Question about Microsoft Virtual PC 7 with Windows XP Home (s65-00396) for Mac
Usb ports are not working in Virtual Pc
I have installed virtal pc in windows vista. In virtual pc I have installed windows xp. Under this my usb ports are not working. Also my cd/dvd drive does not read dvds. It only reads cds.So please give the solutions for these problems. Thank you.
  • Anonymous Apr 01, 2009
    "portas USB não estão funcionando no Virtual PC
Install Virtual Machine additons and u can share the folder between the host and guest pc.
Posted on Mar 04, 2009
How to connect to computer
The unit has a parallel port interface and is supported under Windows 95/98/Me, Windows NT 4.0/2000/XP . The drivers are available here: http://www.usa.canon.com/cusa/support/office/laser_facsimile/laser_class_2050_2050p_2060_2060p/laser_class_2060p?selectedName=Specifications#DriversAndSoftware . For the supported OS versions, download the drivers and then run the exe. If it extracts drivers, note the folder in which they are stored. Then launch the Add a Printer Wizard (Printers and Faxes in XP IIRC). If your computer doesn't have a parallel port, parallel to USB adapters do exist.
Neither Vista or Win7 Compatibility Center have the unit listed. The XP driver may work in Vista 32-bit with the compatibility mode on. For Win7 or Vista 64-bit, I'd suggest a second computer, a dual boot computer or a virtual computer with an older Windows OS. For the most setups, you'll need a licensed version of the Windows OS. (Virtual computer software include: Parallels, VMWare and Virtual PC.)
With Win7 Pro or Ultimate, you can download Virtual PC and XP mode from Microsoft for free, then install them in order. The printer will install normally into the XP virtual computer. However, files from the main computer will need to go onto optical media or an external drive in order to share them with the virtual computer for printing.
I hope this helps.
Jan 14, 2011 | Canon LaserClass 2060P Plain Paper Fax
Tip
How to Install any Driver/Software which isn't Supported by Windows Vista/7
Hello!!
There are lots of old Soft-wares and Drivers available which are not compatible with Higher Version of Windwos.
So some Windows XP exclusive setups can be installed under Windows Vista/7 As Under.
1. Try to install the drivers in compatibility mode.
2. For that right click on setup.
3. Go to properties.
4. Go to compatibility Tab.
5. Set it to win xp sp2.
6. Hit ok
7. Run setup as administrator
8. Ignore any error and hit continue anyway during installation
9. Restart pc
If the above trick doesn't work, then use the device in VIRTUAL XP MACHINE
You can use XP MODE or VMWARE or any other Virtal Machine Application.
Hope it Helps..!!
on Jul 13, 2011 | Computers & Internet
I absolutely hate vista....i wasn't able to transfer my microsoft money so had to download quicken and transfer info...then twice now i have had to reinstall quicken because it won't open up...i guess it...
There is a work around to getting Windows XP programs to work under Windows Vista - Virtual PC 2007.
Virtual PC 2007 is a free download from Microsoft and it allows you to install any operating system and run it in a "window" on your Vista desktop.
Download Virtual PC 2007, create a Windows XP virtual machine, install Microsoft Money and transfer in your data. You can install Quicken as well.
The virtual machine will use your PC's actual connections (network, serial and printer but not USB) to connect to devices and the Internet.
Again - this is a work around that is proven to work. One side benefit - you can copy the virtual machine to an external hard drive / USB memory stick and run it on any comptuer that has Virtual PC 2007 installed on it.
Hope this helps
Nov 18, 2009 | Microsoft Windows Vista Ultimate Edition
Find free driver for umax astra 5600 scanner for OS windows7
I have Umax Astra 5600 scanner but it dose not work in Windows 7
Nov 16, 2009 | Office Equipment & Supplies
I install Windows XP mode and then Microsoft Virtual PC. The computer reboots after virtual pc installation and I then run Xp mode and find it wonderful. I will shut XP mode down and then reboot and my...
Try using the free and simply brillant Sun systems 'VirtualBox'.
http://www.virtualbox.org/wiki/Downloads
I am running Windows 7 Ultimate and could not implement Windows XP mode and MS VPC does not support USB devices: I have both Win XPPRO SP2 and W2003E running in VirtualBox with supports to all my existing USB devices including VGEAR DTV which refuses to works since Vista days and Native Windows 7 (eg. no drivers!).
Hope it helps!
Nov 01, 2009 | HP Pavilion dv7-1130us Notebook PC
I have a problem to install window 98 .
Another solution is to download and install Microsoft Virtual PC in XP, create a Virtual PC drive, and install Windows 98 onto the Virtual PC drive. This works fine if you want to run Win 9X programs which don't require access to USB ports on your computer. If you need Windows 98 to have full access to all of the computer hardware, then use palaboy's solution.
Apr 21, 2009 | APC USB Port Version For Windows 98...
I have installed virtual pc in windows vista. in virtual pc i ave installed windows xp. in virtual pc my usb ports are not working
Virtual PC for Windows does not support USB devices (other than a mouse and keyboard ... which are not actually emulated via USB, but are simply "used" through the host) ... but just to confirm the "official" statement of this:
http://support.microsoft.com/kb/824511/en-us
Unfortunately, Microsoft did NOT add USB support in Virtual PC 2007 (a widely anticipated addition that simply didn't happen).
VMWare Server DOES support USB devices (through the host) with some exceptions. From the documentation: "... Modems and certain streaming data devices, such as speakers and Web cams, do not work properly." You may want to read the details of using USB devices with a VMWare virtual machine starting on page 232 here: http://www.vmware.com/pdf/server_vm_manual.pdf
You can download Virtual Server for free here (You'll need to register and request a free key ... a painless process): http://www.vmware.com/download/server/
Dec 28, 2008 | Microsoft Virtual PC 7 with Windows XP...
Hello,usb.2.0-ser can't install in vista window, thanks
r u using 64-bit because vista 64-bit wont allow drivers that are not whql certified to install...
Nov 28, 2008 | Computers & Internet
HP DesignJet 450c driver for windows vista
THIS SOLUTION IM ABOUT TO TELL YOU IS IN MY EXPERIENCE THE EASIEST ONE JUST DOWNLOAD THE WINDOWS XP DRIVER FOR THE HP DESIGNJET 450C PRINTER AND INSTALL IT INTO THE WINDOWS PRINTER PLATTFORM, YOU MAY SEE SOME ANOUNCEMENTS FROM YOUR COMPUTER TELLING YOU THAT THE PROGRAM YOUR TRYING TO INSTALL MAY NOT BE COMPATIBLE "DONT LISTEN TO THEM" JUST CONTINUE YOUR INSTALLATION AND PRESTO YOUR DESIGNJET PRINTER WILL WORK PERFECTLY
Feb 20, 2008 | HP DesignJet 450c InkJet Printer
Microsoft Virtual PC 7 with Windows XP Home (s65-00396) for Mac Logo
1,275 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
