Question about Sony Televison & Video
Need to know the WEIGHT of Sony TV: KV-27EXR25
Trying to determine if a TV stand I have will support the weight of above TV. I don't have the User Guide which would provide this on the specification page.
  • 56 Answers
Most tv stands have a large range of rating. most range in increments of 100 lbs. The tv you have is around 40 lbs. so if your stand will support up to 100lbs. your good to go. also you didnt specify if this is a hanging stand or floor stand. I am asumming the previous as being a hanging stand. with that make sure you get the bolts into a stud as drywall will only support about 20 lbs. before ripping out.
Posted on Dec 28, 2008
Weight of sony 32S22
141 pounds and 12 ounces!
Your specs, manual and service manual are here. Weight is on page 26 of user manual.
Thank you and you are welcome.
Sony KV 32S22 Specifications
Nov 29, 2016 | Sony Televison & Video
I need to file a claim for damage to my Sony KV27V10. Problem is, it was purchased so long ago (over 10 years) that I don't know the purchase price at that time. I also need to know weight of...
Thank you for posting to Fixya.com and it is my pleasure to guide you.
I am so sorry for your problem. If you plan on submitting a claim with Sony, be ready to pay for the damage yourself because it is out of warranty. On the other hand, you do not state how the TV was damaged. If the damage occured by someone else, say you moved and the movers damaged the TV and you want to submitt the damage claim to the moving company, then that is a different story.
1. You would have to have only an estamate of damage,
a. Compare your 10 year old TV with one like it today. You will not need the actual receipt. If you can remember the cost, they probably will, that would be good or maybe you might have paid by check. Your bank may have a stored copy of your check, which they may charge you for a copy.
b. Take it to an electronic store and ask them to tell you what it would take to fix it.
2. You can determine the weight several ways.
a. Take it to somewhere that uses scales and ask them if they would weight it for you. Explain why and that you would be willing to pay if neccessary. They generally would say, not necessary.
b. Try to balance it on a bathroom scales by resting it on one edge, you may need help to hold it and read the weight.
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 15, 2011 | Sony KV-27V10 27" TV
How much does this model weigh? I want to buy a tv stand weight limit states it holds a 100 lb tv tops?
A 46 inch Sony LCD FlatScreen tv weighs around 90 pounds.
If you look in your own tv's user manual it will tell you its weight in the DIMENSIONS section.
Feb 06, 2011 | Televison & Video
Toshiba 32D46 - Need to know weight in order to determine whether tv stand will support it safely.
Hello
Your Toshiba 32D46 model TVs weight and diamensons are
Width: 29-9/16 in. (751 mm)
Height: 25-15/16 in. (658.5 mm)
Depth: 21-3/4 in. (552 mm)
114.7 lbs. (52.0 kg)
OK
Jan 02, 2011 | Toshiba 32D46 32" TV
Need to mount Sony KV-36XBR400 on a TV Stand. Unit weighs in at 236lbs. Sony discontinued the stand for this unit. Are there any stnds currently made that willsupport tis kind of weight? F....
There are industrial-duty parts carts and tables that will work, but I don't think you care to have gray-metal furniture in your TV viewing room. Check the local furniture stores to see if they have anything rated for this much load.
If not, perhaps you can get a cabinet maker to build a cabinet on 3" or 4" casters designed to hold at least 300 lbs (so you can keep other stuff in the cabinet). This will make the set much easier to manage if you ever want to move it. The casters can be hidden by a wood trim skirt. Ask for at least one metal angle brace under the top so the wood doesn't warp under the load.
Oct 24, 2010 | Sony KV-36XBR400 36" TV
Sony KV-32FS12 32" TV what is the weight on this TV set?
It weighs 165 pounds. Also, Width: 31.5 inches. Height: 27.88 inches. Depth: 23 inches.
Nov 28, 2009 | Sony KV-32FS12 32" TV
Trying to find a tv stand for this tv. what is the weight of the tv
  • Dimensions: 29" H, 30 1/8" W, 22 1/2" D
  • Approx. Shipping Weight: 120 Lbs. I would get a stand that gives you some extra capacity for safety. Measure the base of the TV so you know the dimensions of the sets "footprint" to know the dimensions you need for the stands shelf to accomodate the set. Good luck
  • Nov 25, 2009 | RCA F32648 32" TV
    TV weight
    The trick to lifting Large TVs' is that they are very 'front' heavy, that is, most of the weight is in the picture tube...recall the "problem" of unstable TVs' from years ago (Children pulling down TVs')
    If the TV is on the floor you can put a large pillow at the front (Picture tube face) on the floor & carefully tip the set forward onto the pillow. You can then measure the bottom of the set to see if it will fit on your stand. If you are concerned about the weight simply attempt to sit your body (180 lbs?) on your suspect stand..if it holds your weight your good...wiggle around to see how stable it is.
    _________________________________________________Rick......
    May 24, 2008 | Televison & Video
    Weight
    I have one of these TVs and still love it.  The manual says that the weight is listed at 250lbs (approx.).  Most of the TV stands in retail stores only hold up to 240lbs., so that is something to consider.
    Sep 23, 2007 | Mitsubishi CS-40503 TV
    Televison & Video Logo
    246 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
