Question about White Sewing White 3032
Broke a needle and now the bobbin thread won't pick up
If this is timing ,how do i fix it?
  • 56 Answers
This is something that is very delicate and requires experience to fix. It is a timing issue and sorry to say you are going to have to take it to a sewing machine shop to get it fixed. in most cases this is a small charge around 50-80 dollars to fix.
it would be way to complex and long to put everything here to fix it yourself.
Posted on Dec 28, 2008
My upper thread wont pick up the bobbin thread suddenly. How do I fix that problem?
Install a brand new needle. A bent/dull/damaged needle sometimes will not pick up bobbin thread.
Check that the needle is installed facing the correct direction.
Also check that the bobbin is wound smoothly, the bobbin is turning the correct direction in the bobbin case, and the bobbin tension is threaded correctly.
If it still will not pick up the bobbin thread, there is most likely a timing issue, ie the needle is arriving at the wrong time to intercept the bobbin thread. Search the internet for sewing machine timing discussions or take it for service.
Nov 03, 2016 | Sewing Machines
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
My Bernette 715 isn't picking up the bobbin thread and is getting jammed. Any ideas what's wrong?
First thing to always try: Install a brand new needle. A dull, worn, or bent needle will cause great frustration. It is also the least expensive resolution to most problems.
Second: Remove all the threads. RAISE the presser foot. Rethread from the beginning making sure it is threaded correctly.
Pull up the bobbin thread before beginning to stitch and hold the thread tails in the left hand while slowly taking the first few stitches:
How and Why to Bring up the Bobbin Thread
If still having issues with not pulling up the bobbin thread, the needle/hook may be out of time.
Feb 06, 2016 | Sewing Machines
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Needle won't pick up bobbin thread
check to make sure that the needle was put into the needle holder correctly
all the way up into the needle holder--flat side of the needle to the back side of the machine
if the machine still doesn't up the bobbin thread then
it's possible that when the needle broke that it caused the machine to go out of time which means it has to be retime at a sewing machine shop
Feb 28, 2012 | Sewing Machines
My Janome needle thread will not pick up the bobbin thread! I have checked threading and needle and bobbin case...nothing works!
Your Machine is out of time, you probably broke a needle or sewed over a pin. take the machine to your locsl deler to be re timed. about 90.00
Jun 13, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
My needle won't pick up the bobbin thread
My sewing machine is a Brother LS1217, well actually it is my son's, and he uses it very seldom. I went over to put in a new needle and I cleaned it top and bottom, put in a new bobbin, and a new needle and the needle won't pick up the bottom thread. What am I doing wrong? Please help me!! It has to be something simple, as this is such a simple machine! roseandjimmy@yahoo.com
Jan 11, 2008 | Brother LS-1217 Mechanical Sewing Machine
Needle will not pick up the bobbin thread
www.whitesewing.com try there web site
Feb 18, 2007 | White Sewing White 3032
White Sewing White 3032 Logo
241 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
