When key is turned to run position there is a buzzing noise from one of the relays. no power to starter when trying to crank.
the first thing that I would check is to make sure your battery is fully charged or try and jump the battery using another car battery.
if still no go then I would say that your starter solenoid is bad.
while checking the solenoid/starter double check to make sure your block to body ground cable is secure.
hope this helps,
chris...
SOURCE: intermittent no start. Battery/charging system ok
If it intermittently starts, the battery/charging systems are ok and you hear the relay click, I would suspect a starter going bad. When the engine won't start have some one hold the key to the run position (as if you were cranking the engine) and tap lightly on the starter housing with a metal hammer. Be careful not to hit any of the wires on the starter. If the engine starts cranking and or starts, the starter is going bad. Chances are the armature is burn't or the brushes are worn out. It is usually cheaper just to put in a re-man starter then trying to rebuild it. And since the car is relatively new, chances are you won't be able find parts for it. Now a word of caution here, when you are tapping on the starter be careful not to be next to any moving parts (pulleys, belts, etc) since the engine may start. Also another thing you could check for is loose power cables. You might want to try this before checking the starter because it's easier. Try wiggling the battery connections, follow the negative to ground and wiggle and do the same thing with the positive cable to the starter. You should not be able to wiggle the connections at all. If you can the connections will need to be either tightened or the connector replaced. This should solve your problem. You could also try swapping your relays around and see if this fixes it (just because a relay clicks dosen't mean its necessarily working right.
SOURCE: starter relay clicks when you turn ignition key on
I would think bad starter. Remove it and have it tested to find out. It could also be the starter solenoid gone bad.
SOURCE: 01 dodge caravan new starter battery full turn key
try lookin at the wiring harness under the battery tray,seen them corrode there alot
SOURCE: no start condition new battery , good starter,
no starter relay is always at the fuse relay box at the engine compartment. The relay that you hear is the relay for the accessories to turn off the power during starting position.
SOURCE: location of fuel pump relay Mercedes 300E 1993
you need to remove the cover behind the battery .
fuel pump relay ( K27 )
I hope this can help you.
