Question about Kenmore 24032\24036 Top Load Washer
Kenmore top load washer approx. 10 years old
Water is leaking out from bottom of washer. I filled it on small load with no clothes in it to see if i can detect where it is coming from...is ok for a short period of time then starts running out from the bottom during fill, and during rinse, not sure during spin, but, spin does work to get the water out of the washer. any ideas?
  • 2 more comments
  • gjb0616 Dec 28, 2008
    so this could allow the washer to leak during fill ? From the bottom?
    Just making sure i understand this. Model number is 110.23032101 Kenmore Elite. I pulled up a pic of this model on sears.com and i can not seem to find this part on the diagram. I am still looking at this point. Hoping it would be cheaper to get parts and fix it instead of having a repairman come out or purchase a new washer.
    I spun the water out with no problem so i know spin works fine. And from looking at it from the top and the bottom, i can not detect that there is a hole in the tub. Wish i knew more about how these work. Thanks for your help!
    thank you so much for taking out time to help me out. Let you know how i make out later this week.
    thanks again!
  • smburns22 Dec 30, 2008
    I believe I have a similar/same problem. It appears there is a slow leak coming from a little plastic pump assembly at the bottom of the washing machine. I assume it a seal that is going bad but I am not an expert. I did not follow the resoluion for the issue. Could you resend the response?
  • helenebergma Jan 03, 2009
    when I run the hot water side it leaks massive water through the bottom of the machine, so I use cold only and this has mostly stopped the problem, I think it is a worn hot water o ring or gasket, close, or no cigar?
    thanks
  • Kenmore Master
  • 8,220 Answers
kenmore top load washer approx. 10 years old - f7686aa.jpgPump is leaking around the drive shaft.
To get to the pump CLICK HERE
Posted on Dec 28, 2008
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
My Kenmore Elite washer will not fill.
yes there is a water inlet valve . it is the blue valve your water hoses connect to on the rear of the washer, they get sediment built up inside and get stuck , cost $26.50 from Repairclinic.com just go to site .find parts,then type in your model#
Jan 21, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Kenmore Washer leaks
When my husband came home he took the washer apart and it was the pump. Small pin hole leak in this glob of gray sealer that seals the two plastic parts together. Just been waiting to fail, I'm sure. Thanks for your help.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
Water problem
Apr 01, 2009 | Washing Machines
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series overflowed!!!
The most common cause for this is the water mixing valve plunger sticking. the fix is to replace the mixing valve. Not so common is a defective water level pressure switch. Same fix, replace the switch. Really rare is a small leak in the tube from the tub to the pressure switch.
Feb 06, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Kenmore Clothes Washer leakes when filling,it's a top loader.
When you say it is leaking when it is filling, where is it leaking ? Inside or outside the machine ?
I'lll try to help once I know the answer to the above
Jan 01, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
229 people viewed this question
Sal De
fordexpert
Robert Rankin
