Pc doesnot detect the device.
I bought a brand new Sonny MP4 MP5 player, when i connect it to the my computer, it does not detect it. Win XP 2002.
Can some one help me please.
My sony mp4 cant detect in computer so please give me driver for this
Posted on May 29, 2009
Cant install u-disk to pc
Do you have internet access with this computer?
If so, you should be able to google the brand and model number and find a driver to download.
I would give that a try.
There is no need to reinstall windows to fix this. The driver or inf file is damaged. Visit another computer with win xp, search for files named usbstor. Copy files usbstor.inf and usbstor.pnf into windows/inf folder and usbstor.sys into windows/system32/drivers. Now just search for new driver and that's it, usb storage will be recognized.
Car Transmissions
Jun 12, 2012 | Audio Players & Recorders
Hi, my pc don't read the mp34 audio player =( help!!!
Why is my mp3 and mp4 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see mp3 and mp4 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the mp3 and mp4 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: mp3 and mp4 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 and mp4 Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for mp3 and mp4 Players when used with Windows OS.
The mp3 and mp4 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
May 05, 2011 | Digital Audio NAP256 MP3 Player
My mp4 mp5 device doesnot be recognised please may you help to solve the problem
MP4 Player If your are not an audiophile and don't care much about audio/video quality, cheap chinese ... Microsoft Windows Vista Service Pack 2 Beta Is Coming. ... DriverMax - The Best Free Utility To Update Windows Device Drivers ....
Mar 10, 2011 | Microsoft Windows XP Professional With...
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
4. Power issue.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
STEP 1 - Connect the Sansa player to the PC
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
My Sony mp4 mp5 made in japan is hanging and con not be detected by the computer
look at the side of the mp4 mp5, you'll notice two buttons?(Hold and Reset)... just press the reset and you are good to go....
Nov 17, 2010 | Microsoft Windows XP Professional With...
I want to format my sony mp4/mp5 (PMP) made in Japan.it cant format on its own and when i connect to the pc it is detected but still it cant be formated and when i try to delete the files they are coming...
By lameckp on Sep 22, 2010
i want to format my sony mp4/mp5 (PMP) made in Japan.it cant format on its own and when i connect to the pc it is detected but still it cant be formated and when i try to delete the files they are coming back. please help?
Sep 22, 2010 | Sony HANDYCAM HIDEF 16GB MP4 FL MEM CAM 27...
Dv Mp4 Mp5 player cannot recognize by PC
Your younger brother should be doing your chores for the next month to repay you for wrecking your Mp4 player - I am guessing formatting it erased everything including the operating software.
The Mp4 player like most things is a small computer and computers are just so much junk if they don't have an operating system.
I fear your player will remain junk unless you can find a suitable operating system and persuade the player to accept it.
I suggest you contact the supplier for advice in the first instance, you could be lucky and find them helpful.
If that fails then asking around all the nerds and boffins you might know of could produce results, as could some general online research.
May 17, 2017 | Audio Players & Recorders
My PMP MP4 player's LCD screen is not working.
hi,
i dont think you can solve this very easily. try to do a firmware update of the player.
if the firmware update is no there then there is very little chance to clear this problem.
thanks you
Feb 08, 2009 | Audio Players & Recorders
MP4 Driver
i have club i-mate jaq3 mobile ...when i conect throgh usb ..it cant detect from pc...so may i know which driver needed to solve that problem..?
Jul 14, 2008 | Computers & Internet
427 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
