Question about Scosche Industries Scosche Slc4 Speaker High Level Converter
Installing an aftermarket head unit into a 1994 Ford Bronco
I've installed a Sony head unit into my 1994 Bronco using a wire harness, but I can't get my speakers to play. If I directly hook a extra car speaker from another system to the unit, it plays fine. But when I hook the unit to the wire harness, I get no sound to the factory speakers. Do I need some sort of adapter?
  • Anonymous Mar 13, 2014
    When i first installed the new HU i just hooked up the same color wires and it worked great except when i turned on my head lights. There is a orange dimmer cable (car side) that when hooked up shuts off my sound system when i turn my headlights on but when i don't connect it to the head unit everything works okay but no sound comes from my speakers
    I have a MVH-X560BT and when i first installed it i just hooked up the same color wires and it worked great except when i turned on my head lights. There is a orange dimmer cable (car side) that when hooked up shuts off my sound system but when i don't connect it to the head unit everything works okay but no sound comes from my speakers
  • 95 Answers
Are you using and after market harness to go from your bronco to the harness to the new radio. if so make sure all the colors are matched up (e.i. purple to purple, purple/black to purple/black). did the speakers work before the aftermarket unit. Also check the wiring at the oem speakers
Posted on Feb 17, 2009
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
How to get rear speaker signal from aftermarket stereo
You can fade front to rear in the menu but its not switched it might be fully faded to the front
Aug 31, 2014 | Pioneer Deh-X6600bt Car Cd Receiver...
NEED WIRING DIAGRAM
If you are referring to installation and have the aftermarket wiring harness, The wires should be color coded. RED, YELLOW, & BLACK are power, ignition and ground. These should correspond to matching wires on the back of the head unit (CD player). Match the colored wires from the back of the unit to the same colored wires on the aftermarket harness and then connect them using wire connectors/wire nuts. Once you have them into the correct order the aftermarket harness should connect into the harness in your vehicle. I hope this answers your question =)
Nov 05, 2013 | JVC AM FM CD DET FACE CAR STEREO
94 bronco intermitten starting and sometimes quits while driving
That could be because some distributers have pickup coil and ignition modual in them and some dont......hope this helps
Aug 15, 2012 | 1994 Ford Bronco
Do I need a wiring addaptor to install this stereo into my 2004 f150?
Yes, I recommend a vehicle specific wiring harness for the installation to be proper. When installing aftermarket stereo units in some vehciles, it is necessary to insure that all of the vehicles components are receiving power during normal operation.
FYI, to obtain the proper harness, you will need to provide a bit more information about your vehicle, such as 2 door or 4 door, what version of the Ford stereo is currently installed and whether or not the unit amplified.
Mar 08, 2011 | Clarion NX500 Car Video Player
Putting cd player in 94 explorer?? HELP PLEASE?!?!?!?
Yes, that would be fine, make sure you solder the wires and tape well or use shrink tube on the connections.
Mar 13, 2010 | 1994 Ford Explorer Limited
Hi, I am installing a new head unit into my dads 98' Buick LeSabre and the factory harness has been cut and I'm not sure of the color code and not sure how to run the extras thru the new head unit and how...
Metra makes wire harnesses for your problem. If your wire harness is, 70-5555 the part that goes into the OEM radio will be 71-5555
Try www.metraonline.com and put in the car info. The harness will come with wire codes for splicing the new plug.
Dec 17, 2008 | Car Audio & Video
Stereo Upgrade in 1997 Sentra
hi there. I am not sure about the speakers. But there is a wiring harness available for a aftermarket head unit. I have a '97 sentra the base model XE version. I have just put in an alpine head unit and you defenately hear the difference even on factory speakers. But you will need 2 kits to install an aftermarket head unit in the car. 1. A dash kit. I got mine from canadian tire for about 20 bucks, it comes with instructions on how to put it together and its straight forward, just make sure u get the one for your year and make of car.
2. The wiring harness. there available at mostly every car audio place for about 10 bucks. again make sure u get the one for your year make and model of car. installing this is difficult so unless your good at electronics get it professionally installed. you have to splice the wires into the back of the aftermarket unit, then the plugs plug right into your existing factory car harness.
hope this solves your problem, the dash kit is easy to put together and install into the car, but the wiring harness is a bit difficult, i had my harness installed for about 40 bucks and u save money if u put the dash kit togehter yourself because thats 1 less thing they have to do. good luck.
Nov 29, 2008 | 1997 Nissan Sentra
Scosche Industries Scosche Slc4 Speaker High Level Converter Logo
529 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
