Question about HP iPAQ h3970 Pocket PC
Ipaq H 3970 storeage card problem
I am trying to use a new 2 Gb memory card, but after several attempts to format it, my Ipaq still cannot see it. Any suggestions??
    Novelist:
  • 198 Answers
Hello lenze123, Your Ipaq doesn't support cards larger then 1gb. I'm not shure that a ROM upgrade will fix this as larger cards require different voltage settings and firmware protocols. From the technical specifications of the h3970 it is stated that the pda will support only 1gb cards due to it's hardware configuration. A reset woun't help you on this. The only thing you could try is a ROM update to a later windows version, win2003 or 2003se, but even this may not solve the problem. If you need more informations please reply.
Posted on Apr 25, 2007
Try soft resetting the unit, then try to access it afterwards. Hope that helps
Bought a sony dsc h300 camera about 2 years ago...bought a Kingston Memory card for it....what do I do now ?
Have you tried formatting the new memory card? Sony suggest you format a new card using the camera.
Supported capacity:
  • Memory Stick Duo" media: up to 64 GB
  • "Memory Stick Micro" media: up to 16 GB
  • SD card: up to 64 GB
  • microSD memory card: up to 64 GB
You may also want to check the camera's user guide to narrow down what's causing the card not being detected.
http://docs.esupport.sony.com/dvimag/2014/DSCH300_guide/en/contents/12/01/04/04.html
Jul 08, 2017 | Sony Cameras
ION Pics 2 SD- Will not accept any memory cards. It says "New Memory Card Detected, Please restart." Bye. Then it shuts down. Anyone else have this issue or know how to solve it?
IF you can put that SD card in a computer then you can use the computer to format the card and then try it again. There are two format types so try them both.
Oct 04, 2014 | ION Audio ION PICS 2 SD Photo Slide and...
Cha flashing when new memory card inserted... have tried several to no avail... please can you help?
CH A error indicates that the camera can not communicate with the memory card. Most often this is caused by formatting a memory card in a computer and then putting it into the camera. (Especially on 4 + gb cards). Solution is 1. Reset the camera - then it should work with cards that it worked with in the past. 2. Take the bad memory card and reformat it in your computer to FAT not FAT 32.
It should now work - although it will show capacity to be only 2 gb...
I believe at that point, if you reformat it in camera it will work at the full 4 gb.
Oct 22, 2009 | Nikon D2X Digital Camera
I have a new 2 gb dane-elec memory card and when i turn on my camera it says the memorty card is full and when i try formatting it it says filesys error e00100
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
May 22, 2009 | Kodak EasyShare C330 Digital Camera
Filesys error e00100 when attempting to format a Scandisk 2.0 gb memory card.
Hi ,Welcome
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 02, 2009 | Kodak EasyShare CD33 Digital Camera
    My Kodak EasyShare C315 needs formatting.
    For all the camera users whose cameras won't format...they can't accept all the info on a 2 gb memory card... install a 1 gb card...worked like a charm for me! C315 and others were made before the 2 gb card. Only 1 gb cards work in the older cameras.
    Tami
    Dec 27, 2008 | Holga Flash, 120 Medium Format Camera...
    HP ipaq with navtec gps software and sd card fails
    Ok, nice job Robert,
    I'm posting your solution here to remove it from the unsolved problems list.
    Solution by Robert:
    This problem was finally resolved as a corrupted map file on the SD memory card in the hp ipaq 5550. Solution was to reformat the memory card using fat32 memory format. I used a SD memory card slot on my laptop and right click the drive letter and select format to format the memory card. After that, I reloaded map files to the memory card and all was OK. Note that previously I had loaded map files on the memory card successfully but that was not good enough. A reformat of the memory card was apparently needed.
    I had also previously tried a hard full reset of the ipaq by pressing and holding the lower two buttons (calendar and itask) while holding in the reset button with the stylus for 5 seconds and resynced my contacts and reloaded the gps software, but this was to no avail. Try the re-format.
    Jun 22, 2008 | HP iPAQ H5550 Pocket PC
    Compaq ipaq 3970
    Have you tryed to reset it, theres a small hole in the bottom
    http://pocketpccentral.net/help/ipaq38xxreset.htm
    Nov 03, 2007 | Compaq iPAQ H3955 Pocket PC
    Ipaq won't recognise sd cards help!!
    did you install the following: "iPAQ H3970/H3975 SD Card Driver Updates version 1.1 (27 Oct 03)" SP25681 - Resolves performance issues with SD memory card. - Resolves undetected SD memory card. - Resolves lockups due to SD memory card.
    Sep 14, 2005 | Compaq iPAQ H3970 Pocket PC
    HP iPAQ h3970 Pocket PC Logo
    179 people viewed this question
    Top HP Computers & Internet Experts
    Alun Cox
    pankaj rautela
    pankaj rautela
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
