If the result is positive, type in the integer part then add the fraction part either with the help of the fraction key or the division key. (I do not think that the TI82 has a fraction key.
If it is anything like the TI3 there is command under MATH >Frac. It should be pressed after you enter the mixed number to keep the result as a fraction.
If the mixed number is negative you enclose the whole number in parentheses. Press the change sign (-) key to negate the result.
Press the [ON/C] key to turn on the calculator. Press the [OFF] key to turn it off. To use the calculator in solar mode, put the solar panel in the light and then press the [ON/C] key. To turn it off when in solar mode, slide the calculator cover back on and it will automatically shut off.
Replace the batteries by first removing the cover and placing it face down. Use a Phillips-head screwdriver to unscrew the back panel. Remove the back panel and change the batteries. Screw the back panel back on. Press [OFF] [ON/C] and [ON/C].
Use the basic operation keys for addition [+], subtraction [-], multiplication [x] and division [/]. To change the signs of your values from positive to negative or vice versa, press the [+ -] key before the numbers you enter. Use the parentheses, [(] and [)], to command the calculator to solve what is inside the parentheses first. Press the [=] to solve the number sentence you entered into the calculator.
Find percents of a number by first typing in the number, then [x], then the percent number, [2nd], [%] and, finally, [=]. The [2nd] key allows you to use the commands that are written above each key. For example, to find 20% of 100, type in 100 [x] 20 [2nd] [%] [=] and the display will show the answer, 20.
Turn decimals into fractions by entering the decimal value, then pressing the [2nd] and [F D] keys, then [=]. Turn the fraction back into a decimal by pressing [2nd] and [F D] again. For example, to turn 0.5 into a fraction, type in 0.5 [2nd] [F D] [=].
Turn mixed numbers into improper fractions by entering the mixed number first. Type in the whole number, then the [a b/c] key, then the numerator, the [a b/c] key again and the denominator. Next, press [2nd] [d/c] [=], and the calculator will convert your mixed number into an improper fraction. Press [2nd] [d/c] again to turn it back into a mixed number. For example, to turn 1 1/2 into an improper fraction type in 1 [a b/c] 1 [a b/c] 2 [2nd] [d/c] [=], and the display will show the answer 3/2.
Switch the notation setting of the calculator between engineering, scientific and floating. To select scientific notation, press the [2nd] and [SCI] keys; this will display your answers in scientific notation as a number between 1 and 10 to a power of 10. Press [2nd] [ENG] to switch to the engineering setting; this setting displays values as a number with an exponent that is a multiple of 3. Press [2nd] [FLO] to switch to the floating setting. This is considered standard notation and will display the answer as a standard number.
Use the left arrow key to go back and delete numbers to the right of the cursor that you typed into the display. This must be done before you press [=]. To clear the screen, values and operations, press [ON/C] and [ON/C] again in battery mode, or [CE/C] and [CE/C] again in solar mode.
