windows xp my mother board ECS P4VXAD
You need to install the driver : http://support.creative.com/downloads/download.aspx?nDownloadId=1843
or you can use your onboard soundcard from your motherboard (your motherboard already have onboard soundcard)
cheers
Feb 04, 2011 | Intel Creative Labs Sound Blaster 16 PCI...
Sound card not working...already downloaded & installed the driver but still not working.
Is it a card in a PCI slot? If so does your motherboard already have a soundcard? You'll have to disable it if so to make the PCI card one active. Having 2 sound cards confuses windows, you need to tell it which to use...
To disable the onboard either look in the bios settings or go to device manager, find the soundcard in the relevant section and then right click - disable it...
If that's the case it should be ok but try loading up windows media player and going to the preferences seeing which sound card it is trying to use. Usually if you can get media player working everything else will work
Jan 17, 2010 | Gateway /Creative SoundBlaster Sound Card
No sound (AsRock P4 Combo)
1.
Check the speaker connections - take the plugs out and put them back.
Make sure the speakers get power.
Test the sound with headphones.
If it is a Laptop be sure the speakers are turned on (Usually an Fn function key).
2.
Load a system restore point from a date before the sound problem started.
3.
Has the audio service been started by Windows?
Click Start > Run > type services.msc - then click OK.
In the new window - Scroll down to "Windows Audio", right-click on it and select Properties.
Another new window - set the startup type to Automatic, click Apply and then click Start.
Have a look in "Play control" and any other sound mixer you may have installed to check if the sound is muted.
Go to Control Panel >> Sounds and Audio Devices.
Check to see if your sound card is listed.
If no audio device is detected proceed to step 5.
Be sure the Volume is turned up (at least half way).
The MUTE box should not be checked (go to the advanced window and make sure that nothing is muted).
Select the proper speaker settings under speaker settings advanced tab.
Set the speaker setup settings accordingly.
Is your sound card the default playback device?
Right click the speaker icon next to the clock >> Choose "Adjust Audio Properties".
Click on the Audio tab and select the correct device.
If you make any changes - click Apply, then OK before you close the window.
If you use another type of audio program, please refer to that program's trouble shooter for diagnostics.
Creative Sound Card owners can try this:
Click Start >> Programs >> Creative >> "Sound Card", for example Audigy >> Creative Restore Defaults.
4.
Check to see if the sound card is properly installed in the Device Manager.
Right click My Computer >> Properties >> Hardware Tab >> Device Manager >> in the "View" menu - click "Show hidden devices".
If there are yellow or red "marks" next to the audio, "Microsoft Universal Audio Architecture (UAA) Bus" or an unknown device - install drivers (see step 6).
If Windows does not detect an ONBOARD (Integrated) sound card >> Check to see if it is ENABLED in the BIOS (Setup).
If Windows does not detect a PCI sound card (an Added sound card) >> Shut the computer down, disconnect power. Take the sound card out and put it back again - if possible, use another PCI slot.
5.
Install available Windows updates, including DirectX.
Go to Start >> All Programs >> Windows Update.
6.
Installing drivers:
6a. Install the chipset driver first >> Reboot.
6b. If a "Microsoft Universal Audio Architecture (UAA) Bus" is present in Device manager >> install the driver >> Reboot.
6c. Uninstall old sound drivers:
Check in Add/Remove Programs in the Control Panel for an Audio device driver (i.e. AC97).
Go to the Device Manager and uninstall the driver (Right click on the device >> uninstall).
Install the sound driver >> Reboot.
The drivers to install can be found on a CD that came with the computer/motherboard/sound card.
Jan 12, 2010 | Asrock (P4COMBO) Motherboard
Sound driver is properly install but the voice is not come out .please give your suggestion.
when installing the drivers check that the drivers are related to that hardware only. some drivers from other sources will install but will not work correctly.
if you have installed drivers from the original cd that came with your motherboard(if onboard sound) or the sound card (pci card). then let windows search for the driver in the cd. you don't select the particular driver.
first uninstall the drivers you currently have and then reboot the sys and wait for the system to find for the new hardware device. then choose the option
-> search in the removable media
and then insert the cd.
if this doesn't solve the problem.
check in the bios settings, advanced option that onboard sound card is on for onboard sound
and this is off for internal sound card.
if your motherboard has Realtek sound card then go the site and download the new driver. check the correct ALC codec.
if you are using internal sound card like creative. then download the updated driver.
and also check in the control panel of windows of the "sounds and audio devices properties"..,
in the first tab your sound card name should be visible and in the third tab in default device your audio card name should be specified.
hope this helps
Apr 19, 2009 | Intel 845GE Motherboard
Sound
i need soundmax for my orange pc
Mar 27, 2008 | HP Compaq d220M (829160054797) PC Desktop
Problem with Windows XP recognizing Creative Sound Card
It sounds like a software problem. Though you did the right thing by entering the bios & disabling the onboard sound. That should have been enough. Did you uninstall the old intergrated sound drivers before adding the 24bit card? Just about all the drivers & upgrades for your 4600 through Dell is Creative software & thats why your having a tough time. I would put everything back to how it was. Re-enable the intergrated sound & reboot! Run system restore & check that every thing is running right!! Look at this dell web site for the sound drivers you have at this link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
If you must, install a upgrade for your intergrated sound. Just so you can uninstall it after a reboot. Re disable the sound in the bios. Do not install your new card yet. While back in windows device manager you should be missing a PCI device. Shut down install the new sound card. Hopefully windows will want the drivers & all runs fine. If still no it could be a bad card (i know what your thinking but it's possible). The only thing left is the regestry is using the wrong PCI device.
Dec 26, 2007 | Creative Labs Sound Blaster Live! 5.1...
NO Audio even after putting in own sound card
Difficult to diagnose from afar but go to Start>Run, then type 'dxdiag' without quotes and see if; when it does a sound and video test anything shows up.
Nov 13, 2006 | Gigabyte GA-8IG1000 Motherboard
ASUS P4VP-MX Motherboard Logo
166 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
